It is currently Mon Jun 25, 2018 10:56 pm
Post new topic Reply to topic  [ 45 posts ]
PostPosted: Thu Aug 21, 2008 1:37 pm
Released for Delivery
http://support.automation.siemens.com/WW/view/en/29735640
What's New (English)
https://support.automation.siemens.com/WW/llisapi.dll/csfetch/29735640/WCFWhatsNewenUS.pdf
Die neuen Funktionalitäten von WinCC flexible 2008 (Deutsch)
https://support.automation.siemens.com/WW/llisapi.dll/csfetch/29735640/WCFWhatsNewdeDE.pdf
New
increased to 4096 Powertags
New RT license: SISLA9XRP40103.EKB "WinCC flexible 2008 Runtime (4096)"
EKB_Install_2008_08_20 wrote:
add only new Flex2008 keys to EKB_Install_2008_08_20
for options need use old keys
● Raised system limit to support 4096 tags on MP 377
Supported OS:
Microsoft Windows XP SP3/SP2
Microsoft Windows Vista Business (32 Bit), Ultimate (32 Bit) - NOT SP1 !
WinCC Flexible 2008
DVD ISO image (see how unpack viewtopic.php?t=6036)
12*204.800.000 + 126223 KB
[dead]
rapidshare.com [dead] (boom) (h)
------- If you have problems --------------------------------
one user wrote:
CRC error in the file encrypted WinCCflex2008.iso
WinCCflex2008.part13.rar
I self have downloaded, unpacked and installed this Flex without problems
You can try to download one part from Mirror
Check size of all parts (204.800.000)
and CRC (by Toptal Commander)
Code:
; Generated by WIN-SFV32 v1.0
; (Compatible: Total Commander 7.04)
WinCCflex2008.part11.rar D688CE9B
WinCCflex2008.part10.rar A4BBFF31
WinCCflex2008.part12.rar E6C4CC87
WinCCflex2008.part09.rar 26CABB5B
WinCCflex2008.part13.rar 6E4A577A
WinCCflex2008.part05.rar 2434C199
WinCCflex2008.part08.rar ED043A32
WinCCflex2008.part02.rar BE155780
WinCCflex2008.part04.rar D0B44BD0
WinCCflex2008.part01.rar BC3B6F85
WinCCflex2008.part07.rar 53A94639
WinCCflex2008.part06.rar 2135648C
WinCCflex2008.part03.rar 2429D3F2
viewtopic.php?f=30&t=218
Cumulative THANKS for uploader and Siemens Flex group
No need add new "Thanks Again"
Demo projects for SIMATIC Panels
http://support.automation.siemens.com/WW/view/en/22900091
 Post subject:
PostPosted: Fri Aug 29, 2008 6:29 am
3 versions in torrent
Siemens SIMATIC WinCC Flexible 2008 http://rutracker.org/forum/viewtopic.php?t=1249421
Siemens SIMATIC WinCC Flexible 2008 SP3 http://rutracker.org/forum/viewtopic.php?t=3957237
Siemens SIMATIC WinCC Flexible 2008 SP2 (Full DVD) http://rutracker.org/forum/viewtopic.php?t=3007619
direct link for torrent client
http://rapidshare.com/share/45225C09E4FC8614D8F8B97094603AF6
 Post subject:
PostPosted: Fri Sep 12, 2008 10:38 am
FAQ: Why can't you install the SQL server from WinCC V6.2 or WinCC V6.2 SP2 after installing WinCC flexible 2008?
http://support.automation.siemens.com/WW/view/en/30576253
Remedy:
You can only install the SQL server from WinCC V6.2 or WinCC V6.2 SP2 if the WinCC flexible instance of the Microsoft SQL Server 2005 Express Edition was deinstalled.
WinCC flexible 2008 does not have to be deinstalled.
Procedure:
1. deinstal Microsoft SQL Server 2005 Express Edition
2. Install WinCC V6.2 or WinCC V6.2 SP2
3. Start the "Setup.exe" file on the product DVD of WinCC flexible 2008 and execute the installation.
 Post subject:
PostPosted: Thu Nov 20, 2008 7:28 pm
– OP 73
– OP 73micro
– OP 77A
– TP 177A
– TP 177micro
– Basic Panels
WinCC flexible 2008.
