[?]: danfoss cable for inverter
привода и частотники
hussein kamal
Post by hussein kamal » Mon Feb 27, 2012 11:38 am
i need help to connect danfoss inverter to take backup program from it plz help me to how make cable
xooo
Re: [?]: danfoss cable for inverter
Post by xooo » Mon Feb 27, 2012 5:23 pm
MCT 10 Motion Control Tool Software and the cable from the printer. page 11:
http://danfoss.ipapercms.dk/Drives/DD/G ... tionDrive/
dekor
Post by dekor » Mon Feb 27, 2012 6:52 pm
first you will need a converter RS232 to RS485 then you may access the inverter.
I found on a manual next explanations:
Using VLT Software Dialog
Connection to terminals
Sub D:
- PIN 3 GND
- PIN 8 P-RS 485
- PIN 9 N-RS 485
or
you may use terminals 68-70
Terminal 68 : RS485 P
Terminal 69 : RS485 N
Terminal 70 : GND
dekor
hussein kamal
Post by hussein kamal » Mon Feb 27, 2012 7:18 pm
thanks dekor for your help
(pgood) (pgood) (pgood) (clap) (clap) (clap)
