How to display multiple similar Graphic Objects better ?
Alex3110
Post by Alex3110 » Thu Aug 09, 2018 5:11 am
Hello, everybody !
I work with a project for TP1500 Comfort in TIA portal v.13 Profess.
I have 25 analog signals in my project.
I need to create a screen where the operators will input/change some parameters for analog signals (LL, L, H, HH limits), so I need 4 “I\O” fields for every analog signal.
Thus in the screen must be 25 tables with the same text fields absolutely, but the values in "I\O” fields must depend on certain analog signal which is displayed at a moment.
A question is how to organize everything better (less load to WinCC RT , more performance and efficiency).