● Errors during compilation
● Problems with DEMO mode
● Error installing MSDE
● Canceling "Save as version"
● Internal error
– Mobile Panel 277
– MP 277
– Mobile Panel 177 DP
– Mobile Panel 177 PN
– Mobile Panel 277
– OP 177B
– TP 277
– OP 277
– MP 177
– TP170A
– TP170micro
All CE devices are affected
Note
Hotfix 1 for WinCC flexible 2008
http://support.automation.siemens.com/W ... 08_HF1.exe
( 19486 KB )
● Error converting project.
may fail.
Russian wrote:
Настоятельно рекомендуется установить это обновление,
если у вас есть желание запускать примеры от прежних версий, выложенные на официальном сайте.
Иначе возможны проблемы вплоть до Синего Экрана Смерти = BSOD
 Post subject:
PostPosted: Sun Mar 15, 2009 11:45 am
Service Pack 1 for WinCC flexible 2008
http://support.automation.siemens.com/WW/view/en/34778772
http://support.automation.siemens.com/WW/llisapi.dll/csfetch/34778772/WinCCflexible2008_SP1.exe
1.330.906 KB = 1.3 GB !
PostPosted: Mon Jun 15, 2009 12:29 pm
Hotfix 5 for WinCC flexible 2008 Service Pack 1
http://support.automation.siemens.com/WW/view/en/36540041
Hotfix 3 for WinCC Flexible 2008 SP1
https://support.automation.siemens.com/WW/llisapi.dll/csfetch/36540041/WinCCflexible2008_SP1HF3.exe
Code:
This hotfix solves the following problems in Runtime and optimizes configuration scenarios:
● Restart of HMI device or exiting the simulation
The screen change from recipe view can result in a restart of the HMI device in some HMI
devices.
Certain configurations during simulation of HMI devices can exit the simulation.
Devices affected:
– OP 77A
– TP 177A
– KTP 178
– KTP400 Basic
– KTP600 Basic
– KTP1000 Basic
– TP1500 Basic
Hotfix 2 for WinCC Flexible 2008 SP1
https://support.automation.siemens.com/WW/llisapi.dll/csfetch/36540041/WinCCflexible2008_SP1HF2.exe
( 72853 KB )
Problems corrected in Hotfix 2
● Incorrect display of graphical elements
If you work with many graphical elements in WinCC flexible, the graphical elements are no longer displayed correctly.
● Error message while compiling
You will see the following error message during compilation of a comprehensive WinCC flexible project:
"The WinCC flexible Engineering System does not have sufficient memory to continue and must be shut down. Close all unnecessary applications and restart the
WinCC flexible Engineering System."
● Failed project transfer
If you have compiled a project with WinCC flexible Service Pack 1, it can no longer be transferred to the HMI device. The compiled project file ".fwx" is too large.
Hotfix 1 for WinCC flexible 2008 Service Pack 1
https://support.automation.siemens.com/WW/llisapi.dll/csfetch/36540041/WinCCflexible2008_SP1HF1.exe
( 72694 KB )
scenarios:
● Internal compiler error with tags with linked animations.
If an error occurs with tags with linked animations, the affected location is displayed.
● Conversion error opening projects created prior to WinCC flexible 2008 SP1.
Events at a tag with array elements are deleted during conversion.
● Incorrect references after conversion of projects created prior to WinCC flexible 2008 SP1.
The events at a tag with array elements deleted as a result of the conversion error are restored.
If you have configured a new event in a project that has already been converted, the old incorrect reference is deleted.
The affected tags are logged in the output window in either case.
● Long compile times in projects with numerous faceplate instances.
Runtime problems resolved and optimization of configuration scenarios with this hotfix:
● The "Transparent color" setting does not work on the "Graphic view" screen object on the
– OP 270
– TP 270
– MP 270
– C7-636
● Touch operation is not detected.
Touch operation is sporadically not detected on the following HMI devices:
– TP 177 4"
– OP 177B
– TP 177B
– TP 277
– Mobile Panel 177
– Mobile Panel 277, Mobile Panel 277 IWLAN
– MP 177
– MP 277
– MP 377
● The sound does not work on some of the HMI devices of the MP 377 series.
