[?+]: How activate automation studio v3.0 B&R ?
другие контроллеры
technofreek
Re: [?+]: How activate automation studio v3.0 B&R ?
Post by technofreek » Wed Apr 09, 2014 10:50 am
bozob wrote:crack for AS_3.00.90.0027
changes in PG.exe
Offset 2B410 - cc 06 00 00 01 eb 30 6a 00 8d 8d 20 f2 ff ff ff - eb to 75
Offset 2B5D0 - 42 00 e8 cb 19 08 00 83 c4 18 89 85 1c f2 ff ff - to 90 90 90 90 90
Offset 2BFD0 - 70 FF D0 83 BD C4 F0 FF FF 00 74 62 33 C9 66 89 - to 90 90
Thanks a ton bozob!! You are a lifesaver! (suc) (suc) (suc)
Those who want to upgrade to AS_3.00.90.0027; download the upgrade from http://www.br-automation.com/en-in/down ... ersion=all
Also your correction is typed incorrectly ; it should be as follows
Offset 2B410 - cc 06 00 00 01 75 30 6a 00 8d 8d 20 f2 ff ff ff - 75 to eb
Bartasek
Post by Bartasek » Wed Apr 09, 2014 8:16 pm
If anyone can help me to crack pg.exe file for AS_2.6.0.7?
What you need from my to do this, serial?
Many thank's.
markento
Post by markento » Mon Apr 28, 2014 5:03 pm
Could anybody share B&R AS 2.7.0.X install, if possible with cracked pg.exe.
SolarSoul
Post by SolarSoul » Tue Jul 01, 2014 6:47 am
If this can help somebody, for AS 3.0.90.24 SP06 the pg.exe should be modified as follow:
0x2b415 | 75 | must be replaced by | eb |
0x2b5d3 | e8 cb 19 08 00 | must be replaced by | 90 90 90 90 90 |
0x2bfda | 74 62 | must be replaced by | 90 90 |
It took me less than 1 hour to find which ones I needed to correct. So I guess it's not more difficult for any other version.
You're welcome... (thnx)
miri56
Post by miri56 » Thu Jul 03, 2014 5:38 am
hi
please upload b&r automation studio 4 and crack
technofreek
Post by technofreek » Fri Jul 04, 2014 8:30 am
markento wrote:Could anybody share B&R AS 2.7.0.X install, if possible with cracked pg.exe.
Hello All;
I am also in requirement of the crack for B&R AS 2.7.0.X install.
(tyou)
Markento, you can download it directly from B&R website
http://www.br-automation.com/downloads_ ... 07_Eng.exe
ppp
Post by ppp » Fri Jul 04, 2014 9:14 am
SolarSoul wrote:.....
Your crack is not full.
Only for offline mode (pg.exe).
For online used pviman.exe.
SolarSoul
Post by SolarSoul » Fri Jul 04, 2014 9:28 am
It was my first try... Do you know any informations about the pviman.exe? 'cause I saw nothing in this post...
ppp
Post by ppp » Fri Jul 04, 2014 10:31 am
SolarSoul
Post by SolarSoul » Tue Jul 08, 2014 9:27 am
:oops: Can I ask you if there is any information about how to "fix" this issue? I mean, is there any example of an other version or this version. So I can try if I can modify this file.
I'm not sure if I'm clear enough... I need some help to do a complete "crack" tutorial... Thx (tyou)
Amidamaru
Post by Amidamaru » Fri Jul 18, 2014 9:17 am
Hi! I have a problem, need activate Automation Studio v2.6 SP2. Somebody know how do it this? Help me please!
dracog71
Post by dracog71 » Sat Oct 11, 2014 12:27 am
Hi everyone!.. need AS V 2.4 !.. in the B&R page it's only de "upgrade" donload. not the entire aplicattion... if someone has the Automation Studio V2.4 "demo2 i can build a crack the "pg" of that version.. so, we all win.. plz help me.. i really need that AS !!
mohdabshr
Re: [?+]: How activate automation studio v2.6 B&R ?
