[LINK]: EPLAN Electric P8 v2.1.4 Build 5325 (x86/x64)
Тools, Elcad, Eplan, ...
Linkinx64
Re: EPLAN Electric P8 v2.1.4 Build 5325 (x86/x64) | 1.34 GB
Post by Linkinx64 » Wed Sep 14, 2011 3:25 am
Same release on torrent : http://rutracker.org/forum/viewtopic.php?t=3729861
2011/09/25: WITH CRACK.
jscumm
Post by jscumm » Thu Sep 15, 2011 2:22 am
PDLFFALF
Post by PDLFFALF » Thu Sep 15, 2011 6:23 am
PDLFFALF wrote:EPLAN Electric P8 v2.1.4 Build 5325 (x86/x64) | 1.34 GB
Eplan PPE 2.0 SP1 v2.0.9.4831 | Multilingual | 722 MB
CRACK (serial number file SN-U10066.EGF):
http://eplan-eb2.ys168.com/
see page only with Microsoft Internet Explorer ! and press this button
niila
Post by niila » Thu Sep 15, 2011 6:48 pm
Is this cack for P8 V2.1.4
The crack in the download do not work for the version P8 2.1.4 !!
it s working perfectly (pgood)
Sprudel1968
Post by Sprudel1968 » Thu Sep 15, 2011 7:15 pm
V2.0 SP1 works fine.
V2.1.4 is not work. why what am I doing wrong?
I copied the file-SN-U1006.EFG in common directory.
But V2.1.4 does not work.
niila
Post by niila » Thu Sep 15, 2011 7:53 pm
first be sure that install hasp hardlock driver then copy .egf to Common folder
now you can download files from eplan-eb2.ys168.com "EPLAN P8 Cabine 2.0 SP1 patch Windows x32 x64"{3 parts} and apply steps
Link
Forum Community
Forum Community
Post by Link » Thu Sep 15, 2011 9:17 pm
Sprudel1968 wrote:The files of eplan-eb2.ys168.com can not uncompress.
Packer reports error in file.
use MS IE only and press this button
jscumm
Post by jscumm » Fri Sep 16, 2011 2:34 am
these links are still good with right crack
enjoy! :D
http://www.fileserve.com/file/M2NquUx/EP8.2.1_UploadbyTraining.part1.rar
http://www.fileserve.com/file/mhWbNyG/EP8.2.1_UploadbyTraining.part2.rar
http://www.fileserve.com/file/UF9CWmy/EP8.2.1_UploadbyTraining.part3.rar
Mirror 1:
http://www.wupload.com/file/169440166/EP8.2.1_UploadbyTraining.part1.rar
http://www.wupload.com/file/169442222/EP8.2.1_UploadbyTraining.part2.rar
http://www.wupload.com/file/169441437/EP8.2.1_UploadbyTraining.part3.rar
Mirror 2:
http://www.filejungle.com/f/s85KG6/EP8.2.1_UploadbyTraining.part1.rar
http://www.filejungle.com/f/ScUJcy/EP8.2.1_UploadbyTraining.part2.rar
http://www.filejungle.com/f/HaKVXn/EP8.2.1_UploadbyTraining.part3.rar
Mirror 3:
http://www.filesonic.com/file/1974960284/EP8.2.1_UploadbyTraining.part1.rar
http://www.filesonic.com/file/1974966244/EP8.2.1_UploadbyTraining.part2.rar
http://www.filesonic.com/file/1974959544/EP8.2.1_UploadbyTraining.part3.rar
sadefa
Re: [LINK]: EPLAN Electric P8 v2.1.4 Build 5325 (x86/x64)
Post by sadefa » Sat Sep 17, 2011 4:36 pm
Hello 2 all,
I have the following problem - I use windwos 7 Ulimate 64 bit, and I used the following instructions:
Instructions
Show
1. Install Eplan P8 2.0.5.4602, required setting the "management rights" from the "examples / basic data" if the installation does not deliver, it just pops up and the message: "Information Rights Management is currently unavailable. The database file is missing or broken access to the file. As to infringement can not be established unequivocally, it is impossible to run the program.