Add new images for fix problems.
 Post subject: Re: Installation problem
PostPosted: Fri Oct 02, 2009 12:06 pm
slinky wrote:
I have a problem when installing.
'Cannot create database' error when starting to install flex 2008.
Initially I had lots of problems installing .NET and SQL server, but they are installed OK now.
http://support.automation.siemens.com/WW/view/en/29420407
PostPosted: Sun Jan 24, 2010 4:45 pm
CoMod wrote:
RubberDuck wrote:
I have downloaded Winccflexible. 15 files with exe.001 ... exe.015 at the end.
I cannot extract the files. I have delete the end (001 - 015), I have rename in rar or zip. but all not working
See How unpack archive and CD-image (ISO, NRG) files http://plc.net.ru/viewtopic.php?f=2&t=6036
It's working
RubberDuck
PostPosted: Thu Feb 04, 2010 11:21 am
Demo projects for SIMATIC Panels (WinCC flexible 2008/STEP 7 Basic V10.5), Panel PC and WinCC flexible PC Runtime
Date: 2010-01-14
PostPosted: Thu May 06, 2010 10:44 am
WinCC flexible 2008 SP2
WinCC Flexible 2008 with SP2
Full DVD 3.6 GB
Torrent link http://rutracker.org/forum/viewtopic.ph ... 3#35797163
https://mega.co.nz/#F!2Rd0Ga5C!eB68tI3Qp6ep02jCUP6P8w
http://support.automation.siemens.com/WW/view/en/38612895
https://support.automation.siemens.com/WW/llisapi.dll/csfetch/38612895/WinCCflexible2008_SP2.zip
1.5 GB
About
http://support.automation.siemens.com/WW/view/en/38612975
Support for Microsoft Windows 7
WinCC flexible with Step7 Integration under Windows 7
SIMATIC Step7 V5.4 is not released for the operating system Microsoft Windows 7. It therefore is not possible to use WinCC flexible and Step7 in the integrated mode under Windows 7. For this a separate release will be carried out at a later time
2. New Functionality
Engineering and usability
● New menu command for clearing the list of most recently opened projects
● Object view shows additional information
– Tag comments
– Recipe number
Widescreen for PC Runtime
* 1440 x 900, 1680 x 1050, 1920 x 1080, 1920 x 1200
Enhancements for the Basic Panels
* new System functions
+ set Bit in Tag
+ reset Bit in Tag
+ invert Bit in Tag
* Retentive message buffer
* Number of configurable Tags
o KTP400 Basic: 250
o KTP600 Basic: 500
o KTP1000 Basic: 500
o TP1500 Basic: 500
* new communication driver
o Modicon Modbus TCP/IP
o Mitsubishi FX
o Omron Hostlink/Multilink
Sm@rtService/Sm@rtAccess
* reduced CPU-utilization due to Sm@rtServer
* automatic scaling between server and client
* improved usability in configuration dialogs
Support of new devices
ALM v5.0 - add support Windows 7.
Tested - Ok.
PostPosted: Sun May 09, 2010 10:32 pm
jahman wrote:
After installing SP2 ALM shows me 4 missing keys( I have used Simatic_EKB_Install_2010_03_20, maybe there is a newer one).
The missing keys:
Family-----------------------------Product--------------------------Version
SIMATIC HMI-------------WinCC flexible /Audit for PC--------------1.3
SIMATIC HMI-------------WinCC flexible /Recipes for PC-----------1.3
SIMATIC HMI-------------WinCC flexible /OPC-Server for PC-------1.3
SIMATIC HMI-------------WinCC flexible /Sm@rtAccess for PC-----1.3
EKB install has only Version 1.0. WinCCFlexible is running but maybe there some parts which doesnt work without these keys.
for testing Simatic_EKB_Install_2010_05_09.zip
wait report
! all previous versions may fail if the installed the new version of the ALM v5 keys - type v5!
error will be corrected in future versions.
Because of the new release ALM v5 may be many intermediate versions as far as finding new challenges.
