[!]: Virus inside S7-PLC, Step7, WinCC. DB 890 and DB 8062
Post by CoMod » Tue Jul 20, 2010 10:15 am
Russian
Re: [!]: Virus for WinCC and Рreventive medicine
Post by CoMod » Tue Jul 20, 2010 5:17 pm
Clear Registry LNK tools
Start>Run>Regedit
Stop and Disable WebClient
Stop + Disable + Apply
Restart PC :(
Russia wrote:Профилактическое лекарство
Обнулить LNK
Пуск>Выполнить>Regedit
апрет WebClient
Стоп+ Отключена + Применить
Перезапуск компа
RESULT :(
Post by CoMod » Wed Jul 21, 2010 6:17 pm
New info from Siemens wrote:Current information on malware in connection with Simatic Software
autho
Post by autho » Fri Jul 23, 2010 4:07 am
Post by CoMod » Fri Jul 23, 2010 5:16 am
Update from Siemens
sysclean.zip
The expert from Kaspersky Lab, July 15, 2010 wrote: If you look at these statistics, mapping the world, it becomes clear that the centers of the epidemic are the three countries - Iran, India and Indonesia (all three on the letter "I", funny).
Correct: India.
It features:
s7db_open s7db_open
s7blk_write s7blk_write
s7blk_findnext s7blk_findnext
s7blk_read s7blk_read
s7_event s7_event
s7ag_test s7ag_test
s7ag_read_szl s7ag_read_szl
s7blk_delete s7blk_delete
s7ag_link_in s7ag_link_in
s7db_close s7db_close
Russian wrote: http://www.securelist.com/ru/blog/34302/Mirt_i_guava_Epizod_3
Александр Гостев
Это функции:
s7db_open
s7blk_write
s7blk_findfirst
s7blk_findnext
s7blk_read
s7_event
s7ag_test
s7ag_read_szl
s7blk_delete
s7ag_link_in
s7db_close
s7ag_bub_read_var
s7ag_bub_write_var
Post by CoMod » Tue Aug 03, 2010 4:10 am
Re: [!]: Virus for WinCC and MS HotFIX KB2286198
Post by CoMod » Wed Aug 04, 2010 8:20 pm
Siemens wrote:Important note on the Microsoft Patch
==== Russian ========
greg2008 wrote:http://www.securelist.com/ru/blog/32867/Patch_LNK_vypushchen
sanruku
Post by sanruku » Tue Sep 21, 2010 12:59 pm
Take a look here:
& here:
for more info on the virus...
Stuxnet inside PLC !? wrote:Fact: Stuxnet intercepts code from Simatic Manager that is loaded to the PLC.
symantec wrote:Image
It checks:
2. Method of infection
Update
Re: [!]: Virus inside S7-PLC, Step7 and WinCC. MS HotFIX
Post by Update » Sat Oct 02, 2010 10:43 am
w32_stuxnet_dossier.pdf
greg2008
Re: [!]: Virus inside S7-PLC, Step7, WinCC. DB 890 and DB 80
Post by greg2008 » Wed Oct 20, 2010 7:10 am
Oldman
Post by Oldman » Thu Oct 28, 2010 3:38 pm
Update
Post by Update » Sat Nov 13, 2010 11:22 am
symantec, 11/13/2010 wrote:However, we can now confirm that Stuxnet requires the industrial control system to have frequency converter drives from at least one of two specific vendors, one headquartered in Finland («Vacon») and the other in Tehran, Iran.
Video
Stuxnet Dossier v1.3, p.42 wrote:The PLC is infected.
• Normal operation resumes.
Post by CoMod » Sun Nov 14, 2010 12:29 pm
Who's lying?
(boom)
No one can believe :(
To Langner
Russian wrote:В демо примере = 1 ЦПУ с модулем ввода-вывода с наипростейшей программой, состоящей из блока ОВ1 с одной веткой кода, в которой имеется один таймер и один выход.
Никому нельзя верить.
