Тools, Elcad, Eplan, ...
dalil
Post by dalil » Thu Oct 28, 2021 5:22 pm
Can someone re-upload Eplan fluid 2.9?
Past links are broken (h)
UzOdin
Post by UzOdin » Mon Nov 01, 2021 4:34 pm
@ s1921707
This is Smart Wirng Server. Do you have Smart Wiring Client 2022? And Smart Wiring Monitor 2022?
@ dalil
https://gofile.io/d/8fPWzc
Linus1
Post by Linus1 » Tue Nov 02, 2021 10:32 am
Hello everybody,
I'm new on the forum so this is my first post. (nuser)
First of all sorry for my english.
I'm searching for Eplan P8 and I've tried to install the Electric P8 2.9.3.14179 version using the 1p02.rar crack but it doesn't work.
The eplanlicensemanager.exe doesn't work, it appears this error: "Error! Redirection from eplan.prod.sentinelcloud.com to local not active" and then "exit"
The keygen doesn't work, it creates a license with the 3 HWID and the eplan systems added, but when I call the program it appears a message that the license is not valid for this computer.
So when I try to activate a license in the next page (trying to activate it online and using the 0000... EID code another error message appears: "impossible to connect to the internet server 'https://eplan.prod.sentinelcloud.com' ERROR [HTTP 12007] Impossible to resolve the name of the server or the address
I don't know if that is the right medicine and if it already works, or if I've made a mistake (very probably...) (h)
If anyone can help me I would appreciate very much.
Thank you all
EPLSG
Post by EPLSG » Tue Nov 02, 2021 2:35 pm
I Linus 1
currently I'm using an official license but some weeks ago I installed a license for a friend of mine and worked fine.
I followed the procedure showed in the txt file without online registration.
That's it.
Other forum users will be able to tell you if medicine installation have recently changed.
Keep in touch.
Geeklzk
Post by Geeklzk » Sun Nov 07, 2021 4:00 pm
I have a legal serial number and a legal EPLUSE account. The only problem I have now is that the cannot be downloaded from the data portal. Do you have a good solution?
Jake1
Post by Jake1 » Sun Nov 07, 2021 6:56 pm
Go to Options > Settings > User > Administration > internet connection
Try connection test, Date Portal must be green.
You are at home or in office?
Maybe a firewall blocks the connection.
Stefan_TS
Post by Stefan_TS » Mon Nov 08, 2021 1:14 pm
Can someone upload Eplan EEC ONE 2022?
Carlutu
Post by Carlutu » Sun Nov 14, 2021 4:30 pm
Eplan Fluid 2.9 Links??
HooK
Post by HooK » Wed Nov 17, 2021 7:34 am
I was able to patch ePulse login with EPLAN Electric P8 2022.0.3.17561. I tested pushing date many days ahead and it never asks to login to ePulse anymore!
Can anyone share full Setup files for other EPLAN 2022 products? I want to try and crack those too and release soon :P
Thanks!
-HooK
DesoxyN
Post by DesoxyN » Wed Nov 17, 2021 4:47 pm
Hey everyone,
I'm an Electric & Electronics engineering student. I want to download the latest-stable EPlan Electric. Can anyone link me to correct setup and medicine combo? Thanks!
tazik
Post by tazik » Thu Nov 18, 2021 10:07 am
Eplan is free for students. Just download and create a registration and license request during installation.
https://www.eplan-software.com/solution ... -students/
TheDuke
Post by TheDuke » Fri Nov 19, 2021 9:28 am
Hey HooK
This is great news you got to program a crack.
I think that the vast majority of programs are set up on the EPLAN Platform 2022 and all use the same EPULSE ID together, so that your crack then affects the same programs as the chaos363 keygen.
So it would be great for most of them if you would make your crack available to us.
Jake1
Post by Jake1 » Fri Nov 19, 2021 10:35 am
Great news, indeed! (oo)
5156PBK
Post by 5156PBK » Fri Nov 19, 2021 2:43 pm
EPLAN Platform 2022 Update 1 17617,CK
HooK
Post by HooK » Fri Nov 19, 2021 4:03 pm
Yes, cracked DLL from License Client will bypass ePulse on all EPLAN apps.
They just released Update 1 with new version of License Client so I will patch that one now as well...
-HooK
leewheel
Post by leewheel » Sat Nov 20, 2021 6:55 am
Wait the good news!! & Thanks!!
leewheel
Post by leewheel » Sun Nov 21, 2021 1:40 am
chaos363 wrote:
Tue Sep 21, 2021 7:55 pm
:mrgreen:
https://gofile.io/d/CMBfyo
vcruntime140.dll has changed and template has been expanded for the new options.