! у всех предыдущих версий возможна ошибка, если на диске установлены ключи нового ALM v5 :(
ошибка будет устранена в следующих версиях.
В связи с выходом новой версии ALM v5 возможно будет много промежуточных версий по мере нахождения новых проблем.
PostPosted: Mon May 31, 2010 9:48 am
Dear friends,
some of my collegues have installed Flex2008 + SP2 while I stayed at SP1 + HF5. It looks fine and works perfectly, but it seems the projects are not compatible, other guys can open mine, but I cannot open theirs. IF it's true then we have a problem... Un-documented, of course.
I wonder if anyone else has the same experience or can post a link.
PostPosted: Mon May 31, 2010 12:12 pm
marek_gabriel wrote:
Dear friends,
Flex2008 SP2 use new database engine
for this it convert old Flex2008 SP1 project to new database
Use Save as...
Bugs
Invalid polygons in Editor mode
Russian forum wrote:
Впечатления от СП2, неприятные
0. Открыл проект из СП1 и певрое, что бросилось в глаза - рваные линии полигонов - стал разбираться, ведь в СП1 это же выглядело нормально.
1. Такое впечатление, что графический редактор глючит - очень трудно добиться видимости всех вертикальных/горизонтальных линий полигонов в режиме Редактора,
при этом они отображаются в режиме Runtime.
2. Второй раз выскочило пугающее предупреждение во время нажатия правой кнопки на группе выделенных примитивов для вызова всплывающего меню.
К счастью не катастрофичное - программа после "Ок"нормально работает дальше.
Image Image
No one side of polygon in Editor mode. In Runtime all Ok.
Group gluck
PostPosted: Thu Jun 10, 2010 11:46 pm
Full DVD 3.6 GB ISO image
Image Torrent link http://rutracker.org/forum/viewtopic.php?p=35797163#35797163
Update13 for WinCC flexible 2008 SP2 (HotFix 13 include ALL previous Update 1.. 12)
(sdown)
http://support.automation.siemens.com/WW/view/en/43412059
https://support.automation.siemens.com/WW/llisapi.dll/csfetch/43412059/WinCCflexible2008_SP2Upd13.zip
108 MB
PostPosted: Sun Oct 31, 2010 1:28 pm
benthouse wrote:
Anybody who has an english torrent link available?
Service http://translate.google.com for view russian/chinese pages
http://translate.google.com/translate?hl=ru&sl=ru&tl=en&u=http%3A%2F%2Frutracker.org%2Fforum%2Fviewtopic.php%3Ft%3D3007619
It would be very useful for me too!!
Thanx
PostPosted: Sat Mar 05, 2011 1:31 pm
Demo projects for HMI Panels at WinCC (TIA Portal) for Basic Panels, Comfort Panels and WinCC Runtime Advanced (TIA Portal)
SIMATIC HMI WinCC flexible 2008 Getting Started - First-Time Users
http://support.automation.siemens.com/WW/view/en/18660846
Gauge Controls for Basic Panels.
