[?]: Unprotect Schneider PL7-Pro DFBs
другие контроллеры
letranlong
Re: [?]: Unprotect Schneider PL7-Pro DFBs
Post by letranlong »
ognde wrote:
letranlong wrote:
vlad2006gr wrote:letranlong , project on the memory card? Tried to intercept the exchange with the controller?
dear vlad2006
I have not project on the memory card. and also do not programs plc original. so I can't upload and download or exchange with the controller.
plaese help me
how to do exchange with the controller upload and download with controlled ?
how doing upload and download with controlled ?
Hey buddy,
Have you already used the unitelway driver to download with the correct cable and it´s not working?
You don´t have the application file correct?
dear ognde
I don't Have used the unitelway driver to download.
I Have used software twido swite version: 2.31.04 and used a wire cable TSXPCX3030-C USB 2.0 TO schneider twido series plc go to online with plc
before here, project on the plc. I created project on plc or I write program on plc
but before when I download progam to controller ( PC ==> PLC ) that time I have setting password for controller
but now when i online to controller again, this time me the forget password of (plc) controller and i am being loss program original. so i can't upload and download to controller.
when i online to controller, it's appears a box dialog the below here
twido suide and the plc applications aredifferent
immediate connection impossible
handware configuration are incompatible
PC ==> PLC transfer is impossible
PLC application is protected
PLC ==> PC transfer is forbidden
how is upload program plc?
plaese help me
how upload and download with controlled ?
how to do online with controlled ?
ognde
Post by ognde »
vlad2006gr wrote:ognde wrote:
Hey vlad2006gr i couldn´t download the file, would you mind send it again to me?
relink:
http://dfiles.ru/files/8i69j99vk
http://dfiles.ru/files/mxmzflrd9
or
http://www.4shared.com/rar/XuflXq0bba/b ... nlock.html
http://www.4shared.com/rar/tu5vO9Mpba/b ... nlock.html
Good luck!
Thanks bro, i will download as soon as i can open it in my computer. Thanks very much
ognde
Post by ognde »
letranlong wrote:
ognde wrote:
dear vlad2006
plaese help me
Hey buddy,
dear ognde
plaese help me
Hello, i will try to make a test with a twido plc here and after i test i will try to answer it for you.
Regards
letranlong
ognde wrote:
letranlong wrote:
ognde wrote:
dear vlad2006
plaese help me
Hey buddy,
dear ognde
plaese help me
Regards
thank you very much
You are a great help.
see you soon
have a nice day
thank you again
mseena
Re: Unlock Unity Pro project
Post by mseena »
Dear vlad2006gr, Can you help to unlock PL following the unity Pro project and DFB. https://www.sendspace.com/file/pz2x09
Thanks,
mseena
vlad2006gr
Post by vlad2006gr »
See PM.
la-ma
Post by la-ma »
sorry. My post is not about PL-7.
But it also about Schneider...
I have a PLC Twido TWDLMDA40D. When i try to upload a project from PLC to PC there is a message to enter a password.
I can upload project but can't change anything or save application without the password.
Can anyone tell me is it possible to find the password somewere at temporary files or in memory.
i have a ladder or list view of program. Hard way is to reenter all about 400 strings of project and a lot of constants, counters, timers and etc. But i warry about the value of constants, may be some setting i don't know about ....
Вижу тема по UnitiPro разных версий, но есть вопросы и по TwidoSoft.
может кто знает или сталкивался.
Есть контроллер Twido TWDLMDA40D. Сейчас я могу к нему подключиться и считать проект. Но проект защищен паролем. Поэтому проект не могу сохранить на компьютере, не могу изменять что-либо. Не допускается копировать проект в виде листинга в другой проект.
Можно, конечно, по строкам вбить в новом проекте такую же програму. не уверен насчет других составляющих проекта: константы, счетчики, таймеры, типы входов и, возможно, еще много всяких мелочей. не начем проверить такой вариант. пробовал поискать временные файлы в директориях для дальнейшего анализа. Пока ничего не нашел.
