[LINK]: key and PLC-driver for PLC-ANALYZER pro 4 or 5
day2hack
Re: [LINK]: key and PLC-driver for PLC-ANALYZER pro 4 or 5
Post by day2hack » Mon Jan 09, 2017 6:11 pm
For a training test, I am in need of the PILZ drivers.
pls (sos)
TMS320F2812
Post by TMS320F2812 » Fri Sep 01, 2017 6:51 am
someone who have PLC ANALYZER PRO5 for S7 MPI/Profibus driver.
Pls. upload it again. I need to try use it with S7 MPI/DP.
slowak1982
Post by slowak1982 » Tue Sep 26, 2017 8:46 am
https://mega.nz/#!S9AWjDqJ!NMLCvwp3wez4 ... ZSkQvRYsFw
zip with all drivers, cracked dlls aso
Roof
Post by Roof » Wed Oct 25, 2017 9:39 am
Sorry. But archive is being downloaded with an error
Post by CoMod » Wed Oct 25, 2017 10:58 am
(not_allow)
All Ok
it very old archive from our site
check Mega plugin in your Firefox and dowloaded file
Roof
Post by Roof » Wed Oct 25, 2017 1:52 pm
No problems. Thank you. The file to open only 7Zip. RAR is not suitable.
andifmt
Post by andifmt » Fri Dec 08, 2017 11:10 am
Hello everyone,
I`m looking for the Phoenix Driver.
Please help.....
eujuiz
Post by eujuiz » Fri Jan 12, 2018 1:46 am
Even with the settings in the virtual machine is still giving dongle error.
I'll try to take it in the same hand.
I'm using vmware 12
(h)
eujuiz
Post by eujuiz » Fri Jan 12, 2018 1:53 am
I managed to run it on vmware 12 with windows xp, I had to edit a conditional jump inside the program font :D :D
henk
Post by henk » Fri Jan 12, 2018 10:13 am
@eujuiz
Can you explain how to do?
henk
Post by henk » Fri Jan 12, 2018 10:18 am
@eujuiz
Or may be better, can you share your VMware image?
xflash
Is PLC-ANALYZER pro 6 cracked available?
Post by xflash » Thu Jan 03, 2019 4:07 am
For S7-300,S7-400 PLC-analyzer pro 5 works fine. Is there any working cracked PLC-ANALYZER pro 6 ?
https://www.autem.de/download-content/a ... ro%206.pdf
It supports optimized data block access and cycle precise.
It is a pity build-in TIA Trace function could only record 3 minute.
Good luck to all in 2019!
freddo_Qian
Re: Is PLC-ANALYZER pro 6 cracked available?
Post by freddo_Qian » Sun Jan 06, 2019 2:57 am
i am looking for it too :D :D :D
Sarek
Post by Sarek » Fri Nov 08, 2019 8:53 am
i am looking for it too 8)
MORs
Post by MORs » Wed Jan 15, 2020 9:44 am
(sos) (sos) (sos)
Someone has a crack of Sps-analyzer v6.x???
MORs
Post by MORs » Fri Jan 17, 2020 1:33 pm
Pls-analyzer v 5.1, 5.3 works on win 7 & win 10 without VM
reedcat
Post by reedcat » Fri Jan 17, 2020 4:22 pm
If this is a question, the Analyzer 5.* works with Win 7 32 bit only (on this reason usually runs under VM)
MORs
Post by MORs » Fri Jan 17, 2020 6:46 pm
No, it's a fact
boont
Post by boont » Fri Apr 24, 2020 7:14 am
No ! Pls-Analizer pro v 5 does not work with win7. If you know how to do this, please tell me!
Installation error appears - 1628:Failed to complete installation.
reedcat
Post by reedcat » Tue May 05, 2020 7:50 pm
One more time: PLC Analyzer 5 works under Windows 7 32-bit only and doesn't work with Windows 7 64 -Bit (which is most common). Probably Step7 on that PC also required.
Out of them there is a way to start the Analyzer under virtual machine with Win7 (sure, 32-bit). Read this topic, pls, especially Page2
boont
Post by boont » Fri May 08, 2020 9:07 am
I'm sorry. All right you say. My carelessness )))
alpesh2111
Post by alpesh2111 » Sun Sep 06, 2020 10:07 am
PLC Analyzer PRO 5 is working on Windows 10 64 bit...no single issue
DenSad81
Post by DenSad81 » Sun Dec 13, 2020 4:56 pm
Good day to all. Can anyone help me?
I have a question.
In Readme standing: Run update 5.1.1 - but i found only 5.1.2. Is this a problem?
If i start the Programm, there was a error message (in german): Bitte legen Sie die Schlüsseldiskette ein oder schließen Sie den Dongle-Key an!
Einklaus
Post by Einklaus » Sun Apr 18, 2021 2:29 pm
Hello and Thanks,
I`m searching for the Logo Driver.