http://support.automation.siemens.com/WW/view/en/48052573
PostPosted: Fri Feb 24, 2012 11:49 am
WinCC Flexible 2008 with SP3 for XP32 and W7 32/64 / EURO+ASIA
About http://support.automation.siemens.com/WW/view/en/57267466
SIMATIC WinCC flexible 2008 SP3 TRIAL Download (sdown)
http://support.automation.siemens.com/WW/view/en/100777999
TRIAL = FULL version
TRIAL = ПОЛНАЯ версия
WinCC flexible 2008 SP3 Update5
http://support.automation.siemens.com/WW/view/en/58860033
https://mega.co.nz/#F!nQUUEQLR!ONJao5tj02dy4BuGsQuqxg
(dlink)
Torrent
RapidShare Package: [dead]
30 * 100 Mb + 12.57 Mb
01 http://depositfiles.com/files/hx7s9t12u
02 http://depositfiles.com/files/p2tkj4iiv
03 http://depositfiles.com/files/07y6z9hf7
04 http://depositfiles.com/files/ymofgfdiq
05 http://depositfiles.com/files/lympogvdo
06 http://depositfiles.com/files/4q7erpriq
07 http://depositfiles.com/files/6lcii7239
08 http://depositfiles.com/files/kpevwry8f
09 http://depositfiles.com/files/am9cxhh0v
10 http://depositfiles.com/files/s55eehof1
11 http://depositfiles.com/files/w7zbg1v42
12 http://depositfiles.com/files/wvm420zw7
13 http://depositfiles.com/files/y3zbcpuaa
14 http://depositfiles.com/files/m1f2cvrb2
15 http://depositfiles.com/files/fawfuczd1
16 http://depositfiles.com/files/l1xgazzgc
17 http://depositfiles.com/files/4p4cvtac1
18 http://depositfiles.com/files/rmxbjnf2d
19 http://depositfiles.com/files/rxypa303l
20 http://depositfiles.com/files/kentff46k
21 http://depositfiles.com/files/l01o030n1
22 http://depositfiles.com/files/67t771tqo
23 http://depositfiles.com/files/hj7pe8c4e
24 http://depositfiles.com/files/zvl38yz0s
25 http://depositfiles.com/files/97jrhesk9
26 http://depositfiles.com/files/4sj1yxs64
27 http://depositfiles.com/files/ku6rffq2q
28 http://depositfiles.com/files/yn2832bml
29 http://depositfiles.com/files/9leuevd15
30 http://depositfiles.com/files/5dzxev5pi
or mirror
http://www.4shared.com/rar/NGn-691T/WinCCFlex_2008_SP3_CSApart01.html
http://www.4shared.com/rar/KR1PT7Gk/WinCCFlex_2008_SP3_CSApart02.html
http://www.4shared.com/rar/xXZgaly_/WinCCFlex_2008_SP3_CSApart03.html
http://www.4shared.com/rar/6YaYd-cW/WinCCFlex_2008_SP3_CSApart04.html
http://www.4shared.com/rar/ZcMchhhb/winccflex_2008_sp3_csapart05.html
http://www.4shared.com/rar/lDsy_HmV/WinCCFlex_2008_SP3_CSApart06.html
http://www.4shared.com/rar/742W5QI9/WinCCFlex_2008_SP3_CSApart07.html
http://www.4shared.com/rar/kHLawM20/WinCCFlex_2008_SP3_CSApart08.html
http://www.4shared.com/rar/PWoWACYv/WinCCFlex_2008_SP3_CSApart09.html
http://www.4shared.com/rar/5idnnTPI/WinCCFlex_2008_SP3_CSApart10.html
http://www.4shared.com/rar/iecoP8Pz/WinCCFlex_2008_SP3_CSApart11.html
http://www.4shared.com/rar/wNYGKOEy/WinCCFlex_2008_SP3_CSApart12.html
http://www.4shared.com/rar/XK_NMBWi/WinCCFlex_2008_SP3_CSApart13.html
http://www.4shared.com/rar/PJtQuaru/WinCCFlex_2008_SP3_CSApart14.html
http://www.4shared.com/rar/V-SYDgJ2/WinCCFlex_2008_SP3_CSApart15.html
http://www.4shared.com/rar/nmIJKtFi/WinCCFlex_2008_SP3_CSApart16.html
http://www.4shared.com/rar/lha93Qf9/WinCCFlex_2008_SP3_CSApart17.html
http://www.4shared.com/rar/QSAmrDPJ/WinCCFlex_2008_SP3_CSApart18.html
http://www.4shared.com/rar/uocZ_kd_/WinCCFlex_2008_SP3_CSApart19.html
