iFix 5.5 crack request
Bandika
Post by Bandika » Wed Jan 16, 2013 9:13 am
Hya,
I searched all topics for a crack for iFix. Found cracks for vers. 4.5, wanted to try it with 5.5 wishing myself luck, but all the DL links are broken.
Has anyone a sollution for iFix 5.5 so I can take out that annoying 2 hour time limit?
Any help is welcome, I am ready to try everything (almost) to crack it, fix it.
lehith
Re: iFix 5.5 crack request
Post by lehith » Mon Mar 25, 2013 8:37 am
key from all fix ^)
http://db.tt/fE7vbZGZ
monty_burns_007
Post by monty_burns_007 » Mon Mar 25, 2013 9:18 pm
thanks for the dumps
8)
wangrenzhi
Post by wangrenzhi » Wed Mar 27, 2013 1:38 am
lehith wrote:key from all fix ^)
How to use? think you
linhvt
Post by linhvt » Fri Mar 29, 2013 4:35 pm
Please tell me how to use your key?
Thanks.
Jacksoce
Post by Jacksoce » Wed Apr 03, 2013 7:24 pm
can someone tell me where can i download the ifix5.5 ?
Bandika
Post by Bandika » Thu Apr 04, 2013 8:23 am
Many thanks, I will try it as soon as possible
Bandika
Post by Bandika » Thu Apr 04, 2013 12:27 pm
Tested on Win 7 32 bit and works perfectly.
Readme file is written strange but here are the steps I made:
1 - Run install.cmd
2 - Run ifix reg key (for the desired version, my case 5.5)
3 - Run restart.cmd
I did all this as administrator
hina
Post by hina » Wed Apr 10, 2013 1:37 am
Dear All,
Please re upload ifix 5.5 link because ftp://ftp.automacao.com.br/Suporte/INST ... X/iFIX5.5/ already empty
thank you very very much
Best Regards,
wangrenzhi
Post by wangrenzhi » Wed Apr 10, 2013 4:23 am
wangrenzhi
Post by wangrenzhi » Wed Apr 24, 2013 4:44 am
Bandika wrote:Tested on Win 7 32 bit and works perfectly.
1 - Run install.cmd
3 - Run restart.cmd
the key iFix 5.5 run demo,only 2 hours time,why?
sonia01710
Post by sonia01710 » Thu Jan 23, 2014 1:34 am
Today I also tested this procedure and found that after crack, iFix 5.5 runs for 2 hours same as trial version on windows xp 32bit OS.
shark1980
Post by shark1980 » Fri Jan 24, 2014 8:43 am
:( Crack for 5.5 not work, 2 hours trial. OS - windows 7 32bit.
kjmc
Post by kjmc » Mon Jun 09, 2014 8:36 pm
Key works except for Historian.
I installed, everythings ok when I open the license viewer. The license viewer shows Historian 4.5 authorized but when I log in to administrator it tells me i'm limited to 1 user / 25 tags(the trial version).
I try historian on ifix 5.5 disc, standalone historian 4.5 disc.
The historian "about" menu lists version as 4.5.1xxx but license viewer shows 4.5 authorized. Is that big different?
Historian 4.0 works no problem, no trial limitiation.
Any body else has same problem?? Any ifix 5.8 multikey ready?~?~?~
mech962784
Post by mech962784 » Fri Jun 20, 2014 7:10 am
this license shows no Opc driver licensed .
is it possible to have one with OPC enabled / licensed?
kjmc
Post by kjmc » Sat Jun 21, 2014 12:56 am
mech962784 wrote:this license shows no Opc driver licensed .
Proficy iFix works with the OPC driver. There are many products in the license, which are you want to use?
mech962784
Post by mech962784 » Sat Jun 21, 2014 6:04 am
When i view the ifix license status it will show that the number of licensed opc clients is zero
kjmc
Post by kjmc » Sun Jun 22, 2014 3:46 pm
I'm not understand this OPC option. I use the OPC driver and it works for me to communicate to OPC server, I see intellution OPC components when I install different OPC server program. Maybe it work if you try to use it?
dugme
Post by dugme » Fri Nov 07, 2014 6:45 am
Link ftp://ftp.technolink.spb.ru/SOFTWARE/Pr ... .5-DVD.zip does not working.
Some new link?
monty_burns_007
Post by monty_burns_007 » Mon Nov 10, 2014 3:59 pm
indeed any 5.8 multikey dump available ?
Schtiel
Post by Schtiel » Tue Nov 11, 2014 7:38 pm
dugme wrote:Link ftp://ftp.technolink.spb.ru/SOFTWARE/Pr ... .5-DVD.zip does not working.
Some new link?
lamanck
Post by lamanck » Mon Nov 16, 2015 3:33 am
hina wrote:Dear All,
Best Regards,
Try this ftp://ftp.automacao.com.br/Suporte/INST ... X/iFIX5.5/
turbocex
Post by turbocex » Wed Oct 26, 2016 5:57 pm
Hi guys,
could you please provide me again the iFix 5.5 Crack?
Thanks a lot!!!
rott3
Post by rott3 » Mon Jul 31, 2017 7:05 pm
Hi all,
can someone post new links for iFix v5.5 crack?
thanks
Regards
rott3
Raptor
Post by Raptor » Mon Aug 07, 2017 9:55 am
I need too
