Citect 7.4, 2015, 2016 - Crack
Peritior
Post by Peritior » Mon Mar 27, 2017 1:43 pm
Hello!
Does anyone have a citect crack for any of the "newer" Citect servers?
I have been looking like crazy but all the download links are to old and not active :-/
Citect 7.2, 7.3 would work aswell but i whould prefere 7.4 and newer.
Peritior
Re: Citect 7.4, 2015, 2016 - Crack
Post by Peritior » Wed May 03, 2017 11:03 am
Bump
djalmaz
Post by djalmaz » Mon May 15, 2017 10:00 am
Try these keys (the difference is only in the identifier of the system Vijeo-Citect). VijeoCitect 7.20, Citect 2016 works exactly on this key. By analogy 7.30, 7.40 will work too, the protection system did not change.
Spoiler
Пробуй эти ключи (разница только в идентификаторе скада системы Vijeo - Citect). Точно работает на этом ключе VijeoCitect 7.20, Citect 2016. По аналогии 7.30, 7.40 тоже будут работать, система защиты не менялась.
https://ru.files.fm/u/2yfb9wy8
Peritior
Post by Peritior » Mon May 22, 2017 9:30 am
Awesome! What more files do i need to make the installation?
Some Install.bat if i'm not mistaken? Do you know any downloadlink for that aswell?
tatcontrol
Post by tatcontrol » Tue May 23, 2017 11:15 am
would you please explaine how to install the crack
djalmaz
Post by djalmaz » Mon Jun 05, 2017 5:45 pm
multikey for x64 platform, tested on win7 x64.
And then use the standard procedure for emulating the key:
1. Install .reg file (double click) which you need version
2. Run Install.cmd
3. Restart computer.
Check in ciusafe, should determine the key. Try it
Spoiler
DinoB
Post by DinoB » Thu Nov 16, 2017 3:25 pm
Hi, is this working? I tried on my Virtual machine but so far unsuccesfull.
PLease if someone have som solution tell me..
Regards
DriverFirst
Post by DriverFirst » Mon Jan 07, 2019 5:32 pm
не работает этот способ ни с 7.20, ни с 7.40
Centoff
Post by Centoff » Wed Mar 13, 2019 1:24 pm
Все работает, просто надо поработать над ним под win7-10 x64. Протестировал на win10 версия 7.4. Если надо, могу скинуть мой вариант.
ttrunc
Post by ttrunc » Thu Mar 14, 2019 6:51 am
скиньте пожалуйста
ascii_192
Post by ascii_192 » Tue Mar 19, 2019 5:25 am
It is not working in Win10 currently. I have done a video for windows 7 64bit. It has also included crack:
https://mega.nz/#!AfIRESZC
djalmaz
Post by djalmaz » Wed Mar 20, 2019 9:25 am
Мой ключ прекрасно работает с Citect2016, с Citect7.20 под Windows7 x32 и x64,проверено лично, разница в драйверах на multikey. Подбирайте под свою ОС и разрядность драйвер multikey.sys, должно нормально установиться в системе устройство SafeNet USB SuperPro/UltraPro. Собственно, дальнейший порядок установки указан выше. Файл .reg применяете под свою версию скада, соответственно, разница в идентификаторе Vijeo или Citect серии. Все
Spoiler
Вот что пишет VijeoCitect7.20 с этим ключем
https://ibb.co/dgsVBH7
Centoff
Post by Centoff » Thu Mar 21, 2019 1:33 pm
Извиняюсь за долгий ответ!
Держите!
Распаковать на диск C:\ (если путь будет отличаться от C:\ACA3\, то заменить его в install.cmd)
так же в архиве есть devcon10 и на x86 (автоматом на x64) и архив с мультикеем подписанным для win10 на x64 (уже стоит)
Spoiler
Пароль/Password: plcforum.uz.ua
Установка:
1) Установить сертификат ( у меня на любом сработал, последний на 800)
2) Запустить install.cmd (отредактировать, если путь отличается)
Centoff
Post by Centoff » Wed Mar 27, 2019 10:27 am
Unzip to C: \ (if the path will be different from C: \ ACA3 \ to replace it in install.cmd)
there is also a devcon10 in the archive and on x86 (x64 machine) and the archive with the multikey card is signed on win10 on x64 (already standing)
Installation:
1) Install the certificate (I worked on anyone, the last one was at 800)
2) Run install.cmd (edit if the path is different)
3) Reboot!
mistymoon
Post by mistymoon » Sun Apr 28, 2019 6:56 pm
I've followed the instructions for W10 64bit. But I get this error:
C:\ACA3>C:\ACA3\devcon.exe remove root\multikey
No devices were removed.
C:\ACA3>C:\ACA3\devcon.exe install C:\ACA3\multikey.inf root\multikey
devcon.exe failed.
Press any key to continue . . .
longwangwl456
Post by longwangwl456 » Tue May 07, 2019 10:36 pm
In win10 X64, Citect 2016 simulation key can be found by CiUSAFE.EXE from Citect V7.2 if we replace the file in Citect 2016. But that means nothing.If run "Example" project, it will go to demo mode.
Run the CiUSAFE.EXE from Citect 2016 will show "Error key".
Any comments?
amazon1988
Post by amazon1988 » Thu May 09, 2019 12:47 am
(h)
1.Run as administrator need devcon.exe
2.Drivers subscribed to Multikey x64 needed.
cool_runnin
Post by cool_runnin » Sat May 11, 2019 7:35 pm
I am trying the above on fresh Citect 2018 installation (Virtual Machine + Win7 x64).