http://www.4shared.com/rar/BQMF5tUn/WinCCFlex_2008_SP3_CSApart20.html
http://www.4shared.com/rar/INV58XuU/WinCCFlex_2008_SP3_CSApart21.html
http://www.4shared.com/rar/yofyiBCb/WinCCFlex_2008_SP3_CSApart22.html
http://www.4shared.com/rar/SLgdkl3b/WinCCFlex_2008_SP3_CSApart23.html
http://www.4shared.com/rar/g9sM99VU/WinCCFlex_2008_SP3_CSApart24.html
http://www.4shared.com/rar/zjNuSIB6/WinCCFlex_2008_SP3_CSApart25.html
http://www.4shared.com/rar/EjRwHdSh/WinCCFlex_2008_SP3_CSApart26.html
http://www.4shared.com/rar/Y37aHNMh/WinCCFlex_2008_SP3_CSApart27.html
http://www.4shared.com/rar/vPohci4p/WinCCFlex_2008_SP3_CSApart28.html
http://www.4shared.com/rar/s1xviUBX/WinCCFlex_2008_SP3_CSApart29.html
http://www.4shared.com/rar/nzyagE2W/WinCCFlex_2008_SP3_CSApart30.html
05568ab291f94af869872ade2f7358e6 *WinCCFlex_2008_SP3_CSA.part01.rar
d34638a7a4676543e26871b8da84b3fb *WinCCFlex_2008_SP3_CSA.part02.rar
8b25f2c76945f033646b13804b3ad81e *WinCCFlex_2008_SP3_CSA.part03.rar
482c8ad87b9aeec3298224b52b903b69 *WinCCFlex_2008_SP3_CSA.part04.rar
7cd8d73e88ff7cc14f32f3ed1b4b091c *WinCCFlex_2008_SP3_CSA.part05.rar
19037eef8169f6f732c28485b8f74775 *WinCCFlex_2008_SP3_CSA.part06.rar
806053c9c71ab10be5852b2de429446c *WinCCFlex_2008_SP3_CSA.part07.rar
a4f6edd9c4648301b3d6ea50e0dc8d38 *WinCCFlex_2008_SP3_CSA.part08.rar
7146110da836583d047404a831026c56 *WinCCFlex_2008_SP3_CSA.part09.rar
e883e82e325dbc80d89b1bed61b90d8f *WinCCFlex_2008_SP3_CSA.part10.rar
675dbaf1e9eae60ba0566bcfe4ddb205 *WinCCFlex_2008_SP3_CSA.part11.rar
1ad647310e552503902133bb12a1060a *WinCCFlex_2008_SP3_CSA.part12.rar
154aebe3780354e3dea488cb13f7b677 *WinCCFlex_2008_SP3_CSA.part13.rar
c81456191bdd32f1ad82b7f0917ac979 *WinCCFlex_2008_SP3_CSA.part14.rar
5e582cccde74a4b7340ebbcb192d2a18 *WinCCFlex_2008_SP3_CSA.part15.rar
ee0bcffe3b818cdad1173dc3cfe70367 *WinCCFlex_2008_SP3_CSA.part16.rar
9dd7766197c76b8bfa625835948a1529 *WinCCFlex_2008_SP3_CSA.part17.rar
070ff563d224fab7bd1e71bbc35e80aa *WinCCFlex_2008_SP3_CSA.part18.rar
c26e121b25a6e12d2810708d7cef2ac2 *WinCCFlex_2008_SP3_CSA.part19.rar
daa43f9505df2035864e09a449ca08bf *WinCCFlex_2008_SP3_CSA.part20.rar
2908bb849bf82fee4d868a651e2f4720 *WinCCFlex_2008_SP3_CSA.part21.rar
545e97cebb7b2c41ab5e1dce10751e21 *WinCCFlex_2008_SP3_CSA.part22.rar
787c7314ff36194df26f54f02aa53c9d *WinCCFlex_2008_SP3_CSA.part23.rar
f8c8a5c1de0bd6a65397c12cafd25fa3 *WinCCFlex_2008_SP3_CSA.part24.rar
a97145aabfe47072a7b6c2b552debeeb *WinCCFlex_2008_SP3_CSA.part25.rar
0dc730878f5965a6dd7d58ba7a3a08c8 *WinCCFlex_2008_SP3_CSA.part26.rar
34b0d38afd6c5c1a566cfa5706d508ea *WinCCFlex_2008_SP3_CSA.part27.rar
50133237492181eddaa57a75cca1b549 *WinCCFlex_2008_SP3_CSA.part28.rar
f0f5ea2714c9e399c82514c55d6b529f *WinCCFlex_2008_SP3_CSA.part29.rar
b46156675bc45fb95fbfcc15a349c1cc *WinCCFlex_2008_SP3_CSA.part30.rar
(pgood)
Home Edition compatible
Image Image Image
PostPosted: Tue May 15, 2012 9:53 pm
Update 2 for WinCC flexible 2008 Service Pack 3
(sdown) http://support.automation.siemens.com/WW/view/en/58860033
https://support.automation.siemens.com/WW/llisapi.dll/csfetch/58860033/WinCCflexible2008_SP3Upd2.exe
160 MB
PostPosted: Tue May 22, 2012 10:14 pm
SHKODRAN wrote:
I have installed this version , everything is working very well , but I don't find the "Migration" tool installed?