Post by mohdabshr » Sun Dec 28, 2014 6:11 am
hello please I need help for How activate automation studio v2.6 B&R ? or if some body have crack for pg.exe for this version to share.
George SM
Post by George SM » Fri Jan 16, 2015 3:18 pm
Dear friends,
does anybody have an info how to activate Deutsch version of Automation Studio?
I use 3.0.90.20 SP02 English version (activated) In the zip file which I have downloaded there was only pg.exe for English version!
English for me is good but my boss doesn't speak English. He needs Deutsch version.
We also use English version 2.6.0.14 SP04. It is not activated.
We will be glad to get any activated Deutsch version. It is better newer version!
Thanks a lot!!!!!!
__________________________________________________________________________________________________________________
Коллеги привет!
кто нибудь знает как активировать немецкую версию Automation studio?
У меня есть скаченная 3.0.90.20 SP02. В комплекте был pg.exe только для английской версии.
Для меня английской версии достаточно, но мой босс плохо понимает английский и ему нужна немецкая версия.
Мы также пользуемся trial версией 2.6.0.14 SP04 (английская).
Мой босс был бы рад любой активированной немецкой версии. Желательно поновее.
Большое Спасибо!
Hommit
Post by Hommit » Wed Jan 28, 2015 10:47 am
Hello
Can you tell what i should look for with IDA to crack any version? Whats is their name? As i understand, it is address of some functions and result of register check.
How the crack is made? Ty.
Here is setups i found for versions 2.7.0.7, 3.0.90.21, 4.0.14.208 and 4.1.4.402
http://entas.ru/content/automation-studio
(if you going to install help upgrade 4.1.5 for AS4.1.4, unpack zip, download help upgrade from official site and replace install file in \Setups\AddOn folder - for whatever reason my version refused to install it from Upgrades menu, this way it install correctly with main installation process)
elektronikmuh
Post by elektronikmuh » Thu May 21, 2015 7:34 pm
Do you have B&R Automation Studio v4.2 cracked pg.exe?
muh.elektronik@gmail.com
Last edited by elektronikmuh on Fri Jan 01, 2016 6:49 pm, edited 2 times in total.
rotkiv
Post by rotkiv » Sat Aug 22, 2015 6:31 am
Need AS4 too (((.
zaplatin
Post by zaplatin » Tue Mar 22, 2016 12:08 pm
ol_zy wrote:If it intersting so
Correct modification for AS_3.00.90.0020
Try the following adjustments
Code:
Using HexEditor Change the following
Offset 2AF98 75 to EB
Offset 2B2A3 E8 6B 14 08 00 to 90 90 90 90 90
Offset 2bc9b 74 62 to 90 90
90h = NOP
I am testing it is work.
How long it working? I cant found WINHEX good and I had use http://www.ultraedit.com/
ol_zy
Post by ol_zy » Sat Jun 11, 2016 5:08 pm
Code:
90h = NOP
It's work till now so you can use it any time.
Is somebody have activation for v4.2.4.149?
malek
Post by malek » Tue Aug 16, 2016 12:25 am
Приветствую!
Прошу помощи в поиске старых версий Automation Studio 2.5.1 или 2.5.3. Все прежние ссылки уже не работают.
jevticel
Post by jevticel » Mon Sep 05, 2016 1:42 pm
Can amnyone upload Automation_Studio older version,2.2,2.3,2.6?
Because my project is old and i can't open with V2.7 and V3.0.90.
Please for help!
Thanks!
Morpheus_11
Post by Morpheus_11 » Tue Mar 07, 2017 11:06 pm
I'm new to this forum, I unexpectedly have to work with B&R PLCs the next months and I really need B&R automation studio version 3.0.90 for my work. Is there anyone who has that software and can upload it anywhere for me? would really help.
Also, if there is already any crack for this version, I would also very appreciate that, but first and for most I need the software.
ol_zy
Post by ol_zy » Wed Mar 08, 2017 5:33 am
Morpheus_11 wrote:Hello,
Just read this topic http://entas.ru/content/automation-stud ... qt-maintab
George SM
Re: [?+]: How activate automation studio v4.Х.Х B&R ?
