[?]: Promis.e v8i for microstation
Тools, Elcad, Eplan, ...
djcatalyst
Post by djcatalyst » Fri Apr 22, 2011 10:44 am
HI
I found some ftp link with all installation files of Promis.e v8i
but without crack for license
ftp://ftp.archwayftp.com/promise
please ,can some one here fix ore create a crack for the program ?
(h) thx
Linkinx64
Re: [?]: Promis.e v8i (for microstation) link.CRACK NEEDED
Post by Linkinx64 » Sun Apr 24, 2011 9:28 am
djcatalyst wrote:can some one here fix ore create a crack for the program ?
I can. http://depositfiles.com/files/exslsi774
djcatalyst
Post by djcatalyst » Mon Apr 25, 2011 8:57 pm
thanx a lot for crack Linkinx64
i have only to short questions .
1. how i active it or where i should to put these .dll files ?
2. are these files working with AUTOCAD version of promis.e ? ( if not i will looking for promis.e for autocad and i will upload it for your expert look).
thanx anyway you r the genious.
Linkinx64
Post by Linkinx64 » Tue Apr 26, 2011 6:36 am
djcatalyst wrote:1. how i active it or where i should to put these .dll files ?
Copy Bentley folder from archive over existing folder (default: C:\Program Files\Bentley in 32-bit Windows version, C:\Program Files (x86)\Bentley in 64-bit Windows version). Overwrite files on prompt.
djcatalyst wrote:2. are these files working with AUTOCAD version of promis.e ?
I don't know what is the "AUTOCAD version of Promis.e". These files are intended for the products I donwloaded by the link you provide at 22 of April (Promis.e and PowerDraft).
djcatalyst
Post by djcatalyst » Wed Apr 27, 2011 3:47 pm
hello
Linkinx64
as i promissed , i found link with PROMIS.E for Aoutocad :
http://www.ndocs.ru/Compuware/Bntl/Bent ... utoCAD.zip
i think the link is a litle bit low it disconnected couple of times , but maybe you could downlod the pro.
and it wroten that is russian version , but i think it can be the multilanguage.
if you succeed to download it , please try to create some crack for it.
thnx a lot . (oo) (tyou)
Linkinx64
Post by Linkinx64 » Thu Apr 28, 2011 5:43 am
The service pack 2 located by the link is not intended for Promis.e v08.11.07.146 (for AutoCAD):
More troubles happened after install. Autocad is crashing after I try to launch Promis.e v8i for AutoCAD:
Maybe it because I've cancelled the Promise's SQL instance for SQL Server...
I'm only able to make a "blind" crack now: by comparison of original and cracked versions of Bentley.liclib.dll for the PowerDraft (see linkz in post above).
3 very similar parrterns found and edited but operability of the software can't be checked. I can't install MS SQL because I have working SQL instance that is used for my work.
So, the operability test is up to you: http://depositfiles.com/files/lr3xukna7
P.S> Crack for Promis.e v8i Microstation should also work with Promis.e for Acad. Because Bentley.liclib is copying to the same folder during install...
djcatalyst
Post by djcatalyst » Thu Apr 28, 2011 6:47 am
oh,
thanx alot for your huge work Linkinx64
i will try totest it .
thanx again for everything
(oo)
mytom123
Post by mytom123 » Thu Apr 28, 2011 3:29 pm
Hi
I have test software with license but after start software (promis-e for autocad) , it display some error like this:
"Command: (command "LoadEctEcad")
LoadEctEcad ; error: Exception occurred: 0xC0000005 (Access Violation)
Enter BACKSPACE to interrupt script.
nil
Command: (if (= InitOK "no") (command "ECAD_EXEC_SETUP"))
and I checked in the license management tool, it display :
Microstation Power Draft : Trial expires in 26 days
1777 : Trial expires in 26 days.
Could you see it or may be I did something wrong to apply license.
Thanks and regards.
Linkinx64
Post by Linkinx64 » Fri Apr 29, 2011 4:25 am
mytom123 wrote:and I checked in the license management tool, it display :
I know it. But after 26 days nothing will happens.
Check it: set windows date 1 month forward and try to launch PowerDraft. License manager will show "expired" but PowerDraft continue work.
mytom123 wrote:I have test software with license but after start software (promis-e for autocad) , it display some error like this:
nil
Does it happened after you applied the "license"?
I will check for this issue if so. Which AutoCAD version you use?
mytom123
Post by mytom123 » Fri Apr 29, 2011 7:25 am
Hi
It was happened after I start program, and already add license.
My Cad software is autocad 2007.
Brgds.
djcatalyst
Post by djcatalyst » Fri Apr 29, 2011 9:33 am
please guys help
ive tried to download autocad version from link what i found :
( http://www.ndocs.ru/Compuware/Bntl/Bent ... utoCAD.zip )
but it all the time disconnected :(
if some one of you succeed to comple the download please upload it to another link so i will download it completley
thx alot
djcatalyst
Post by djcatalyst » Fri Apr 29, 2011 2:52 pm
ohhh
thanks alot BROTHERS.
you saved my ass//
Linkinx64
Post by Linkinx64 » Sat Apr 30, 2011 4:55 am
Hi
nil
This error message appears disregarding to the crack. Means, without crack it appears too.