Wincc installation is finished correctly , without any problem!
How I can convert Protool 6.03 project to this Wnicc 2008?
ReRead about http://support.automation.siemens.com/WW/view/en/57267466
about ProTool Migration wrote:
ProTool Migration:
Because of the neccessary changes for the 64 Bit support under Windows 7, the ProTool migration cannot be offered any more with Service Pack 3 for WinCC flexible 2008.
Install WinCC flexible 2008 SP2 on VirtualBox.org and use Migration (h)
PostPosted: Sat Jun 09, 2012 1:16 am
elcboy wrote:
how can i find the crack of wincc flexible 2008 sp3 ???
i need this crack !
help me please
PostPosted: Tue Dec 25, 2012 6:43 pm
PostPosted: Sun Dec 29, 2013 1:23 pm
Date:2013-12-19 Update 4 for WinCC Flexible 2008 SP3
http://support.automation.siemens.com/WW/llisapi.dll/csfetch/58860033/WinCCflexible2008_SP3Upd4.zip
434 MB
+ patch for Update 4 :)
http://support.automation.siemens.com/WW/llisapi.dll/csfetch/58860033/WCF2008_SP3_Upd4_Patch_ID955999.zip
PostPosted: Sat Aug 16, 2014 5:04 pm
Is it possible to get Service pack 3 for wincc flex 2008 alone? I have Winccflex 2008 SP2 already installed and I would like to upgrade existing installation.
PostPosted: Fri Sep 05, 2014 6:21 am
PostPosted: Sat Sep 20, 2014 10:21 pm
guzo007 wrote:
hi all
the download links dont work!
can i have please a new link to download wincc flexible sp3 und crack?
please help me
all link ?
optimal to use torrent http://rutracker.org/forum/viewtopic.php?t=3957237
or send private request in Private Message for private link to Mega
anti-abuse firewall (h)
PostPosted: Tue Sep 23, 2014 4:21 pm
PostPosted: Fri Nov 28, 2014 10:15 am
Hi Did you get the Service pack 3 file alone. I am also looking for the same.
PostPosted: Mon Jan 26, 2015 10:09 am
In some Geyrope countries Mega blocked at the level of a democratic government as sanctions against Russia.
Use proxy for download from blocked sites
or Torrent
В некоторых странах Гейропы Мега заблокирована на уровне демократического правительства в качестве санкций против России
Триал есть полнофункциональная версия, идентичная коробочной.
PostPosted: Sat Feb 28, 2015 4:23 pm
salphonse wrote:
I didn't. I had installed wincclfex 2008 SP3. It has sensed that SP2 is installed, then it removed winccflex, reboot the PC and it installed SP3. Thanks god there were no problems and now it works with SP3.
PostPosted: Tue May 05, 2015 3:29 pm
Full DVD 3.6 GB
1.5 GB
About
– Tag comments
– Recipe number
+ set Bit in Tag
+ reset Bit in Tag
+ invert Bit in Tag
o KTP400 Basic: 250
o KTP600 Basic: 500
o TP1500 Basic: 500
o Mitsubishi FX
Tested - Ok.
Hello, download the wincc flex sp2 in winrar format; It requires password to unzip. Could you help me. Thanks in advance
PostPosted: Tue May 05, 2015 3:34 pm
PostPosted: Sat May 23, 2015 12:37 am
Dears, I need pasword as well Please woulc you advice to me as well.
PostPosted: Mon Aug 03, 2015 10:50 am
WinCC_flex_2008_SP2.part04.rar: Checksum error in the encrypted file WinCC_flex_2008_SP2.iso. Corrupt file or wrong password.
