It is currently Thu Jan 17, 2019 12:09 pm
 Post subject: FT View 8.0
PostPosted: Fri Sep 04, 2015 5:09 am
Can't take credit for this but...
FT View 8.0 is in 3 RAR's that are posted elsewhere on this forum. But not a patch to crack it as far as I know. I tried installing FT View 7.0 for which there is a patch on this forum for FTA that comes with that version but when I tried to install the FT View 7.0 I have (SR 3), the Sentinel driver outright crashes a Windows 7 VM no matter how I install it. So I was stuck with access to FT View Studio ME 7.0 legit or ME 8.0 illegit but no crack for FTA.
Moving forward, the Romanian web site has the following patch for FTA 3.62.11. I had 3.62.10 so again, there was a problem. Fortunately the only problem was that flexsvr.exe is slightly different. The rest of the files are the same. There are several places where the pattern "55 8B EC" is present but only the very last one needs to be modified.
Factory talk Activation Version 3.62.11
Hexedit C:\Program Files (x86)\Rockwell Software\FactoryTalk Activation\flexsvr.exe
Address: EE380
To: 33 C0 C3
Hexedit C:\Program Files\Common Files\Rockwell\FTACommon.dll
Address:A8780
To: 33 C0 C3
C:\Program Files\Common Files\Rockwell\RSpers32.dll
Address: A0F2B
To: 30 90
C:\Program Files\Rockwell Software\RSLinx\RSLINX.EXE
Address: 1AD036
To: E9 2C 00 00 00 90
C:\Program Files\Rockwell Software\RSLinx\FTAStub.dll
Address: 11E2
To: 09 00
If fresh install of rockwell product open ftasystem.lic from C:\Users\Public\Documents\Rockwell Automation\Activations for edit,
copy following to the file and save make sure to keep the FTA Placeholder at bottom of lic file in file.
Code:
SERVER this_host ANY
USE_SERVER
VENDOR flexsvr
FEATURE rsi.master flexsvr 1.0 permanent 10 VENDOR_STRING=9999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:MASTER LICENSE" SN=0000000001 \
FFFF FFFF FFFF FFFF"
FEATURE RSLINX.GW flexsvr 1.0 permanent 10 VENDOR_STRING=9999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSLINX.EXE GW" SN=0000000001 \
FEATURE RS5K_700.exe flexsvr 1.0 permanent 10 VENDOR_STRING=9999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RS5K_700.exe" SN=0000000001 \
FEATURE RS500P.EXE flexsvr 1.0 permanent 10 VENDOR_STRING=9999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSlogix 500" SN=0000000001 \
FEATURE RSLgx5P.exe flexsvr 1.0 permanent 10 VENDOR_STRING=9999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSLgx5P.exe" SN=0000000001 \
FEATURE WED32.EXE flexsvr 1.0 permanent 10 VENDOR_STRING=9999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:WED32.EXE" SN=0000000001 \
FEATURE RSARCH.EXE flexsvr 1.0 permanent 10 VENDOR_STRING=9999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSARCH.EXE" SN=0000000001 \
FEATURE RSARCH.PERS flexsvr 1.0 permanent 10 VENDOR_STRING=9999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSARCH.PERS" SN=0000000001 \
FEATURE RSVME.STUDIO flexsvr 1.0 permanent 10 VENDOR_STRING=9999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSVME.STUDIO" SN=1564000001 \
FEATURE RSV.STUDIO flexsvr 1.0 permanent 10 VENDOR_STRING=9999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSV.STUDIO" SN=1564000001 \
FEATURE PlantPAx_ModelBuilder.exe flexsvr 1.0 permanent 10 VENDOR_STRING=9999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:PlantPAx_ModelBuilder.exe" SN=0000000001 \
Incidentally these changes also take care of Logix 5, 500, and 5000 (up to Rev. 19). For rev. 20+, I believe you have to install, then uninstall FTA, then install it from FT View 8.0, then patch as above but as I don't need Studio beyond 19 yet, I haven't tried it.
 Post subject: Re: FT View 8.0
PostPosted: Thu Nov 26, 2015 12:27 am
Please Download and Share, the file have that name to avoid being deleted, is version 8.10.00 NO crack Inside I hope you find it useful
http://www.mediafire.com/download/iwuco7u0actfdec/37511B5ACA121761034CD104903DA326.rar
NOTE: I do not know if it requires a premium account for download but is the full version
File: 37511B5ACA121761034CD104903DA326.rar
Pass: 73B95E0C7B9D6E7829F1E440C538871F5241CFE1
Regards
PostPosted: Thu Apr 21, 2016 9:36 pm
Thank you so much. I recievied new equipment and have no chance to change SCADA. Not anymore.
PostPosted: Thu Aug 04, 2016 3:49 pm
Thank you!
PostPosted: Fri Feb 24, 2017 4:44 pm
Thank you.
PostPosted: Thu Jun 15, 2017 4:51 pm
Hi All,
do i need a premium account to download this, my download keeps cutting
PostPosted: Tue Jun 20, 2017 1:24 pm
Try to search for other resources containing this software, I thin I have found somewhere on mega.nz . Just search this forum.
PostPosted: Wed Jul 12, 2017 10:03 am
thanks for sharing everything ok except RSLINX.EXE, bytes at specified location are different am unable to follow instructions.
Address: 1AD036
please advise