This Keygen for EPLAN Electric P8 2022.0.3.17561 Still working,but in EPLAN Electric P8 2022.0.3.17617, its not working .
Jake1
Post by Jake1 » Sun Nov 21, 2021 8:08 am
Update 1 is available since friday 19.11, the guys need little time to modify the new vcruntime140.dll.
ePULSE crack works too (I was allowed to test it), so i think the guys will share ePULSE crack and Update 1 crack together, maybe soon! :wink:
vengai
Re: Eplan P8 2.8/2.9 adding EDZ offline data portal files
Post by vengai » Sun Nov 21, 2021 12:57 pm
Hello All
Could anyone provide information or steps in order to open edz offline data portal files download in eplan p8 electric .Please anyone help me.
Thank you all... (sos)
Jake1
Post by Jake1 » Sun Nov 21, 2021 5:55 pm
Hi, when you have articles in edz format go to:
Article management > extras > import > use File type "edz format"
Eplan will create folders for pictures, macros too.
EPLSG
Post by EPLSG » Mon Nov 22, 2021 7:07 am
Hi Vengai,
if you want to use the individual parts you can also open or extract files using 7zip.
edz file is like to a zip,nothing else.
HooK
Post by HooK » Mon Nov 22, 2021 7:19 am
Bad news: I tried modifying vcruntime140.dll to make it work with the new license client (v2022.0.3.339) without any luck :x :(
We will need @chaos363 help with this as he knows more than me!
Bypassing ePulse with new license client is no problem! The problem is now vcruntime140.dll
For now, just don't update the new license client & don't install update 1!
Keep License Client at version 2022.0.3.323!
lunakk
Post by lunakk » Mon Nov 22, 2021 5:34 pm
HooK, can you please share solution how to bypasse ePULSE. (tyou)
zart
Post by zart » Tue Nov 23, 2021 6:37 am
Please someone apply link for version 2022.0.3.323,because previous not content English language.
Thanks in advance.
lunakk
Post by lunakk » Tue Nov 23, 2021 1:19 pm
EPLAN 2022.0.3.323
https://gofile.io/d/MuuUEB
zart
Post by zart » Wed Nov 24, 2021 6:36 am
Please someone apply download link for version 2022.0.3.323,because previous not content English language.
Thanks in advance.
HEROS47
Post by HEROS47 » Thu Nov 25, 2021 8:56 pm
HooK, can you please share solution how to bypasse ePULSE. Please (sos)
zart
Post by zart » Mon Nov 29, 2021 1:37 pm
For version 2022.0.3.323.
When I use crack EPLAN_Patch_1_0_3 I have a message "There is not serial in "lservrc",but when I use EPLAN_Patch_1_0_2 not
For E-Pulse it is asking serial,when I try to log with my registration email address same that I use successfully for Eplan 2.9 ,and I get a message that Eplan will stop after 1 week.
Any help will be apreceated .
willi_TC
Post by willi_TC » Thu Dec 02, 2021 7:10 am
anyone has a crack/instruction for licencing?
got it going but have the same issue with epulse message - "will shut down in 1 week"
Anyone a good advise?
mareq6666
Post by mareq6666 » Sat Dec 04, 2021 3:03 pm
Hello just change date in windows and you can use eplan 2022
Jake1
Post by Jake1 » Sat Dec 04, 2021 6:25 pm
Will not work!
@HooK has a solution for EPLAN 2022 without update 1.
We need new crack for update 1, but chaos353 is not available... :(
AK47
Post by AK47 » Mon Dec 06, 2021 7:25 pm
It doesn't look like @HooK have a solution as so far he didn't publish anything. Chaos353 should be very careful as this could be a trolling trying to find how the license is bypassed so they can fix this in future updates.
Jake1
Post by Jake1 » Mon Dec 06, 2021 7:44 pm
HooK has the solution for ePULSE, i have tested it and it still works.
It's his patch, he decides when he will release it.
AK47
Post by AK47 » Mon Dec 06, 2021 7:58 pm
Yeah, yeah. Good for him. He can keep it, no worries 8)
HooK
Post by HooK » Mon Dec 06, 2021 9:57 pm
Sorry friends. I have been busy with life lately, so not much free time :(
Jake, feel free to share the cracked "Eplan.IdentityClient.Coreu.dll" I have given you with the rest of the people here (pgood) so we don't get an angry mob forming...lol AK47 :P
I spent good amount of time on trying to make a new vcruntime140.dll that will work with Update 1 as well, but I wasn't successful. We need chaos363 to revise it! But for now, just don't apply Update 1 and you will still be able to use EPLAN Electric P8 2022.0.3.17561.
