Patch EPLAN P8 (V1.8-V2.7) 2018-12-16
Тools, Elcad, Eplan, ...
PDLFFALF
Post by PDLFFALF » Thu Aug 03, 2017 2:25 pm
http://eplan-eb2.ys168.com/
van8x10
Re: EPLAN P8 2.7 Crack
Post by van8x10 » Thu Aug 03, 2017 3:17 pm
Gr8! Thank PDLFFALF!
Sprudel1968
Post by Sprudel1968 » Thu Aug 03, 2017 5:57 pm
Have you a version.dll for EPlan 2.7?
Sprudel1968
Post by Sprudel1968 » Thu Aug 03, 2017 6:00 pm
The patch also works under windows 10???
Sprudel1968
Post by Sprudel1968 » Thu Aug 03, 2017 6:06 pm
SN-U10066.EGF would be good for versions 2.5 and 2.6 to work again.
van8x10
Post by van8x10 » Fri Aug 04, 2017 1:37 am
@Sprudel1968:
Q1: The patch also works under windows 10???
A1: Yes, for my Windows 10 64bit Pro, newest updated version!
Q2: Have you a version.dll for EPlan 2.7?
A2: I'm using the file included in patch files for EPLAN P8 v2.1-v2.6, shared by PDLFFALF!
Q3: SN-U10066.EGF would be good for versions 2.5 and 2.6 to work again?
A3: No, after patching, SN-U10066.EGF would be removed, and replaced with SN-U10225.EGF, so EPLAN P8 Electric v2.6 can't work, but Propanel v2.6 addon still works!
Thank Sprudel 1968 for sharing, so come on, other parts of EPLAN P8 v2.7 please! :D
van8x10
Post by van8x10 » Fri Aug 04, 2017 2:51 am
van8x10 wrote:@Sprudel1968:
(sorry)
Sorry, this is for the first patch of Mr PDLFFALF. I've just tested with newest patch that PDLFFALF updated and SN-U10066 is good for v2.6 and v2.7 to work!
Hat off and thank Mr PDLFFALF again! (thnx) (oo) (gpost) (tyou)
goranv90
Re: Patch EPLAN P8 (V1.8-V2.7)
Post by goranv90 » Tue Aug 22, 2017 9:18 am
10 days ago, I have installed EPLAN 2.6 with crack posted on this forum and everything working perfect.
Now, I am trying to install 2.7 version (on other PC), but when I use this crack (the same way as I did for v2.6 and it is working), I cannot start EPLAN. It is written that dongle is not recognized and some possible causes.
Anyone have idea how to avoid this dongle problem, or what am I doing wrong this time?
Thanks in advance.
van8x10
Post by van8x10 » Sat Aug 26, 2017 3:23 am
The file HASPUserSetup.exe included in the patch files of Mr PDLFFALF is old version! It is not good for Windows 10 Pro Version 1703. Pls replace by the new one from https://sentinelcustomer.gemalto.com/se ... =all&t=all (Sentinel HASP/LDK - Windows GUI Run-time Installer, Version 7.60, Released 19 July 2017)
igoruha
Post by igoruha » Mon Aug 28, 2017 11:22 am
Installed this crack on Eplan 2.5 and 2.6. I did everything according to the instructions, but the problem with the lags is not solved. Help....p.s. OS - Win7
gregar
Post by gregar » Tue Aug 29, 2017 6:06 am
igoruha wrote:Installed this crack on Eplan 2.5 and 2.6. I did everything according to the instructions, but the problem with the lags is not solved. Help....p.s. OS - Win7
I have the same problem with delays in Win 10 Pro 64 Bit Spain. Any decision please.
igoruha
Post by igoruha » Wed Aug 30, 2017 4:12 am
Installed 2.7. (Win7 64 bit). Did version.dll tried to add a visit to the site, but does not affect the download. It's like the system doesn't see my version.dll... it works, just delay every 60 seconds not pass. Help....
van8x10
Post by van8x10 » Mon Sep 11, 2017 6:08 pm
igoruha wrote:Installed 2.7. (Win7 64 bit). Did version.dll tried to add a visit to the site, but does not affect the download. It's like the system doesn't see my version.dll... it works, just delay every 60 seconds not pass. Help....
Read the file 'Version.dll Creator Steps.docx' first. Do exactly the instruction!
igoruha
Post by igoruha » Wed Sep 13, 2017 10:26 am
All right. Antivirus prevented. Thanks for the reply.
sventek
Post by sventek » Sun Sep 17, 2017 6:27 am
I'm using Win10 Enterprise built 1703, but I can't update the virutal USB drive in the device manager (according to the patch instructions point 7, it won't work with running the install.cmd either).
Does anyone have a solution?