2. Copy the license file (SN-U10225.EGF) from folder to folder EPLAN_P8_2.0_patch_Windows_x32x64 C: \ User \ Public \ Eplan \ Common \;
3. Remove driver protection HL Hasp Control Panel - Programs and Features (Right-click on Eplan License Manager - Edit, then do the hardware key driver is unavailable);
4. Install newer drivers HASPUserSetup.exe;
5. 5189.reg run the file and add data to the registry;
6. Run the driver installation Multikey - emulator from your Release \ MultiKey64 \ install.cmd;
7. Run a test mode in Windows 7 x64 dseo13b.exe running the program and the radio button for "Enable Test Mode".
By the way, just note that here also provides the opposite effect "Disable Test Mode", disable the test mode;
8. In one corner will display "Test Mode Windows 7 Rekease 7600;
9. 9. Run the program dseo13b.exe;
10. 10. Add a digital signature for the driver Multikey.
To do this, select "Sign a System File" and enter the filename including the full path C: \ Windows \ System32 \ Drivers \ multikey.sys, test mode does not turn off!
11. Reboot your computer;
12. Start the EPLAN Electric P8 2.0.5.4602 and enjoy his work
now the problem is that I cannot install the Eplan License client for the noew eplan version 2.1. I get an error messagethat says that the hardlock service cannot be stoped.
Any ideas for solution?
many thnaks in advance
SOLUTION:
use the dseo13b.exe disable test mode. restart start again dseo13b.exe - enable test mode. Install only the lciense client. Done :)
Link
Forum Community
Forum Community
Post by Link » Sun Sep 18, 2011 7:48 am
sadefa wrote:the folder is empty
today is empty (boom)
but
nonlongtimelife link
https://rapidshare.com/files/3226162504/SN-U10066.EGF
sadefa
Post by sadefa » Sun Sep 18, 2011 10:10 am
I have problem with the dongle emulator. I am using Windows 7 Ultimate 64 bit OS.
Any ideas how to run the dongle service on this OS. I did not have any problemes with the 2.0 SP1, but now I have with this 2.1 version. Whenever I click the start servce buton on the Emulator tab i get an error mrssage "Error 1275".
Many thanks in advance!
Please not taht that on the status bar there is the this note that I underlined with green, that fhr emulator is for 1.8. Does this mater at all?
niila wrote:@sadefa
I do not understand why you are using dongle emulator tool 1.8.6 still
when you do necessary steps it s gonna work without tool
this is what's included into the torrent, and acutially this is the firs time I see this dongle emulator...
Can you please tell me where to look for the "necessary steps" for 64 bit OS?
niila
Post by niila » Sun Sep 18, 2011 9:00 pm
http://eplan-eb2.ys168.com/ you can download from here called "EPLAN P8 Cabine 2.0 SP1 patch Windows x32 x64"{3 parts}
or check your pm
workto2009
Post by workto2009 » Mon Sep 19, 2011 2:37 am
Hi All For eplan p8 V2.1 have any crack?
because now i have problem for serial when open program
ok i have copy SN-U10066.EGF to C:\Users\Public\EPLAN\Common.
for this version need to be install Dongle or not?
who can install for this version under win 7 64 bit can you tell how to do????
sadefa
Post by sadefa » Mon Sep 19, 2011 6:54 am
The problem is not the license file, but the dongle emulator. It does not work correctrly for 2.1 under 64 bit OS. I have the same problem like you.
I used to have 2.0 SP1 and everything was OK, but now it seams that I cannot start the dongle service :(
In test mode I have build 7601, but that was not a problem with the 2.0 SP1.
UPDATE:
Here is the problem:
I do everything as it's written, but the driver is not working properly. I did try to use windows update, but it's still not working, the driver is not OK and windows says that there is no better one. Anyone with driver files to install manually?
The co processor is something else.
sadefa
EPLAN Electric P8 v2.1.4 EMULATOR
Post by sadefa » Sat Sep 24, 2011 4:46 pm
Hello 2 all!