BTW, I have released these on B4A already last month :D :
EPLAN Education 2022.0.3.17561
EPLAN Fluid 2022.0.3.17561
EPLAN Pro Panel 2022.0.3.17561
Cheers! 8)
-HooK
AK47
Post by AK47 » Tue Dec 07, 2021 6:21 am
I spent good amount of time on trying to make a new vcruntime140.dll that will work with Update 1 as well, but I wasn't successful. We need chaos353 to revise it! But for now, just don't apply Update 1 and you will still be able to use EPLAN Electric P8 2022.0.3.17561.
Cheers! 8)
-HooK
Hi Hook,
Is not an angry post at all, I'm just saying the facts everyone like me reading the forum is seeing. And the facts are, some saying that, he cracked the ePulse but not sharing what he did or at least I can't see it, which is absolutely fine and no one forcing you to share. But the question is, if you don't planing to share it why announcing it on the first place? Please answer.
Second, if you are the ordinator of the ePulse crack, why are you asking someone else to share it. Does it takes that long to upload a file with few kb, but didn't take long to write your post above? Please answer.
And again, no one is angry I just share opinion like everyone else have right to do it.
zart
Post by zart » Tue Dec 07, 2021 11:35 am
Cheers! 8)
-HooK
<<<"Eplan.IdentityClient.Coreu.dll" I have given you with the rest of the people here >>> (usearch) where it is?
In EPLAN Electric P8 2022.0.3.17561 set up folder ?
When I install that -> with out E-Pulse not running.
boroova6523
Post by boroova6523 » Tue Dec 07, 2021 1:43 pm
When creating the "lservc" file in the Keygen (1.03) try adding "No Identity Check" and "Skip Identity Check" in the "Modules" section
titus95
Post by titus95 » Tue Dec 07, 2021 3:24 pm
Thank you boroova6523 it allows to open EPlan. (pgood)
TheDuke
Post by TheDuke » Tue Dec 07, 2021 5:48 pm
Thank you boroova6523 for the tips, thats it. :D :D
Jake1
Post by Jake1 » Tue Dec 07, 2021 6:04 pm
Cool! (pgood)
Always good when more people have a solution for a problem.
HooK
Post by HooK » Tue Dec 07, 2021 10:45 pm
Ohh god! Drama queen alert :shock: I'm ignoring you @AK47... you add no value to this thread whatsoever. Move along...
@boroova6523
Good find mate! (pgood) "No Identity Check" and "Skip Identity Check" eliminates the need to patch "Eplan.IdentityClient.Coreu.dll"!
Now we just need to create a new "vcruntime140.dll" to make it work with update 1.
Chaos353 used cmp RAX & R8 registers with v2.9 & cmp R15 & RBX on v2022 (works up to v2022.0.3.323). I tried debugging/tracing to see what can work for v2022.0.3.339 (update 1) but was unsuccessful (so far). Need Chaos363's help at this time!
Cheers,
-HooK
Tesiro
Post by Tesiro » Wed Dec 08, 2021 9:41 am
Cheers! 8)
-HooK
Hello, can you provide the Elpan fluid 2022 installation package? Thank you
HooK
Post by HooK » Wed Dec 08, 2021 3:43 pm
EPLAN Fluid v2022.0.3.17561:
https://disk.yandex.com/d/geXYuAAmQZgEeg
brusko
Post by brusko » Wed Dec 08, 2021 9:11 pm
(gpost)
Thank you so much. This way works perfectly. (suc)
And small note. The nickname of Chaos is Chaos363 not Chaos353. :haha:
Tesiro
Post by Tesiro » Thu Dec 09, 2021 12:30 am
Thank you so much for sharing
EPLSG
Post by EPLSG » Thu Dec 09, 2021 8:27 am
I am using version 2.9 but I would like to upgrade to the new one. Anyone have an installation guide point to point?.
Thanks all (oo)
Jake1
Post by Jake1 » Thu Dec 09, 2021 11:45 am
Patching 2022 is same as patching 1.9
Use patch 1.03
- Copy vcruntime140.dll in bin folder from 2022
- When creating the "lservc" file in the Keygen (1.03) try adding "No Identity Check" and "Skip Identity Check" in the "Modules" section
EPLSG
Post by EPLSG » Thu Dec 09, 2021 1:46 pm
OK thanks I'll try to follow your indication
timido
Post by timido » Thu Dec 09, 2021 7:41 pm
I have installed and patched succesfully Eplan 2022, but if I try to open Propanel 2.9 that was installed and working it says that there isn't a valid license. I have tried to add in the patch all the modules of the version 2.9 and create the lservrc, but it says the same. Is it possible to have at the same time both versions? Thanks!