Hope anybody can help me (oo)
Kone
Post by Kone » Mon Apr 19, 2021 12:09 pm
Assuming I tried to install the program illegally, I might do the following:
0.: Download the cracked software from the Link which is already shared in this forum
1 .: Copy the complete folder (PLC-Analyzer 5) to your computer before you start the installation. Network drives often do not have administrator rights.
2 .: Install the WkRuntime using the administrator rights so that the WKWIN32.DLL and other Wibukey DLLs are automatically preinstalled in the correct storage locations
https://www.wibu.com/de/support/anwende ... tware.html
3 .: Install the PLC-Analyzer 5.0 with the help of the Setup.exe file and administrator rights, which is located in the "Setup" folder, skip the licence-management
4 .: Using the administrator rights, copy the files svcrypt.dll, syczpia.dll to ----> C: \ windows \ syswow64
5 .: Using administrator rights, copy the anawin.exe file to the PLC analyzer folder, which is located in the standard installation under C: \ Programs (86x) \ AUTEM \ PLC-ANALYZER pro 5
5 .: Using administrator rights, copy the driver.dll file to the PLC analyzer folder, which is located in the standard installation under C: \ Programs (86x) \ AUTEM \ PLC-ANALYZER pro 5 \ DRIVER
6 .: Run the update
7 .: Open Anawin and Analyze whatever there is to analyze :-)
Important:
I would not open the anawin.exe before the update has been carried out!
If you would have already made this mistake, you would have to completely uninstall the PLC analyzer.
This is possible with the Revo-Uninstaller program https://www.chip.de/downloads/Revo-Unin ... 91156.html. The corresponding setup file is included.
Of course, all of this is purely hypothetical
Greetings, Kone
alpesh2111
Post by alpesh2111 » Sat May 08, 2021 8:38 am
Do anybody have SIMOTION driver for PLC analyzer PRO 5?
reedcat
Post by reedcat » Sun Nov 07, 2021 7:58 pm
Dear friend, you have forget one small thing: on which Windows version(s) your have try this idea? :)
On my experience the last version is Win 7 32-bit. Till now all attempts to start Analyzer on 64-bit Windows have no result.
Kone
Post by Kone » Wed Mar 30, 2022 2:12 pm
Hello, I think this would work based on this hypothetical guide. Even for Windows 10 20H2 64-bit.
The main difference between the 32-bit and 64-bit installation would be the location of the .dll files.
For 32-bit systems, .dll must be copied to system32, for 64-bit systems to SysWow64.
You could also theoretically put the .dll files in both folders and optionally remove any unused .dll from your computer after it works.
You'd just have to make sure that you really have removed all regestry entries from previous attempts before you'd start over...
S4CABB
Post by S4CABB » Sun Nov 20, 2022 7:30 am
Hello EveryOne
Yesterday I managed to reinstall PLC ANALYZER 5.x on a HOST Windows 10 - 64 Bits without problem following the procedure described above.
Then upgrade to V5.8 latest version available on Autem...
Everything works with more than 10 different PLC Drivers...
Always on top this forum :haha:
busoco
Post by busoco » Mon Nov 28, 2022 7:16 am
Thank you for your information. I also just did it successfully :D (pgood) .
Can you please give your PLC drivers? I have only 6 drivers that uploaded on this forum.
Thank you in advance.
S4CABB
Post by S4CABB » Fri Dec 02, 2022 7:24 am
busoco
I send you a private message for these PLC Drivers
busoco
Post by busoco » Sat Dec 03, 2022 8:40 am
Thank you very much for the files.
I will test them on PLC.
(pgood) (pgood) (pgood) (pgood) (pgood)
(tyou) (tyou)
X200881
Post by X200881 » Mon Dec 26, 2022 9:13 am
Hello. Can you provide a link to a working program. I don't get out. Error "ODBC Runtime error (OxAZZZ)!" and the process hangs in memory. Win7 x64.
nawrokrz
Post by nawrokrz » Mon Jan 02, 2023 7:29 pm
Hi all,
I am looking for a driver MITSUBISHI MELSEC Q / A / FX for PLC-Analyzer 5. Can anyone help me, please? Thx.
X200881
Post by X200881 » Wed Jan 04, 2023 7:52 am
X200881
Post by X200881 » Thu Apr 13, 2023 6:48 am
Hi all,
Does it work PLC-Analyzer 5 for you on windows 10 64? I couldn't launch at all. (h)
Jia Bing Qi
Post by Jia Bing Qi » Sun Sep 24, 2023 12:00 pm
hello guys,I need PLC ANALYZER different PLC Drivers,can you give me the all?
after I updated to 5.8, the software can only be used on the day of the update, and once the time passes 24 o'clock, the software cannot be opened and used normally。I wonder how you can do it for unlimited time?
