It is currently Wed Nov 22, 2017 4:57 am
 Post subject: need help for hmi omron
PostPosted: Sun Jul 16, 2017 12:54 pm
i have hmi omron nt600s-st211 ev3 in my factory and have problems in touch ]
i want to change it to delta dop if some one helps me to make adresses of input and outputs and data entering
PostPosted: Mon Jul 17, 2017 3:04 pm
What CPU are you using?
PostPosted: Tue Jul 18, 2017 4:29 pm
i have cqm1 cpu43
PostPosted: Wed Jul 19, 2017 1:12 pm
have you selected the cqm series under your communication settings?
If not then go to the options tab and select communication settings then select "omron" under the manufactures options and then select "c/cpm/cqm series" under the series option.
once that is done you should be able to set the memeory path for your PLC tags on the HMI.
PostPosted: Sun Jul 23, 2017 12:33 pm
there isn't problem with communication with the new hmi
the problem is how to set the memory data entering in the new hmi dop delta
PostPosted: Mon Jul 24, 2017 11:11 am
I've pm'd you my email address.
Would you mind sending me your DOP file?