For everyone that have ever had a problem with EPLAN Emulators.
For version 2.1 follow the following steps:
1. Download the rar archive from http://www.filesonic.com/file/2216098681
2. Set UAC to minimal. (User account control)
3. Install EPLAN 2.1
4. Copy the file that is into the common folder from the rar and paste it to C:\Users\Public\EPLAN\COMMON.
5. Go to control panel. There you will find licence client. Right click and click change. There you can disable the HL drivers.
6. Install the new drivers (provided into the rar - HASPUserSetup.exe)
7. Add the data to the registry by running 5189.reg from the archive
8. Go to the Release folder and then to x32 or x64 (depending from your PC and OS) and run install.cmd
9. Run dseo13b.exe and enable test mode.
10. Restart your computer
11. Run dseo13b.exe and sign a file. The address of the file is C:\Windows\System32\Drivers\multikey.sys
12. Restart your computer
13. EPLAN 2.1 is running
It took me 2 weeks to make 2.1 run on my x64 system. That's why I share this and hope everything is OK. I tested more than 4 emulators with thousands of options for installing - it did not work. Finally it worked with this one :)
Regards
sadefa
Re: EPLAN Electric P8 v2.1.4 EMULATOR
Post by sadefa » Thu Sep 29, 2011 3:30 pm
is it possible to upload the link again from filesonic
something else, what i dont understands is that the link http://eplan-eb2.ys168.com/ the same looks in firefox as well internet explorer
use the link from my post. I got this from a torrent site.
I also cannot tell why the http://eplan-eb2.ys168.com/ has to be opened only with IE ...
aladin2140 wrote:but the link is expired
i tried it with internet download manager also not working
Don't use any (boom) (=integrated "internet download manager" - disable it) - you need only CLICK
Link work also with Firefox
sadefa
Post by sadefa » Sat Oct 01, 2011 10:18 am
aladin2140 wrote: ...
sadefa
can you tell me where to find licence client
because i can't find it the control panel
and the eplan is installed
Maybe I can create a video tutorial for this?
aladin2140
Post by aladin2140 » Mon Oct 03, 2011 12:37 pm
if you do make a video can you also show which settings you choose in eplan 2.1.4
because i am at ends desperatings
i found the change in control panel in programs
i patched and installed multikey in testmode
then in normal mode it began copying files, i was really happy ( i though i was going further in the process)
but then comes the eplan
when i start it
i always get the licence windows
did i forgot something.
thanks for the reply
sadefa
Post by sadefa » Mon Oct 03, 2011 9:20 pm
here is a link for the video. Sorry for the poor quality of the speech, but the mic I used was quite old.
Download link for video:
http://www.filesonic.com/file/2310960711
Download link for patch:
Instructions:
PS. All the tutorials are really similar, but the problem comes form the files that are included into the download archives. For example I saw a link for 2.1 crack and the license file was for 2.0 ... or the registry file is for other license file. With this one everything is OK, I personally got 2.1 running with this. If you still have problem, uninstall all drivers, uninstall Mkey and license client. Install Eplan LC and you are back to step 3 and try again.
I hope I helped.
aladin2140
Post by aladin2140 » Tue Oct 04, 2011 9:53 am
sadefa really really really really really really thank you with the video it worked
it worked from yesterday too i only had to test it in testmode i didn't know that
sadefa if you have a better tutorial in the near future that eplan can work in normal windows can you pm me
because it is my little brother is working with it
and i don't know if it is a good idea to work alway in testmode
thanks for your helps and patients
sadefa
Post by sadefa » Tue Oct 04, 2011 5:05 pm
Actually I have nothing to do with creation of the patch or any EPLAN crack. I just made the video ...
I made some correction to the quality of the speech in the video.
