[?]: WinCC v7.0 demo mode ???
knetknet
Post by knetknet » Thu Jun 04, 2009 6:58 am
hi friend wincc v7.0 is in demo mode can anybody help me??
i am sending all the files you need below...
this is the licence.log file
06/04/2009 09:34:29 Control Center - Demo Mode ConfigurationSystem enabled -
06/04/2009 09:34:29 NoLicense CS | Name of License = A9WRC?0700 | Text of License = Simatic WinCC RC (Runtime + Development) | Exists = No |
06/04/2009 09:34:29 InitLicense CS | AppName = AppCS:Mcp | CycleCheck = yes | NameForMessageBox =  | Name of License = A9WRC?0700 | Text of License = Simatic WinCC RC (Runtime + Development) |
06/04/2009 09:34:31 NoLicense ED | Name of License = A9WRC?0700 | Text of License = Simatic WinCC RC (Runtime + Development) | Exists = No |
06/04/2009 09:34:31 Control Center - Demo Mode Editors enabled -
06/04/2009 09:34:31 InitLicense ED | AppName = AppEd:Mcp | CycleCheck = own | NameForMessageBox =  | Name of License = A9WRC?0700 | Text of License = Simatic WinCC RC (Runtime + Development) |
06/04/2009 09:34:33 Control Center - Demo Mode ConfigurationSystem enabled -
06/04/2009 09:34:44 Control Center - Demo Mode Runtime enabled -
06/04/2009 09:34:44 NoLicense RT | Name of License = A9WRT?0700 | Text of License = Simatic WinCC RT (Runtime) | Exists = No |
06/04/2009 09:34:44 InitLicense RT | AppName = AppRT:Mcp | CycleCheck = yes | NameForMessageBox =  | Name of License = A9WRT?0700 | Text of License = Simatic WinCC RT (Runtime) |
06/04/2009 09:34:47 InitLicense RT | AppName = AppRT:TlgASO | CycleCheck = yes | NameForMessageBox =  | Name of License = SIFCY9WTGX06024 | Text of License = WINCC Arch (4000000) | Relevant Limit = 0004246500 |
06/04/2009 09:34:49 Control Center - Demo Mode Runtime enabled -
06/04/2009 09:42:19 ExitLicense RT | AppName = AppRT:Mcp | CycleCheck = yes | Name of License = A9WRT?0700 | Text of License = Simatic WinCC RT (Runtime) |
06/04/2009 09:42:19 ExitLicense RT | AppName = AppRT:TlgASO | CycleCheck = yes | Name of License = SIFCY9WTGX06024 | Text of License = WINCC Arch (4000000) |
06/04/2009 09:42:28 ExitLicense CS | AppName = AppCS:Mcp | CycleCheck = yes | Name of License = A9WRC?0700 | Text of License = Simatic WinCC RC (Runtime + Development) |
06/04/2009 09:42:28 ExitLicense ED | AppName = AppEd:Mcp | CycleCheck = own | Name of License = A9WRC?0700 | Text of License = Simatic WinCC RC (Runtime + Development) |
06/04/2009 09:42:40 InitLicense CS | AppName = AppCS:Mcp | CycleCheck = yes | NameForMessageBox =  | Name of License = A9WRC?0700 | Text of License = Simatic WinCC RC (Runtime + Development) |
06/04/2009 09:42:41 NoLicense ED | Name of License = A9WRC?0700 | Text of License = Simatic WinCC RC (Runtime + Development) | Exists = No |
06/04/2009 09:42:41 Control Center - Demo Mode Editors enabled -
06/04/2009 09:42:41 InitLicense ED | AppName = AppEd:Mcp | CycleCheck = own | NameForMessageBox =  | Name of License = A9WRC?0700 | Text of License = Simatic WinCC RC (Runtime + Development) |
06/04/2009 09:42:43 Control Center - Demo Mode ConfigurationSystem enabled -
this is the authorinformation.inf
2009-06-04 09:36:18
License   			installed			needed			to install			Product
SIFLA9WRT10602			Yes  [TOSHIBA]		Yes      			No        			WinCC Runtime 128 PowerTags 512 Archive Tags
SIFLA9WRC10602			Yes  [TOSHIBA]		Yes      			No        			WinCC Runtime+Configuration 128 PowerTags 512 Archive Tags
