I have the splitted files in STEP 7 and WinCC Professional folder :
STEP 7 and WinCC Professional.md5
TIA_Portal_STEP_7_Pro_WINCC_Pro_V15.001
TIA_Portal_STEP_7_Pro_WINCC_Pro_V15.002
TIA_Portal_STEP_7_Pro_WINCC_Pro_V15.003
TIA_Portal_STEP_7_Pro_WINCC_Pro_V15.004
TIA_Portal_STEP_7_Pro_WINCC_Pro_V15.exe
TIA_Portal_STEP_7_Pro_WINCC_Pro_V15.out
TIA_Portal_STEP_7_Pro_WINCC_Pro_V15.txt
TIA_Portal_STEP_7_Pro_WINCC_Pro_V15_2.001
TIA_Portal_STEP_7_Pro_WINCC_Pro_V15_2.002
TIA_Portal_STEP_7_Pro_WINCC_Pro_V15_2.003
TIA_Portal_STEP_7_Pro_WINCC_Pro_V15_2.004
TIA_Portal_STEP_7_Pro_WINCC_Pro_V15_2.exe
TIA_Portal_STEP_7_Pro_WINCC_Pro_V15_2.out
The files with out- extension I got after I had assembled the files *.001...*.004 и *2.001...*2.004 in Total Commander. It sent me a message "Assembly was successful. CRC- sum was not found"
What to do next ?
TIA v.15. How to assemble the distributive ?
Re: TIA v.15. How to assembly the distributive ?
run selfextracting TIA_Portal_STEP_7_Pro_WINCC_Pro_V15.exe
and select folder for unpack and install
https://support.industry.siemens.com/cs ... l-download
Notes about downloading
The download is split into multiple files.
Please first download all of the parts to the same folder
and then execute the file with the extension .exe.
Afterwards, the parts are merged and you can execute the setup.
Thank you very much !
I tried you told but I had no enough patience to wait a little more
I thought the assemly was hang.