The new video can be found here:
or
https://rapidshare.com/files/2402453002/Eplan.mp4
aladin2140
Post by aladin2140 » Tue Oct 04, 2011 10:05 pm
@ sadefa
the files in your instructions would it also work for eplan 1.9
because the dongle they give would not work for 64 bit
(my little brother is used to work with 1.9 in school)
and another problem would i tested today a project from 1.9 to open in 2.1 and it said it could not convert it
thus it can't read nor open it
thanks
sadefa
Post by sadefa » Wed Oct 05, 2011 6:41 pm
Yesterday at work my colleges told me that the new eplan 2.1 converts the database as 2.0 was doing it.
So far I did not have the chance to open 1.9 or lower project with 2.1.
I will try it later when I can get a license from the server, as all the licenses we have at the company are already taken (we have net installation of eplan).
I will write back what happened.
Boxy
Post by Boxy » Wed Oct 05, 2011 11:20 pm
Normaly, if you open a project from 1.9 then Eplan ask you and then convert it to 2.x and make a copy of the old project wit V.... in the filename.
But it is not possible to convert it back to 1.9! Because the change something at hte Database!
sadefa
Post by sadefa » Thu Oct 06, 2011 6:43 am
@Boxy
I know that, but the question was if eplan 2.1 can open projects made on 1.9. I know that eplan 2.0 is converting the DB of projects made on 1.9. The same goes for 2.1. Eplan 2.1 converts the DB of projects made on 2.0.
btw. I have also another mirror:
http://hotfile.com/dl/133803247/8903ca5/Electric_P8_2.1.4.5325.part01.Link_is_Dead :(
http://hotfile.com/dl/133804504/213bfce/Electric_P8_2.1.4.5325.part02.Link_is_Dead :(
http://hotfile.com/dl/133803848/a8f40aa/Electric_P8_2.1.4.5325.part03.Link_is_Dead :(
http://hotfile.com/dl/133806341/76682ef/Electric_P8_2.1.4.5325.part04.Link_is_Dead :(
http://hotfile.com/dl/133807064/05a72c3/Electric_P8_2.1.4.5325.part05.Link_is_Dead :(
http://hotfile.com/dl/133805117/295ca4c/Electric_P8_2.1.4.5325.part06.Link_is_Dead :(
http://hotfile.com/dl/133807926/c4da0aa/Electric_P8_2.1.4.5325.part07.Link_is_Dead :(
http://hotfile.com/dl/133889011/a3efa43/Electric_P8_2.1.4.5325.part08.Link_is_Dead :(
http://hotfile.com/dl/133888420/47e9626/Electric_P8_2.1.4.5325.part09.Link_is_Dead :(
http://hotfile.com/dl/133956494/e48916b/Electric_P8_2.1.4.5325.part10.Link_is_Dead :(
http://hotfile.com/dl/133956964/116bce5/Electric_P8_2.1.4.5325.part11.Link_is_Dead :(
http://hotfile.com/dl/133968889/f398de8/Electric_P8_2.1.4.5325.part12.Link_is_Dead :(
http://hotfile.com/dl/133969538/d7fd77e/Electric_P8_2.1.4.5325.part13.Link_is_Dead :(
Boxy
Post by Boxy » Fri Oct 07, 2011 10:22 am
Sorry sadefa, as i write this, i dont think about you. I think there about the question from aladin ...
I actualy tryed it and opend (recover) a old Project 1.8 or 1.9 in Eplan V2.1.4.
The same as if you open it in 2.0.x. They recover it and told you to convert it to the new Database. If you dont convert it, it's write protect or only readable.
Only different as i see, is that if you convert vom 2.0.x to 2.1.4 is the in the Filename from the old Version (1.8/1.9) is not _V3_ its _V6_ ...
aladin2140
Post by aladin2140 » Fri Oct 07, 2011 12:24 pm
@ boxy
can you give me a good example of the extensions you talk about what you have to change in the project about that V
because i can't really follow
i only installed eplan for my little brother
thanks everyone
Boxy
Post by Boxy » Fri Oct 07, 2011 2:40 pm
You don't must chang anything.
Only open the Project and Eplan do the rest by himself (wait)
BULBO
Post by BULBO » Mon Oct 24, 2011 8:30 am
Hi Boys,
I have test this and works fine only with Export/Import.With this operation Eplan don't control the version.
