It is currently Mon Jul 16, 2018 6:16 am
 Post subject: Driver battery SP305
PostPosted: Fri May 04, 2018 9:09 am
Всем привет, имеется программатор Field PG M3, стоял аккумулятор SP303. После замены на SP305 программатор не видит аккумулятор, возможно необходимо установить драйвер для аккумулятора ?! Подскажите в чем может быть проблема.
 Post subject: Re: Driver battery SP305
PostPosted: Sat May 05, 2018 7:00 pm
https://support.industry.siemens.com/cs/document/48791866/simatic-field-pg-m3-aktuelle-bios-version?dti=0&lc=de-WW
There is the new BIOS with Support of the new Battery.
PostPosted: Tue May 15, 2018 8:35 am
Hello, please help. I have a Field PG M3. Changed the accumulator SP305, now I do not see it Windows. My version of BIOS 140107.
PostPosted: Fri Jul 13, 2018 8:55 am
Im looking for the last Bios for the Power PG P3 Version V10.02.07
Or a Bios newer then Version V10.02.04
Maybe someone have it.
PostPosted: Sat Jul 14, 2018 9:17 am
this ?
https://support.industry.siemens.com/cs ... w/48791866