Thanks a lot.
sventek
Burned Electrician
Post by Burned Electrician » Sun Nov 19, 2017 5:05 pm
Can I use this crack on windows 8.1? Because inside the txt there are instructions for 7 and 10
Oll Bell
Post by Oll Bell » Thu Nov 23, 2017 12:02 am
PDLFFALF wrote:Patch EPLAN P8 (V1.8-V2.7)
how use the patch "Patch EPLAN P8 (V1.8-V2.7)" for "Electric P8 2.7.3.11418" on windows 7?
I did according the description, but unfortunately.
WIN 7 X64 Patch Instructions:
7: Reboot.
Wath is " Use the version.dll creator"?
van8x10
Post by van8x10 » Thu Nov 23, 2017 7:36 am
1: Read file 'Version.dll Creator Steps.docx
2: Run file 'PYG_DLL_Patcher_x64.exe' in folder 'version.dll Creator'
Oll Bell
Post by Oll Bell » Thu Nov 23, 2017 8:15 am
Thank you.
First i used the "old" File "version".
Nоw create the new "version" and use it. But is unfortunately to.
sidetrax
Post by sidetrax » Tue Dec 05, 2017 11:58 am
Anyone else getting the following message when trying to connect to the ePlan Data Portal?
"Dear EPLAN Data Portal user, unfortunately there is a problem with your dongle. Please get in contact with your local helpdesk for further information."
I'm using HASPUser_Setup v7.60 for Windows 10, because the one provided with the crack does not work on Windows 10.
sopoed
Post by sopoed » Fri Dec 08, 2017 5:07 pm
Has anyone put this patch running in eplan 2.4? I'm trying to put it running without success. I'm using Win7 64bits.
Thank you.
dimigav
Post by dimigav » Tue Jan 23, 2018 12:49 pm
This patch works on Windows 2012 R2?
I saw MultiUSB errors.
adaptine
Post by adaptine » Thu Jan 25, 2018 9:15 am
EPLAN does not start? This is how you can temporarily restart EPLAN!
The installation of the Microsoft Update „January Patch Day“ currently has the effect that several EPLAN products can not be started afterwards. This includes all products which use the EPLAN Licence Manager and / or the EPLAN Licence Client. As a rule it is, however, possible to resolve the afore-mentioned problem at short notice by temporarily de-installing the patch, i.e., the EPLAN products can be started again. At this point EPLAN explicitly points out that this suggested resolution is merely a tip and that the realization of the suggested solution is made without liability and at your own risk. So please evaluate for your company if the suggested solution constitutes a temporarily viable option for you.
EPLAN is already in close contact with Microsoft and is working intensely on a sustainable solution which guarantees the customary operating ability of the EPLAN products after the installation of the patch. We will inform you immediately as soon as we can supply such a sustainable solution.
You can temporarily solve this problem as follows:
Is the following error message displayed during the launch of your EPLAN software?
If so, please check whether one of the following patches is installed on your system. After de-installing the patch corresponding to your operating system you should be able to start the EPLAN software as usual.
Windows 10 1709 (KB4056892)
https://support.microsoft.com/en-us/hel ... -kb4056892
Windows 10 1703 (KB4056891)
https://support.microsoft.com/en-us/hel ... -kb4056891
Windows 8.1 (KB4056898)
https://support.microsoft.com/en-us/hel ... -kb4056898
Windows 7 (KB4056897)
https://support.microsoft.com/en-us/hel ... -kb4056897
Windows Server 2016 1709 (KB4056892)
Windows Server 2012 (KB4056899)
https://support.microsoft.com/en-us/hel ... -kb4056899
An overview on all further available updates for „January Patch Day“ by Microsoft can be found here:
https://www.catalog.update.microsoft.co ... ?q=2018-01
van8x10
Post by van8x10 » Fri Feb 23, 2018 4:26 am
adaptine wrote:EPLAN does not start? This is how you can temporarily restart EPLAN!
The installation of the Microsoft Update „January Patch Day“ currently has the effect ....
This issue has been solved with Cumulative Update for Windows 10 (1709) (2018/02) KB4074588 and EPLan 2.7 P8 HF2 (Build 11561)
covagashi
Post by covagashi » Tue May 15, 2018 5:31 am
I update the version 2.7 HF2 to 2.7 HF3 and now I'm having a lot of lag when before I haven't.
Even I'm creating a new version.dll I still having a lot of lag. Someone have a good version.dll that is working?
JustMe007
Post by JustMe007 » Thu Jun 14, 2018 1:49 pm
Did someone succeeded with 2.7 HF3 without lags?
covagashi
Post by covagashi » Thu Jun 14, 2018 2:45 pm
JustMe007 wrote:Did someone succeeded with 2.7 HF3 without lags?
I did.