Bonavox
Post by Bonavox » Mon Oct 24, 2011 9:16 am
Well ... it is working but there is one difference between 2.0 and 2.1
In 2.0 you could swith back "Disable Test Mode" and work with.
In 2.1 you probably have to let Windows in the Test Mode for ePLAN working (at least in my case - when I turn off Test Mode then ePLAN 2.1 is not possible to run).
cuervo2k
Post by cuervo2k » Tue Nov 08, 2011 11:10 am
hi, can someone explain me how to activate the program in windows xp 32 bits?. I do not get to run the dongle emulator. Thank you.
Bonavox
Post by Bonavox » Tue Nov 08, 2011 11:16 am
Does anybody know? Is there any difference between original CD and downloads which are in this posts?
If I will use original ePLAN installation CD would it work with activation procedure?
sadefa
Post by sadefa » Mon Nov 14, 2011 2:27 pm
cuervo2k wrote:hi, can someone explain me how to activate the program in windows xp 32 bits?. I do not get to run the dongle emulator. Thank you.
There is a topic about this.
Bonavox wrote:Does anybody know? Is there any difference between original CD and downloads which are in this posts?
They are the same :)
Xfx-MX
Post by Xfx-MX » Wed Nov 16, 2011 12:10 pm
hi everybody, I installed eplan here and I cracked successfully but when I create a new project, e-plan can not find any template, then I try to find it manually but there is no any template folder in my computer. My friend sent me his own template folder, now I can use my friend's template. However When I choose a component to add ( for example "a black box") eplan gives me this message " no matching symbol was found in the project". I installed 2 different eplan but nothing changed. what is the problem, can someone help me?
sadefa
Post by sadefa » Tue Nov 22, 2011 10:54 pm
hm ... there must be :)
Look @ C:\Users\Public\EPLAN\Electric P8 and there should be a folder named templates :)
gogycro
Post by gogycro » Sun Nov 27, 2011 11:23 pm
Bonavox wrote:Does anybody know how to use included Data Portal?
I did install Data Portal from installation CD, but nothing happened.
There is no shotcut in the Start menu, there is no shortcut in ePLAN menu ... :?:
Open EPLAN then Utilities - Data Portal Navigator
sadefa
Post by sadefa » Tue Dec 13, 2011 11:03 pm
amtm wrote:Eplan 2.1 to work please. Crack that this post does not work. (h)
Someone just used google translate to post here.
The answer is to be found in previous posts and it works.
i have a problem when i choose new project Eplan give message to me that " The function 'Restore project' cannot be performed because of the settings defined in the rights management module."
and i can't start new project
I guess you played with the settings of the user rights settings. Just copy the original MD file that can be found in the /Users folder to the company folder directory under /Users.
It will work this way.
erkut13
Post by erkut13 » Wed Jan 11, 2012 10:49 am
sadefa wrote:For everyone that have ever had a problem with EPLAN Emulators.
Regards
Hi sadefa;
I did everthing you wrote but eplan is not working !
it says : The program 'EPLAN' cannot be started with this license.
amtm
Post by amtm » Wed Jan 11, 2012 7:20 pm
I have the same problem, does not work. (h)
grmm
Post by grmm » Thu Jan 12, 2012 6:19 pm
Instructions:
1. Disable AV
2. Download the rar archive from http://www.filesonic.com/file/2216098681
3. Set UAC to minimal. (User account control)
4. Install EPLAN 2.1
5. Copy the file that is into the common folder from the rar and paste it to C:\Users\Public\EPLAN\COMMON.
6. Go to control panel. There you will find licence client. Right click and click change. There you can disable the HL drivers.
7. Install the new drivers (provided into the rar - HASPUserSetup.exe)
8. Add the data to the registry by running 5189.reg from the archive
9. Go to the Release folder and then to x32 or x64 (depending from your PC and OS) and run install.cmd
10. Run dseo13b.exe and enable test mode.
11. Restart your computer
12. Disable AV, copy multikey.sys to c:\privremena_mapa\multikey.sys and Run dseo13b.exe and sign a file. The address of the file is c:\privremena_mapa\multikey.sys!!!!!!
