It is currently Sat Apr 21, 2018 1:28 am
PostPosted: Mon Apr 16, 2018 11:56 am
hello everyone
we work on a water station using plc schneider M340 and we should make a communication with a dcs honeywell , this dcs should read a variables from my plc i have a ethernet module BMX NOE 0.100
i put the ip adress but the dcs show that the variables are not online
PostPosted: Mon Apr 16, 2018 5:52 pm
Hi accmpy,
on M340 side you can only setup the IP-address and %MWi variable addresses.
So, if communication doesn't work, then check the IP and %MWi addresses.
Users browsing this forum: seba and 1 guest