Post by George SM » Wed May 17, 2017 2:17 pm
If somebody has activation for v4.Х.Х - please share!
Thank you in advance!
Если у кого нибудь есть кряк на v4.Х.Х - поделитесь, пожалуйста, добрые люди!
Спасибо!
digetp
Post by digetp » Sat May 20, 2017 9:16 pm
Hi is what someone has codes to change to enable AS 3.0.90.21 in pg.exe ? thanks
chackerhz
Post by chackerhz » Mon Aug 07, 2017 1:32 am
hi:All
Could you help me to crack this two files as AS4.0 (http://pan.baidu.com/s/1c13dzQK ) and share some method with picture?
Thank you very much
chackerhz
umaralhasni
Post by umaralhasni » Sat Aug 26, 2017 8:04 am
how can i change the security mode TRIAL to RUNTIME on PVI Monitor
B&R V3.0
please help
proeng
Post by proeng » Tue Oct 31, 2017 9:27 am
umaralhasni wrote:Image
B&R V3.0
please help
I need,please hhelp.
ppp
Post by ppp » Fri Nov 03, 2017 11:43 am
jevticel wrote:Hello,
Please for help!
Thanks!
Automation Studio v2.2.1 (with crack offline and online)
http://www63.zippyshare.com/v/fZ3H00Fv/file.html
http://www63.zippyshare.com/v/xbWw9j4t/file.html
proeng
Post by proeng » Fri Nov 10, 2017 12:37 pm
proeng
Post by proeng » Mon Jan 08, 2018 11:48 am
Help me please my friends. I am in a difficult situation. (h) (oo) :(
(old or new version PVI Manager)
Regards
pedritocar
Post by pedritocar » Tue Jan 23, 2018 9:03 pm
Hello!
I am a student in electronic and I would like to use B&R Automation Studio for my school project.
Can you help me to get this software with the crack?
Thank you in advance (suc)
cccbbbaaa
Post by cccbbbaaa » Tue Apr 30, 2019 12:46 pm
Key generator for AS version 2, 3, 4 :
https://we.tl/t-xlWEMFwtGc
ol_zy
Post by ol_zy » Wed May 01, 2019 10:25 am
Don't work for 4,2 version.
Generated secondary code is invalid :(
lisnuk
Post by lisnuk » Tue May 14, 2019 7:47 am
Transfer deleted, reload please ! (tyou)
engrmunir786
Post by engrmunir786 » Thu May 16, 2019 5:56 pm
Dear experts
i have downloaded B&R 4.2 new version from below mention link
https://www.br-automation.com/en/downlo ... redirect=1
how to activate it..
cccbbbaaa
Post by cccbbbaaa » Thu May 16, 2019 7:27 pm
Try this link:
https://we.tl/t-BraeFEiXkc
Choose Automatio Studio (Legacy)
B&R serial number: 12345678901
lisnuk
Post by lisnuk » Wed May 22, 2019 8:16 am
Thank you (oo)
chriss_russell
Post by chriss_russell » Thu May 30, 2019 2:37 pm
hi can you reupload that keygen for br 2 3 4 please
chriss_russell
Post by chriss_russell » Thu May 30, 2019 2:46 pm
please reupload
Dinda
Post by Dinda » Wed Jun 05, 2019 6:41 pm
asif25
Post by asif25 » Sat Jun 22, 2019 7:02 am
Please for help!
Thanks!
Hope so you are doing fine
I need B&R Automation Studio V2.2. Can you please help about it. The above links are expired. Kindly attach recent link that'll be great help.
ilcalmo
Post by ilcalmo » Fri Jul 05, 2019 9:24 pm
https://my-files.ru/v43p62
file has been deleted!
Could someone upload again?
Thank you.
Hammer2
Post by Hammer2 » Tue Jul 30, 2019 6:45 am
I have found it on the following site:
https://anonfile.com/T37dx7t5ne/AS_code_v4.xx_rar
It doesn't seem to work for latest v4.6 as AS does not take legacy license code types anymore (like 12345678901) but only in format XXXXX-XXXXX-XXXXX-XXXXX-XXXXX