Да, сейчас пользуюсь TwidoSoft v3.5. Может попробовать старыми версиями?
vlad2006gr
Я правильно понял?-
Т.е. проект скачивается с контроллера TWDLMDA40D, и в программе вы видите все шаги программы? Только не можите сохранить.С таким не встречался, но большинство программ, при скачивании, сохраняют в ТМР директории все файлы и потом перекидывают в заданную. Проверьте при скачивании директории для временных файлов. Возможно там будет ваш проект.
la-ma
Post by la-ma »
да, все правильно.
я тоже про временные директории знал, и потому поискал в типовых папках операционной системы. Пока не нашел.
Для меня все равно есть радость. Повезло, что поставщики оставили старые версии программ в виде *.twd файлов. Они прекрасно открываются в "блокноте" и там нашел поле "pass" в открытом текстовом виде. его и ввел при считывании новой измененной версии. Совпало.
Где все таки система хранит временные файлы пока не нашел. Больше увлечен знакомством с программированием этого контроллера. Для меня это впервой. В основном Омрон или Брадлей.
Yes, I can transfer project from PLC to PC. But I can'tfind any temporary files at \AppData, \local\temp ...
But i a lucky boy. i had an old version of project from suppliers as *.twd file. It can be open as a xml file at Notepad. The password stored inside this file as a plain text.
I still interesting in to find some temporary storage for online openning project but not right now.
vlad2006gr
Дело в том, что программа при сливании проекта может записывать его на диск либо без расширения, либо с другим расширением. Не *.twd. Плюс большинство программ кидают дополнительные файлы, с юзер ареа, состоянием битов и памяти, и хз еще что. Потом только программа пакует или наоборот, распаковывает в файл привычного вида. Смысл в вашем случае искать эти файлы - для определения пароля. Но раз вы его уже знаете, то нету. Разве, что для практики;) Я поступаю следующим образом: используя утилиту от сисинтерналс- Filemon.exe ищем куда программа ложит файлы, потом другой программой - Folder Find Text ищем там файлы с необходимым тектом, например паролем.
la-ma
Post by la-ma »
попробую поискать. может и утилиту поставлю.
сейчас больше увлечен/озадачен новой задачей. к контроллеру подключен управляемый пускатель с хитрым логическим контрольным модулем Tesys LUCC. Требуется разобраться с его ошибками передаваемыми по Modbus. это уже в другую тему.
Спасибо за участие.
I will try to find temporary files later.
dian_andry_k
Post by dian_andry_k »
Dear vlad2006gr,
http://www.4shared.com/rar/p3Ysq59gce/D ... _Pass.html
Thanks,
Andry
vlad2006gr
This project is compiled in version 7.0 XLS.
http://www.4shared.com/rar/-d4uxPuice/D ... _Pass.html
Good luck!
ridhatn
Post by ridhatn »
Dear vlad2006gr,
http://www.4shared.com/rar/r94PpPvgba/Documents.html
Thanks,
rida
vlad2006gr
Pooh
Post by Pooh »
0vlad2006gr добрый день !!!
Хотел просить еще раз проконсультировать о том в каких файлах следует искать пароли для версий Юнити от 7.0 и выше ? Интересует пароль на всю программу, не только на блоки. Хочу разобраться в этом вопросе с вашими подсказками.
И есть еще один вопрос по Твидо. Есть один объект на нем контроллер Твидо, программа в контроллере на карте памяти. Программа закрыта паролем и есть доступ только к функциям RUN и STOP. Пароль естественно мне неизвестен. Существует ли возможность скачать такую программу из контроллера ???
Надеюсь на помощь в этих вопросах, заранее спасибо.
SE_support
Post by SE_support »
Pooh wrote:0vlad2006gr добрый день !!!
А чем не устраивает информация с первой страницы этого топика? Уже даже скриншоты с описанием даны. Влад конечно не всё рассказывает :) Есть ещё более простой способ посмотреть пароль на проект, даже если пароль не в открытом виде - кто ищет, тот найдёт.
