Siemens TI545
niksiz
Siemens TI545
Post by niksiz » Thu Mar 01, 2018 8:32 am
Hi all,
I have a problem with a TI545.
I see this model for firs time and have some questions about it.
First I need a software for it. I have found that TIsoft is obsolete.
Does someone have it? Or any other software?
Second question is about hardware.
PLC was without power for about six monts. After applying power BATT GOOD light went ON.
PLC GOOD and RUN leds were OFF.
I have tryed to reset by switching off the battery.
After this PLC GOOD also went ON.
But RUN is still OFF.
How to make it to go to RUN mode.
If I am not wrong the program can not be erased because battery is working, right?
destroy13
Re: Siemens TI545
Post by destroy13 » Wed Apr 11, 2018 7:16 pm
I use PLC WorkShop Suite for Siemens 505 from Fastrak. RUN issue is probably due to current program...
zuchciu104
Re: Siemens TI545
Post by zuchciu104 » Sun May 05, 2019 3:05 pm
TI 545 it's a old Texas Instrument line of PLC acquired by Siemens. Still accessible by TiSOFT dos base software.
or PLC Workshop windows base software. Both of those are only accessible by old Windows XP and below OS.
Let me know if you still have a issue with this.