SIFCY9WTGX06023			Yes  [TOSHIBA]		Yes      			No        			WinCC Option Archive (Count Relevant)
SIFLA9WLB10602			Yes  [TOSHIBA]		No      			No        			WinCC Load Balancing
SIFLA9WC170602			Yes  [TOSHIBA]		No      			No        			Channel SIMATIC S5 Ethernet TF
A9SNEL90			Yes  [TOSHIBA]		No      			No        			Channel Industrial Ethernet Softnet - S7 Lean
SIFLA9WC180602			Yes  [TOSHIBA]		No      			No        			Channel SIMATIC S5 Ethernet Layer 4
SIFLA9WC190602			Yes  [TOSHIBA]		No      			No        			Channel SIMATIC TI Ethernet Layer 4
SIFLA9WSEC0602			Yes  [TOSHIBA]		No      			No        			Server
SIFLA9WRT20602			Yes  [TOSHIBA]		No      			No        			WinCC Runtime 256 PowerTags 512 Archive Tags
SIFLA9WRC20602			Yes  [TOSHIBA]		No      			No        			WinCC Runtime+Configuration 256 PowerTags 512 Archive Tags
A3WCL112			Yes  [TOSHIBA]		No      			No        			Channel SIPART
SIFLA9WRT30602			Yes  [TOSHIBA]		No      			No        			WinCC Runtime 1024 PowerTags 512 Archive Tags
SIFLA9WRC30602			Yes  [TOSHIBA]		No      			No        			WinCC Runtime+Configuration 1024 PowerTags 512 Archive Tags
SIFLA9ARC10602			Yes  [TOSHIBA]		No      			No        			WinCC Audit RC
SIFLA9ART10602			Yes  [TOSHIBA]		No      			No        			WinCC Audit RT
SIFLA9WOP10602			Yes  [TOSHIBA]		No      			No        			WinCC Option Connectivity Pack
SIFLA9WCL50602			Yes  [TOSHIBA]		No      			No        			Channel Allen Bradley Serial DF1
A7TMCS50			Yes  [TOSHIBA]		No      			No        			Channel TELEPERM M,0, CS275
SIFLA9WRT40602			Yes  [TOSHIBA]		No      			No        			WinCC Runtime 64K PowerTags 512 Archive Tags
SIFLA9WRC40602			Yes  [TOSHIBA]		No      			No        			WinCC Runtime+Configuration 64K PowerTags 512 Archive Tags
SIFLA9WOP20602			Yes  [TOSHIBA]		No      			No        			WinCC Option Connectivity Station
SIFLA9WVC10602			Yes  [TOSHIBA]		No      			No        			DataMonitor 3 Clients
SIFLA9WCL60602			Yes  [TOSHIBA]		No      			No        			Channel PROFIBUS FMS
SIFLA9WRT50602			Yes  [TOSHIBA]		No      			No        			WinCC Runtime 8K PowerTags 512 Archive Tags
SIFLA9WRC50602			Yes  [TOSHIBA]		No      			No        			WinCC Runtime+Configuration 8K PowerTags 512 Archive Tags
SIFLA9WOP30602			Yes  [TOSHIBA]		No      			No        			OpenPCS 7 Station / WinCC
SIFLA9WVC20602			Yes  [TOSHIBA]		No      			No        			DataMonitor 10 Clients
SIFLA9WSPA0602			Yes  [TOSHIBA]		No      			No        			ProAgent WinCC
SIFLYSMSR00700			Yes  [TOSHIBA]		No      			No        			Maintenance Station Runtime
SIFLA9WRT60602			Yes  [TOSHIBA]		No      			No        			WinCC Runtime 100K PowerTags 512 Archive Tags
SIFLA9WRC60602			Yes  [TOSHIBA]		No      			No        			WinCC Runtime+Configuration 100K PowerTags 512 Archive Tags
SIFLA9WOP40602			Yes  [TOSHIBA]		No      			No        			WinCC Option Connectivity Station
SIFLA9WVC30602			Yes  [TOSHIBA]		No      			No        			DataMonitor 25 Clients
SIFLA9WSRD0602			Yes  [TOSHIBA]		No      			No        			Redundancy
SIFLA9WCL80602			Yes  [TOSHIBA]		No      			No        			Channel Modbus Serial
SIFLA9WRT70601			Yes  [TOSHIBA]		No      			No        			WinCC Runtime 256K PowerTags 512 Archive Tags
SIFLA9WRC70601			Yes  [TOSHIBA]		No      			No        			WinCC Runtime+Configuration 256K PowerTags 512 Archive Tags
