[LINK:] Schneider Electric Vijeo Designer 4.6 authorization
Schtiel
Post by Schtiel » Thu Mar 20, 2008 12:45 pm
Follow instructions in the archive:
http://plcforum.uz.ua//VJD46_auth.rar
or http://slil.ru/25602737
Enjoy! :D
MareBlu
Post by MareBlu » Sat Mar 22, 2008 8:16 am
Thank you veri much, Schtiel...
I haven't this software still, but I wish to get it in some way...
bye
MareBlu
Post by MareBlu » Fri May 02, 2008 5:22 am
Thank you very much, Schtiel...
I need it to test if there is an error on communication protocol of a touchscreen...
bye
betlehed
Post by betlehed » Fri Jun 27, 2008 9:52 am
Dear Schtiel
In my project I had to work with XBT GT2330 graphic panel
I have only VD 4.2. My version doesn't support this panel.
So, I downloaded and installed VD4.6
But I can't compile no mine no sample project and I have no idea why :shock:
The error is :
"Error aborting build due to compiler errors. Please clean and rebuild target. If error continues, consult readme and other user documentation."
After cleaning and rebuilding the target I see the same error.
Can somebody help me?
Schtiel
Post by Schtiel » Sat Jun 28, 2008 7:09 pm
betlehed wrote:The error is :
Hi!
I had the same problem. During install you should change the default directory for projects
C:\Documents and Settings\User\Мои документы\Vijeo Designer Projects
to any directory that doesn't contain any cyrillic symbols (for example, to
C:\Program files\Schneider Electric\Vijeo Designer\Projects.
Hope this will help you.
betlehed
Post by betlehed » Mon Jun 30, 2008 6:37 am
Thank you, Schtiel
Now It works OK
eng.jaber
Re: [LINK:] Vijeo Designer 4.6.0c
Post by eng.jaber » Tue Nov 18, 2008 10:46 pm
Schtiel wrote:Vijeo Designer 4.6.0c
Vijeo Designer 4.6.0:
Vijeo Designer 4.6.0 Patch C
dear Schtiel :
i have this major problem each time i try to unrar multi rar files
it always asks for a password when it gets till file part11
plz man help me on this problem and if you have another way to slove this , maybe i don't know the right way to install Vijeo Designer 4.6.0.dear Schtiel :
plz man help me on this problem and if you have another way to slove this , maybe i don't know the right way to install Vijeo Designer 4.6.0.from multi rar files
thanks again
thanks again
Schtiel
Post by Schtiel » Wed Nov 19, 2008 10:42 am
eng.jaber wrote:i have this major problem each time i try to unrar multi rar files
There is no password on archive. Use WinRAR if you have problems with other archivers.
eng.jaber
Post by eng.jaber » Fri Nov 21, 2008 8:35 am
thanks man it works
mika
Post by mika » Sun Dec 21, 2008 2:49 pm
hello
i tried to install the veijo version 4.6 with success,only i can not install the autorization key.i followed the instructions and think that the problem is installing the 58056 file.where do i have to install it.can somebody help me
most
Post by most » Sun Dec 21, 2008 6:07 pm
mika wrote:hello
you only have to place (copy) this file in the folder windows
khalid312
vijeo designer
Post by khalid312 » Sun Mar 01, 2009 4:34 pm
does someone knows why when i run vijeo designer, i et a message saying"you shoud be as administrator to run vijeo designer". but me i am running computer as adminstrator.
thank for help
Schtiel
Re: vijeo designer
Post by Schtiel » Fri Mar 06, 2009 8:09 pm
khalid312 wrote:does someone knows why when i run vijeo designer, i et a message saying"you shoud be as administrator to run vijeo designer". but me i am running computer as adminstrator.
Right click on Vijeo Designer shortcut, select Run as Administrator
maly1986
Re: [LINK:] Schneider Electric Vijeo Designer 4.6 authorization
Post by maly1986 » Thu Aug 20, 2020 2:44 pm
Enjoy! :D
Can you please update those links, i'm trying to open but it looks dead.
aymeric38
Post by aymeric38 » Fri Aug 12, 2022 9:49 am
Link_is_Dead :(/files/100958344/VJD46_auth.rar
Enjoy! :D
Here : https://anonfiles.com/Zc62Q0Ldu0/VJD46_auth_rar
tested and working ;) Read first the readme.txt file
aymeric38
Re: vijeo designer
Post by aymeric38 » Fri Aug 12, 2022 9:50 am
Thank you Schtiel for your work on Vijeo Designer ;)
aoody
Post by aoody » Sat Jul 29, 2023 8:47 am
Schtiel wrote:
Tue Apr 29, 2008 6:33 pm
Link_is_Dead :(/111245064/VJD460.part01.rar
Link_is_Dead :(/111246010/VJD460.part02.rar
Link_is_Dead :(/111246989/VJD460.part03.rar
Link_is_Dead :(/111248407/VJD460.part04.rar
Link_is_Dead :(/111249534/VJD460.part05.rar
Link_is_Dead :(/111442231/VJD460.part06.rar
Link_is_Dead :(/111443753/VJD460.part07.rar
Link_is_Dead :(/111468929/VJD460.part08.rar
Link_is_Dead :(/111470441/VJD460.part09.rar
Link_is_Dead :(/111471898/VJD460.part10.rar
Link_is_Dead :(/111477409/VJD460.part11.rar
Link_is_Dead :(/111478354/VJD460.part12.rar
Link_is_Dead :(/111483861/VJD460.part13.rar
Link_is_Dead :(/111485110/VJD460_patch_c.part1.rar
Link_is_Dead :(/111486440/VJD460_patch_c.part2.rar
please sent link Vijeo Designer 4.6
I want to used.
Thank
boonyod.s@gmail.com
Schtiel
Post by Schtiel » Wed Aug 02, 2023 4:06 pm