Just need unistall the new Client Service and go back to 9.1.15.30800
For know your client version go to Help--->information ---> System information
JustMe007
Post by JustMe007 » Thu Jun 14, 2018 10:01 pm
Thanks,
Yes, I'm with newer version(9.1.15.31700), where can I find this version (9.1.15.30800)?
covagashi
Post by covagashi » Fri Jun 15, 2018 5:40 am
JustMe007 wrote:Thanks,
Run setup.exe
C:\Program Files\EPLAN\Setup Manager\2.7.3\Bin
and unistall the new version of the client service.
For install i dont remmeber if i get from download.exe (C:\Program Files\EPLAN\Download Manager\2.7.3\Bin)
or i just download again eplan and install only the client service.
EPLAN:
https://mega.nz/#!sI42hJKA!PsBmtYd8YPJr ... kUHJP9cvKs
JustMe007
Post by JustMe007 » Fri Jun 15, 2018 8:41 am
Thank you for your help but unfortunately nothing changed.
Now I'm with License Client 9.1.15.30800, tried version.dll from your link, tried creating a new one (from the link in the first post).
For an experiment I even tried to allow "patch successful visit the site" and "patch successful msg" but nothing happens - there's no message nor a site opens. So maybe the dll is not loading correctly?
I don't know if this is causing my problem but when creating dll and when I load "eplan 2.7.xml" a message appears:
You have selected the patch file for subsidiary
1.Please fill in the correct host name
2.Please check dynamic base address[Common sense]!
3.Make sure the timing of the DLL is loaded crack and choose a good API HOOK!
4.this option open After Can not To Host EXE Conduct patch
I'm with Windows 10 with all updates, I use Avast which I disable for the tests.
wormalmeida
Post by wormalmeida » Fri Sep 21, 2018 6:12 pm
JustMe007 wrote:Thank you for your help but unfortunately nothing changed.
Hey, Im with the same problem. Anyone knows how to solve it?
SStasL
Re: Patch EPLAN P8 (V1.8-V2.7) 2018-12-16
Post by SStasL » Fri Dec 21, 2018 12:08 pm
Who can redirect me to eplan 2.8 crack?
juanmemo
Post by juanmemo » Thu Jan 03, 2019 12:36 pm
SStasL wrote:Who can redirect me to eplan 2.8 crack?
EPLAN has changed the validation process and there is no dongle needed anymore. The new crack is going to take a long time...
Luca
Post by Luca » Thu Jan 03, 2019 2:17 pm
...If ever :x
djto
Post by djto » Thu Jan 03, 2019 4:28 pm
...If ever :x
Please put the eplan 2.8 download (dlink)
bloemp
Post by bloemp » Tue Feb 19, 2019 12:21 pm
Hi All,
I've created a new version.dll for the latest version of Eplan 2.7 HF5,
this should remove the lag (Atleast it does for me :D ).
Hopefully you will find it usefull!
https://mega.nz/#!D3Aw2K5Y!G7pK_uI8qQyA ... xjnJvTkE3c
OSCARFL
Post by OSCARFL » Wed May 08, 2019 2:26 pm
hi BLOEMP
have you been able to install version 2.7 in w10?
can u help me ??
bloemp
Post by bloemp » Wed May 08, 2019 3:09 pm
Yes, it is working without any problem for me with the latest windows 10 professional (x64).
What issues are you experiencing?
OSCARFL
Post by OSCARFL » Tue May 14, 2019 7:55 am
HI
are these the correct instructions ??
Do you do steps 6 and 7 ??
does not enable the usb driver multikey
WIN 10 X64 Patch Instructions:
2: Copy the license file SN-U10066.EGF to folder C:\User\Public\Eplan\Common\
3: Turn off the antivirus software, turn off the UAC system, this isnot really necessary, but you need to allow the system/antivirus alerts.
4: Run as administrator HASPUserSetup.exe.
5: If you want you can run EPLAN 2.1-2.7 X64 crack.exe with administrator rights instead of following the next steps 6 and 7:
6: Add to registry EPLAN 2.7 1-2.reg and EPLAN 2.7 2-2.reg
7: Start a command console with administrator rights and run install.cmd that you can find in MultiKey64.
If you don't want to use the install.cmd just copy multikey.cat , multikey.inf , MultiKey.sys to C:\Windows\System32
And update the Driver of virtual usb in Device Manager.
8: Use the version.dll creator
9: Copy version.dll to: C:\Program Files\EPLAN\Platform\2.7.3\Bin. Solve the lags problem.
10: Reboot.
van8x10
Post by van8x10 » Fri Jul 05, 2019 2:13 am
Now version is 7.92
https://supportportal.gemalto.com/csm?i ... =KB0018320
ubord
Post by ubord » Thu Oct 03, 2019 10:50 am
For Eplan 2.1 on windows7/64 , the correct HASP is "Sentinel_LDK_Run-time_setup" : https://www.utex.com/webapps/utexsuppor ... K2451?Open
...it is increasingly difficult to make these shit work!....становится все труднее заставить это дерьмо работать!
