Hello there
I need the program I wrote below.
This program is a program that tells Mitsubishi servo motors the strength to write to the encoder. Encoder type OSA16,OSA17,OSA18 vs...
I can not find anywhere.
Give the the name of the program MOTID VER.1.00 if you have in your hand are you sharing?
Thank you...
[?]: Mitsubishi servo motor encoder software
Re: help me! Mitsubishi servo motor encoder software
update help me???
update help me??? Mitsubishi servo motor encoder config software motid.
Mitsubishi (Motor ID writer) software. Servomotor encoder firmware.....
Little chance, but I'll try to find out . The EEPROM 25L160 encoder OSA676S5AS failed , there were engine settings. Maybe who knows where to get the firmware?
You Can be done this problem finished?setmedical wrote: ↑Tue Oct 31, 2017 9:21 amupdate help me??? Mitsubishi servo motor encoder config software motid.