PostPosted: Mon Nov 30, 2015 9:40 pm
Hello to all!
I think that the password is: plcforum
Try and answer me.
PostPosted: Wed Jan 13, 2016 5:52 pm
nope everything okay the password was wrong it is :flex2008SP2
Good luck
PostPosted: Tue May 31, 2016 6:55 pm
Update7 for WinCC flexible 2008 Service Pack 3
https://support.industry.siemens.com/cs/document/58860033/update-for-wincc-flexible-2008-service-pack-3?dti=0&dl=en
PostPosted: Thu Jun 23, 2016 9:44 pm
Full DVD 3.6 GB
1.5 GB
About
– Tag comments
– Recipe number
+ set Bit in Tag
+ reset Bit in Tag
+ invert Bit in Tag
o KTP400 Basic: 250
o KTP600 Basic: 500
o TP1500 Basic: 500
o Mitsubishi FX
Tested - Ok.
part 9 in mega with error! (temporary error??)
PostPosted: Thu Aug 31, 2017 6:06 pm
SIMATIC WinCC flexible 2008 SP5 TRIAL Download is available.
(pm) (suc) (thnx) (tyou)
(sdown) https://support.industry.siemens.com/cs/document/100777999/simatic-wincc-flexible-2008-trial-download
(sdoc) https://support.industry.siemens.com/cs/document/109749111/delivery-release%3A-service-pack-5-for-simatic-wincc-flexible-2008
WinCC flexible 2008 SP5 supports the following Operating Systems
Engineering System:
Windows 7 (32 Bit, 64 Bit)
Windows 7 Ultimate/Enterprise SP1
Windows 7 Professional SP1
Windows 10 (64 Bit)
Windows 10 Professional
Windows 10 Enterprise
Windows 10 LTSB Enterprise
Runtime System:
Windows 7 Embedded Standard (32 Bit) *)
Windows 7 Embedded Standard mit SP1 (32 Bit) *)
Windows 10 (64 Bit)
Windows 10 IoT LTSB Enterprise *)
The license keys from WinCC flexible 2008, 2008 SP1/SP2/SP3 can be used without any change for WinCC flexible 2008 SP5 too.
PostPosted: Thu Aug 31, 2017 6:44 pm
Torrent https://rutracker.org/forum/viewtopic.php?t=3957237
Direct link for torrent client https://mega.nz/#F!Ww9SCCZQ!6NhIu768fib7w2DUFu0wPw
PostPosted: Fri Sep 01, 2017 8:01 pm
I need the two exe files from the Trial download.
SIMATIC_WinCC_flexible_2008_SP5_CSA.exe (2,7 MB)
SIMATIC_WinCC_flexible_2008_SP5_Runtime.exe (2,7 MB)
No torrent download links.
exe only packed to ZIP
https://mega.nz/#F!MCBTiJqK!5OY1PRyqHZn-hm7FPlzMJg
PostPosted: Fri Sep 01, 2017 9:27 pm
Thank you very much.
Greatings and I wish you a nice weekend....
Corosop15
PostPosted: Fri Sep 01, 2017 11:15 pm
WinCC Flexible 2008 SP5 have new format incompatible with WinCC Flexible 2008 SP3 (boom) (h)
WinCC Flexible 2008 SP5 имеет новый формат несовместимый с WinCC Flexible 2008 SP3
PostPosted: Tue Jan 30, 2018 7:08 pm
Good luck
Thank you!!! (tyou) (tyou) (tyou) (tyou) (thnx)
PostPosted: Mon Jun 04, 2018 2:47 pm
Link wrote:
The missing keys:
wait report
Any solution for above problem ?
i got this message and i think it's related to same above problem
WinCC flexible / Sm@rtService for PC-RT and WinCC flexible / Sm@rtAccess for PC-RT
i checked last Sim_EKB_Install
License manager
PostPosted: Mon Jun 04, 2018 3:47 pm
:anon: ReRead Help file - no need install ALL keys !!!
:anon: Install only 1 required key for option with major version number
(sfaq) How can you deactivate the Trial License when the message appears indicating that the Trial License has expired, although the Floating License has been installed?
https://support.industry.siemens.com/cs/document/24200966