Pooh
Post by Pooh »
Если бы информации с первой страницы было достаточно, я бы не задавал вопросы. С первых сообщений этой ветки утекло много времени и сменилось много версий программы.
Я нашел пароль на секции программы, приблизительно там же появляется пароль и на всю программу. Но можно ли как-то вскрыть зашифрованный пароль..? (h)
SE_support
Pooh wrote:Если бы информации с первой страницы было достаточно, я бы не задавал вопросы. С первых сообщений этой ветки утекло много времени и сменилось много версий программы.
Ну всё правильно, вы нашли где находится пароль, просто теперь пароль ещё и зашифрован. Надо всего-лишь знать как зашифрован пароль - данная инфо пока нигде не проходила, но алгоритм проще простого.
nguyanh
Post by nguyanh »
Dear Vlad2006gr.
Could you please help me unlock unity pro project this file.
https://drive.google.com/file/d/0BxAlpH ... sp=sharing
Thank you very much
vlad2006gr
See PM.
schutz
Post by schutz »
Hi!
I have a problem in my file with a section protected by password ... but I forgot the latter...
Can you help me ?
The link to the file: http://ovh.to/c1VXNWW
Thanks!
Jérémie
vlad2006gr
In late October, I will be able to help .
vlad2006gr
schutz wrote:
Hi!
Can you help me ?
http://www.4shared.com/rar/LEWI48f2ce/c ... nlock.html
Good luck!
schutz
Post by schutz »
Thank you very much! (oo)
Nivin
Post by Nivin »
Dear Experts,
I have seen in the forum and I have done unlock password for Unity Pro program. I use Unity Pr V.8.
My program is password protected with encryption.
After working on Hex editor this is what i get.
Header name="Project" version="0.0.559" dateTime="date_and_time#2014-12-31-14:1:49"
password="C8D8180D416C5DD4400A9655CAB64860EE30306461394E338B0610B1"
crypted="0"></contentHeader>...<commParameters>....<PLCAddress address="192.168.1.10"
How do i know the password.?
Program is available in the below link provided.
http://www.4shared.com/archive/27fE-NINce/CoGen.html
Please help.
Thanks & Regards,
Nivin
(nuser)
vlad2006gr
Nivin wrote:
Dear Experts,
Project version 7.0
Password project- inddcc21
Password DFB- TYC31
Good luck!
Nivin
Post by Nivin »
Dear vlad2006gr,
Thanks a ton... You make it seem so simple..
I have no words to express my gratitude.. I needed the password desperately.
How did you do it..Just to know & learn..
(oo) (tyou)
gameover123
Post by gameover123 »
Dear vlad2006gr
please help me to unlock the program. Our contractor locked the project and refuse to give password .
i know the password for station.apx but unable to find password for DFBs.
PM password please.
Uploaded Locked Files:
5-11-15.rar
gameover123
Thanks vlad2006gr.
You are great.
Arnaud1
Post by Arnaud1 »
I need help with a password. This password is crypted and i don't unprotected DBF...
The project is uploaded at :
https://1fichier.com/?2ednslp5hf
Thank you in advance for your time.
vlad2006gr
Arnaud1 wrote:Arnaud1 » Чт дек 10, 2015 12:23 am
In the project there is no password!
Arnaud1
Post by Arnaud1 »
thanks for your answer. I am very stupid, i take many project for testing and it's the bad project uploaded.
http://up.lbzh.fr/uploads/566935f3e0643.stx
Thanks for your time and your help.
vlad2006gr
Arnaud1 wrote:Arnaud1 » Чт дек 10, 2015 11:23 am
No password:
http://up.lbzh.fr/uploads/566aa6a860605.rar
Good luck!
Arnaud1
Post by Arnaud1 »
Thank you very much. I will test it monday.
Can you explain to me how are you did it ?
Only software or with hardware ?
Мои искренние благодарности.
vlad2006gr
Arnaud1 wrote: Arnaud1 » Сб дек 12, 2015 11:30 am
Only software and reversing. Do not forget to rename the file.
Good luck!
Arnaud1
Post by Arnaud1 »
THANK YOU VERY MUCH MISTER VLAD2006GR...