This is an internal Promis.e or AutoCAD 2007 error, have nothing to do with my crack.
Test configuration: OS Windows XP Pro SP3 + AutoCAD 2007 + Promis.e v8i for AutoCAD v08.11.07.146 + crack http://depositfiles.com/files/lr3xukna7 - all works.
djcatalyst
Post by djcatalyst » Sat Apr 30, 2011 1:03 pm
hey guys
how i schould open these files : Bentley_Promise_v8i_for_AutoCAD.crc , and the others
please help
.crc file ?
how i extract it?
thx
mytom123
Post by mytom123 » Sat Apr 30, 2011 4:50 pm
Hi
You can use some software to combine files, like total commander or others.
After that you can install this package.
Brgds.
djcatalyst
Post by djcatalyst » Sat Apr 30, 2011 7:27 pm
ohh
im totaly confused , ine tried to do something with total comander but with no results.
please can you explain me how can i extract all these filese to one folder with the program?
sorrry
thx
mytom123
Post by mytom123 » Sun May 01, 2011 3:20 am
Hi
All files in one folder, choose 1 file .Ex: The left window display source files, the right window display the destination after merge.
Merge with total commander menu File > Combine
After combine 001+002+...+... to one archive file you can unpack it.
Brdgs
djcatalyst
Post by djcatalyst » Sun May 01, 2011 8:33 pm
thx
i did it as you explained , it works
(clap)
Linkinx64
[LINK]: promis.e v8i for AutoCAD x64/x86 [08.11.08.22]
Post by Linkinx64 » Sat May 28, 2011 5:49 pm
64-bit edition of promis.e v8i for AutoCAD now available:
http://www.filefactory.com/file/ce8309d ... 22_x64.rar
308Mb
This version require 64-bit edition of AutoCAD (2007 through 2010).
32-bit edition:
http://www.filefactory.com/file/ce831d2 ... 22_x86.rar
312Mb
baquyen
Post by baquyen » Wed Jan 11, 2012 5:53 am
Linkinx64
Post by Linkinx64 » Thu Jan 12, 2012 10:52 am
I have more recent versions of promis.e for AutoCAD than your:
promis.e for AutoCAD v08.11.10.66 [x64]:
http://www.filefactory.com/file/2cvlaeh ... 66_x64.rar
promis.e for AutoCAD v08.11.10.66 [x86]:
http://www.filefactory.com/file/2gnc4ez ... 66_x86.rar
promis.e for AutoCAD v08.11.11.18 [x64] (w/o prerequisites):
http://www.filefactory.com/file/45xt1u5 ... .part1.rar
http://www.filefactory.com/file/21srsg7 ... .part2.rar
http://www.filefactory.com/file/1b6j48w ... .part3.rar
promis.e for AutoCAD v08.11.11.18 [x86] (w/o prerequisites):
http://www.filefactory.com/file/6kqawwj ... .part1.rar
http://www.filefactory.com/file/2i3girc ... .part2.rar
http://www.filefactory.com/file/1oqy3ci ... .part3.rar
Installation order:
1. Install AutoCAD (supported versions: 2007 - 2011, not included).
2. Download a proper version of promis.e for AutoCAD.
3. Install Prerequisites (see prerequisites folder).
4. Install Promis.e (setup folder): x86 for 32-bit version of AutoCAD, x64 for 64-bit version of AutoCAD.
5. Copy file from crack folder to the proper place.
baquyen
Post by baquyen » Sun Jan 15, 2012 5:27 pm
Linkinx64, thanks! (tyou) (gpost)
I just install 32 bit version.
cy4102249
Post by cy4102249 » Thu Nov 22, 2012 8:20 pm
hello,Linkinx64,
the links does not workig....
Linkinx64
Post by Linkinx64 » Fri Nov 23, 2012 4:38 am
cy4102249 wrote:hello,Linkinx64,
I can't believe it...
vamosnelson
Post by vamosnelson » Sun Dec 15, 2013 5:50 pm
Anybody can provide a link of Promis.e of first post ( compatible with medicine and NOT autocad version)?
zrq1977
Re: [?]: Promis.e v8i for microstation
Post by zrq1977 » Tue Dec 24, 2013 2:19 pm
i try it, but its give me message to inseret other file location....
any one can help, by providing the set-up program for promis-e (SELECT Series 7) with crack? for 64 bit.
thes0002002
Post by thes0002002 » Wed Dec 25, 2013 1:40 pm
Hello Linkinx64,
Can you check the link of Promise series 5?
Thank you so much!
Linkinx64
Post by Linkinx64 » Fri Dec 27, 2013 7:43 am
Checked. Re-uploaded.
thes0002002
Post by thes0002002 » Sat Dec 28, 2013 9:10 am
Hello Linkinx64,
Thank you very much!
kiemars86
Post by kiemars86 » Thu Jan 08, 2015 2:08 pm
hi all,
I have a promis-e v8i (select serial 7), but without crack.
Please can some on fix it.
Thanks!