13 copy c:\privremena_mapa\multikey.sys to C:\Windows\System32\Drivers\multikey.sys
14. Restart your computer
15. NEW HARD...UPDATING.....
16. EPLAN 2.1 is running (100%)
Don't forget !!!!!!
Exclusions in AV add C:\Windows\System32\drivers\multikey.sys !!!!!!!!!!!!!!!!!!
eando
Post by eando » Tue Jan 24, 2012 9:56 pm
Is it possible to run Eplan P8 2.1 with another different EGF file than the provided along with the crack (SN-U1006.EFG) ?
With the crack for earlier versions of P8, this was possible to be done...
tron
Post by tron » Tue Jan 31, 2012 9:14 am
Due to the closure of Megaupload.com, FileSonic has deaktivate his filsharing system. Can you upload your files to another Host like share-online.biz, rapidshare.com, uploaded.to ... thank you in advance
All sharing functionality on FileSonic is now disabled. Our service can only be used to upload and retrieve files that you have uploaded personally.
If this file belongs to you, please login to download it directly from your file manager.
iyalav
Post by iyalav » Wed Feb 01, 2012 12:36 pm
The rar arciheves which sadefa uses on his video and on the this link http://eplan-eb2.ys168.com/ are different. The reg keys and the licence files are different i think. And the filesonic's link is dead. I have tried many times different combination also with old versions licences but it does not work.
So can anybody reupload the archieve that on the sadefa's video?
manepipoca
Post by manepipoca » Tue Feb 14, 2012 1:46 pm
Hi!
With x32 and WinXP this works fine:
0-Disable AV;
1-Download this file: https://rapidshare.com/files/4276816903/p8_2_1.rar;
2-Install Eplan P8 2.1;
3-Copy the file "SN-U38269.EGF" into "C:\Documents and Settings\All Users\Application Data\EPLAN\Common" (Depends OS);
4-Registry the file "SN-U38269.reg" simply click on it;
5-Run "install.cmd", are in the folder x32 or x64 of the downloaded file;
6-Run "dseo13b.exe", click on next, and check the option "Enable Test Mode", click on next. Choose "Exit" and click on Next;
7-Restart your computer;
8-Disable AV;
9-Run "dseo13b.exe", click on next, and check the option "Sign a System File" click on next, put this path: "C:\Windows\System32\Drivers\multikey.sys" and confirm. Choose "Exit" and click on Next;
10-Restart your computer;
11-Run Eplan 2.1
Best Regards!
arifnihat
Post by arifnihat » Thu Feb 16, 2012 3:47 pm
Hey guys pls help me.
I have Eplan P8 2.0 SP1 Build 4831. And i cracked with http://eplan-eb2.ys168.com/ crack.
When i want to create pages after 10 page this messages has shown.
"The maximum number of logic pages has been reached! The page cannot be created"
Please help!
BULBO
Post by BULBO » Mon Feb 20, 2012 9:30 pm
I can't understand where is the problem.I worked fine with 2.0.9 but when I installed the 2.1.4 licenses do not work.Where is the problem? Can I download the files for crack? Help me Safeda
seb3489
Post by seb3489 » Sat May 26, 2012 1:57 am
I have a problem with the installation of EPLAN.
I succeed to install EPLAN 2.0 on one laptop but I don't achieve to have a good licence for the others computers.
I read and read the tutorial but I don't succeed.
When I go to control pannel, to check peripheric manager (Gestionnaire des périphériques), I find virtual drive but it isn't installed correctly
How can I delete all? Driver, ... for begin with a clean installation... Tomorrow, I will try to install 2.1 but I think that it won't work.
Thx for your help.
washa_rednecks
Post by washa_rednecks » Fri Jul 13, 2012 10:29 pm
please, is there somebody, how can send me a link for working patch on version 2.1.6? Please?
I have 2 diferent patches, but it doesn't work.
I'm trying it allday without success.
Please, do you have working version with patch/crack?
Thank you very much, Washa