Can you make a tutorial with an example ? I think you're the best to make it.
onderatsan
Post by onderatsan »
Hello Master VLAD2006GR.
I need your help.
Can You open attached projects DFB? (Program - Tasks - Mast - Sections.. Everything Locked)
and say to me what is passwords?
PLC1 Project;
https://www.dropbox.com/s/19o2kaqkvhrcf4q/PLC1.rar?dl=0
PLC2 Project;
https://www.dropbox.com/s/57pd74905ibwg7b/PLC2.rar?dl=0
With Best Regards.
vlad2006gr
onderatsan wrote:Hello Master VLAD2006GR.
I need your help.
See PM.
onderatsan
Thank You very much Master.
Can You tell me, what was password / passwords? if possible.
With Best Regards.
vlad2006gr
The password has been encrypted. Decoding was not in the password.
houssamatif
Post by houssamatif »
dear vlad2006gr;
can you help me to unlock this project:
https://drive.google.com/open?id=0B7hg9 ... TNxUklZWXM
thank you
vlad2006gr
houssamatif wrote:can you help me to unlock this project:
password 198508
Good luck!
houssamatif
thank you so much
it's very helpful
you are amazing !!!!!
(clap) (clap) (clap) (clap) (clap) (clap)
letranlong
letranlong wrote:
ognde wrote:
dear vlad2006
plaese help me
Hey buddy,
dear ognde
plaese help me
dear everybody
please help me
alik-sobaka
Post by alik-sobaka »
Уважаемый Влад возможно вы мне сможете помочь? Часто возникают вопросы со станком, иногда причину проблемы приходится долго искать
https://drive.google.com/open?id=0B6Nle ... 01FM0ZUcVk
https://drive.google.com/file/d/0B6Nleu ... sp=sharing
Премного благодарен.
vlad2006gr
alik-sobaka wrote:Уважаемый Влад возможно вы мне сможете помочь?
See pm.
Good luck!
vlad2006gr
letranlong wrote:PC ==> PLC transfer is impossible
Тут напишу по русски. В Pl7 и в Unity после компиляции программы образуется образ для загрузки в карту памяти BinAppli (это если программу *.stu открыть в винраре она будет видна) . Если из карты памяти контролера через кардридер скачать программу, так это и будет BinAppli , только преобразованный.В Unity можно открыть программу любой версии. Переименовать файл *.STU в *.STA, и он откроется. Но конечно не будет DTM. Так вот в *.STA файле и находится этот BinAppli.
Я достал карту из запароленого (PLC ==> PC transfer is forbidden), скачал через кардридер ноутбука. Преобразовал в BinAppli , вставил в *.STA и открыл в Unity. Но вообще работа трудная.
In Pl7 and in Unity program after compiling formed image to boot to BinAppli memory card (if it is a program * .stu open vinrar it will be visible). If the memory controller via a card reader to download maps, so it will be BinAppli, only Unity preobrazovannyy.V can open any version of the program. Rename the file to * .STU * .STA, and it will open. But of course there will be the DTM. So in * .STA file and this is BinAppli.
I got a card from the password-protected (PLC ==> PC transfer is forbidden), downloaded through a laptop card reader. I convert to BinAppli, put in * .STA and opened in Unity. But in general the work difficult.
SE_support
Vlad2006gr,
тебе пора уже свой бизнес открывать по подбору паролей :)
Ты пишешь "Преобразовал в BinAppli , вставил в *.STA и открыл в Unity. Но вообще работа трудная. " - что ты имеешь ввиду под "преобразовал"?
И ещё вопрос - ты уже научился находить "закодированный" пароль от Unity проектов?
vlad2006gr
Преобразовал это то,что файл BinAppli и скаченный с карты как бы сегментированный. Сегмегнты в обоих файлах одинаковы, но находятся в разных местах. Поэтому их нужно переставить.
SE_support wrote: ещё вопрос - ты уже научился находить "закодированный" пароль от Unity проектов?
Ну про это я говорить не хочу.