SIFLA9WVC40601			Yes  [TOSHIBA]		No      			No        			DataMonitor 50 Clients
SIFLA9WC200700			Yes  [TOSHIBA]		No      			No        			Channel Mitsubishi FX
SIFLA9WCL90700			Yes  [TOSHIBA]		No      			No        			Channel SIMATIC S5-PMCL2
SIFLA1STOP0102			Yes  [TOSHIBA]		No      			No        			SIMATIC HMI StoragePlus Server
SIFLA9WRT80600			Yes  [TOSHIBA]		No      			No        			WinCC Runtime 150K PowerTags 512 Archive Tags
SIFLA9WRC80600			Yes  [TOSHIBA]		No      			No        			WinCC Runtime+Configuration 150K PowerTags 512 Archive Tags
SIFLA9LB100600			Yes  [TOSHIBA]		No      			No        			WinCC Load Balancing step-up
SIFLA9WSN10600			Yes  [TOSHIBA]		No      			No        			WebNavigator 3 Clients
SIFLA9WDC10600			Yes  [TOSHIBA]		No      			No        			WinCC WebDiag Clients
SIFLA9WC210600			Yes  [TOSHIBA]		No      			No        			Channel Mitsubishi MELSEC A
SIFLA9WC100600			Yes  [TOSHIBA]		No      			No        			Channel SIMATIC S5-PMCH1
SIFLA9IDB10602			Yes  [TOSHIBA]		No      			No        			Industrial DataBridge 128 Tags
SIFLA9WSN20602			Yes  [TOSHIBA]		No      			No        			WebNavigator 10 Clients
SIFLA9WDS10602			Yes  [TOSHIBA]		No      			No        			WinCC WebDiag Server
SIFLA9WC220602			Yes  [TOSHIBA]		No      			No        			Channel SIMADYN D PMC Ethernet Layer 4
SIFLA9WC110602			Yes  [TOSHIBA]		No      			No        			Channel Applicom Multi Protocol Interface
SIFLA9WARC0401			Yes  [TOSHIBA]		No      			No        			User Archives
SIFLA9ACC10602			Yes  [TOSHIBA]		No      			No        			WinCC Audit ChangeControl RC
SIFLA9IDB20602			Yes  [TOSHIBA]		No      			No        			Industrial DataBridge 512 Tags
SIFLA9WSN30602			Yes  [TOSHIBA]		No      			No        			WebNavigator 25 Clients
SIFLA9WC230602			Yes  [TOSHIBA]		No      			No        			Channel Omron C-Series HostLink
SIFLA9WC120602			Yes  [TOSHIBA]		No      			No        			Channel GE Fanuc SNP SNPX
SIFLA1WPC10602			Yes  [TOSHIBA]		No      			No        			Basic Process Ctrl
SIFLA9IDB30602			Yes  [TOSHIBA]		No      			No        			Industrial DataBridge 2048 Tags
SIFLA9WSN40602			Yes  [TOSHIBA]		No      			No        			WebNavigator 50 Clients
SIFLA9WOIC0602			Yes  [TOSHIBA]		No      			No        			Internet Connection
SIFLA9WC240602			Yes  [TOSHIBA]		No      			No        			Channel PROFIBUS DP
SIFLA9WC130602			Yes  [TOSHIBA]		No      			No        			Channel GE Fanuc Ethernet
SIFLA1WPC20602			Yes  [TOSHIBA]		No      			No        			Advanced Process Ctrl
SIFLA9IDB40602			Yes  [TOSHIBA]		No      			No        			Industrial DataBridge 10.000 Tags
SIFLA9WC250602			Yes  [TOSHIBA]		No      			No        			Channel SIMATIC 505 TCPIP
SIFLA9WC140602			Yes  [TOSHIBA]		No      			No        			Channel Allen Bradley DH DH+ DH485
SIFLA1WPC30602			Yes  [TOSHIBA]		No      			No        			Storage
SIFLA9WC150602			Yes  [TOSHIBA]		No      			No        			Channel Modbus Network Protocol Suite
SIFLA1WPC40503			Yes  [TOSHIBA]		No      			No        			Chipcard
SIFLA1STOV0102			Yes  [TOSHIBA]		No      			No        			SIMATIC HMI StoragePlus Viewer
SIFLA1WPC50602			Yes  [TOSHIBA]		No      			No        			Video
this is the print of ALM file...
http://plcforum.uz.ua//L ... y.pdf.html
Post by CoMod » Thu Jun 04, 2009 9:09 am
Name of License = A9WRC?0700 | Exists = No |
Installed
SIFLA9WRT10602 Yes =A9WRT?0602 !
You need to install key for WinCC v7.0 <> not for WinCC v6.2 !
Install only 1 WRC key