It works but now I am stuck with upgrading the emulated dongle and receiving the Authorization Code.
Any solutions to generate the key ?
amazon1988
Post by amazon1988 » Mon May 13, 2019 2:45 pm
Citect 2018 has version 8.1x, in the header is a key for Citect 2016 8.0x
cool_runnin
Post by cool_runnin » Mon May 13, 2019 6:59 pm
I got the key. The key changes each time you run CIUSAFE and that indicates the multi-key emulator works OK.
But how to generate authorization code to that key ?
According to yt some guy goes to official site where you paste the key (starting with 047-, 048, ..) and then he gets long text. This is Authorization Code.
Also. The .reg files in above links for each version are the same so why not use them for x8.1 (Citect 2018) ?
amazon1988
Post by amazon1988 » Tue May 14, 2019 7:55 am
This is how the key to version 8.1 should look
And the .reg file is different from the citect 2016 version (8.0)
longwangwl456
Post by longwangwl456 » Thu May 16, 2019 4:03 am
Hi cool running,
You run the CiUSAFE from citect 2016 or 2018 and find the right key just using the .reg file from above?
Very interesting. My test failed as CiUSAFE from citect 2016 cannot find any key based on the .reg file here.
My system is Win 7 64 bits.
Could you share your .reg file and your CiUSAFE.exe file to me?
cool_runnin
Post by cool_runnin » Sun May 19, 2019 5:27 pm
Hi longwangwl456:
You 've got all needed files in above replies.
1) Run devcom.exe as Administrator
2) Double click appropriate .reg file
3) Install multikey file
4) Reboot windows 7. You will be notified that the driver is not digitally signed (warning) but still reboot the system.
In windows 7 during rebooting keep pressing F8. This will take to you Advanced Boot Options menu. There, select the last option (Disable Driver Signature Enforcement).
Only then you will see in CIUSAFE.exe that you got your Citect registered.
So each time you start system you need to remember about F8 and you are all set.
amazon1988:
Maybe you share with us how on earth have you created .reg file for Citect SCADA 2018 ?
longwangwl456
Post by longwangwl456 » Mon May 20, 2019 2:57 pm
Thanks cool.
Still not working to me.
Here is my test result.
If I use CiUSAFE.exe from V7.2 then showing key found, good. That verified the multikey working properly. No diver signature problem.
If I use the original CiUSAFE.exe from Citect 2016 itself, then showing Error key, nothing found.
File size of CiUSAFE.exe from Citect 2016 is about 3M while the one from V7.2 only 1M. Therefore I think the problem may from CiUSAFE.exe itself. That's why I 'd like to have your CiUSAFE.exe to test in my system.
Thanks!
longwangwl456
Post by longwangwl456 » Mon May 20, 2019 2:59 pm
Or I can send you my Citect 2016 CiUSAFE.exe to test in your system.
ascii_192
Post by ascii_192 » Tue May 21, 2019 1:02 pm
here is crack with video instruction:
https://mega.nz/#!AfIRESZC!vcYwVKNYSGGj ... V6IkSyCZEw
longwangwl456
Post by longwangwl456 » Tue May 21, 2019 7:42 pm
Thanks ascii_192.
Unfortunately still not working for me.
MultiKey running properly as running CiUSAFE.exe from V7.2 can show "key found" but no use for Citect 2016.
Size of CiUSAFE.exe in Citect 2016 is 3130kb while in Citect V7.2 only about 1015kb.
Not sure where is the problem.
longwangwl456
Post by longwangwl456 » Tue May 21, 2019 10:10 pm
Update!
Redo everything on a new "clear" Win7 VM and finally it is working!
Thanks everyone.
bobahatop
Post by bobahatop » Sat Jun 08, 2019 10:10 am
Does it work for 2018?
longwangwl456
Post by longwangwl456 » Sun Jun 09, 2019 3:25 am
Don’t know. Have not tried 2018 yet.
mezippy
Post by mezippy » Sun Sep 22, 2019 6:09 pm
Hi All,
This threat has been excellent.
Thanks .
jotamarc
Post by jotamarc » Wed Mar 25, 2020 12:42 pm
Hi people,
I'm new in this forum!
I was searching information about Citect SCADA, 2016 version being more specific, and I've seen links cited in this forum were broken and I was wondering why. Making a quick research I've seen this software was bought by AVEVA and now it has to be downloaded on his website.
I left the links here below for you to download if you need:
And here the link for the download page in general, for searching updates and other possible versions you were looking for:
https://softwaresupportsp.aveva.com/#/producthub
There are also versions from 7.00 to 2015 named as Vijeo Citect, which it confuse me a lot, but maybe you would know better which is the version do you need.
Said all of this, I need your help for cracking this Citect SCADA 2016 version. I've seen a post in this forum talking about it, but these times Citect SCADA was a Schneider Electrics software yet.
Do someone of you in this forum has information about how to crack this newest version (2016, not interested in 2018) in Windows 10? if it was for Windows 7 would be great as well, I don't think I'm having troubles with Windows versions.
Thank you all, bye!
KaskadSD
Post by KaskadSD » Fri May 29, 2020 10:45 am
Hi!
Anybody know how activate AVEVA Citect SCADA 2018 R2?
I installed Citect SCADA 2018 R2 and activated it using activation method for Citect SCADA 2016. But Citect wrote me that my license didn't update for this version.
Maybe anybody have crack or activation method for AVEVA Citect SCADA 2018 R2?