Отповедь руссофобу Лангнеру.
sanruku
Post by sanruku » Wed Nov 17, 2010 8:31 am
Update:
Post by CoMod » Wed Nov 17, 2010 3:35 pm
KIS2011 detect all.
КИС 2011 задетектил.
About Gas Centrifuge
and
Update
Post by Update » Tue Jan 25, 2011 7:58 pm
Info
Post by Info » Tue Feb 22, 2011 8:25 pm
Oldman
Post by Oldman » Sat Feb 26, 2011 3:30 pm
Russian wrote:видимо хорошо поработали израильские товарищи раз до сих пор наши спецы не уверены в безопасности объекта http://www.rbc.ru/rbcfreenews/20110226155945.shtml
Post by CoMod » Sun Feb 27, 2011 9:11 am
Oldman wrote:http://translate.google.com/translate?js=n&prev=_t&hl=ru&ie=UTF-8&layout=2&eotf=1&sl=ru&tl=en&u=http%3A%2F%2Fwww.rbc.ru%2Frbcfreenews%2F20110226155945.shtml
June 3, 2002
3 июня 2002 года
CHANt
Post by CHANt » Thu Mar 31, 2011 4:18 pm
Symantec in RUSSIAN
Info
Post by Info » Wed Jul 06, 2011 7:50 pm
July 5, 2011
Russian wrote:Потенциальная слабость Пароля безопасности в SIMATIC Контроллерах = Потенциальная внешняя атака на запароленные S7-PLC
Post by CoMod » Sat Jul 23, 2011 10:36 am
One year later
This is not our Cyber
but it exist
Cyber wrote:Posted: April 11, 2008 19:27
Russian wrote:Год спустя.
из статьи wrote:Даже трудно кодированный пароль базы данных Siemens был ранее представлен.
Наш Кибер, не тот Кибер 2008.
dolphinhusky
Post by dolphinhusky » Wed Oct 19, 2011 5:00 pm
Post by CoMod » Wed Oct 19, 2011 7:38 pm
Maybe it's a reaction:
Russian wrote:В последнее время Касперский пишет неприятное сообщение при запуске Simatic EKB Install.
Возможно это реакция:
Schtiel
Post by Schtiel » Wed Oct 19, 2011 9:26 pm
CoMod wrote:I do not know what the "store password".
Russian wrote:Я не знаю, что такое "хранилище паролей".
Info
Post by Info » Sat Oct 22, 2011 7:04 am
Symantec
Russian wrote:В настоящее время вирус DuQu не представляет прямой опасности для систем управления.
Info
Post by Info » Wed Nov 02, 2011 6:06 pm
Post by CoMod » Sat Nov 19, 2011 9:05 am
Then they come to you (boom)
Washington Times, Friday, November 18, 2011: Intrusion on water tower wrote:Hackers apparently based in Russia attacked a public water system in Illinois last week and damaged one of its pumps.
Тогда они придут к вам (boom)
Washington Times, 18.11.2011: Вторжение на водокачку wrote:На прошлой неделе Хакеры, по-видимому, находящиеся в России, напали на общественную систему водоснабжения в штате Иллинойс и повредили один из насосов.
CatCesar
Post by CatCesar » Mon May 28, 2012 2:12 pm
See the Results
http://www.controlglobal.com/articles/2 ... -view.html
Oldman
Post by Oldman » Wed Jul 25, 2012 8:34 am
jpavic
Post by jpavic » Tue Jul 15, 2014 3:02 pm
Virus Stuxnet
Post by CoMod » Fri Jul 18, 2014 4:28 am
Post by CoMod » Fri Sep 12, 2014 5:13 am
WITHOUT BACKDOOR
Our project is not commercial
наш проект не коммерческий
Post by CoMod » Sun Dec 18, 2016 10:31 am
http://www.nytimes.com/2016/12/17/us/po ... tions.html
Stuxnet live anew (boom)
Post by CoMod » Wed Mar 08, 2017 1:00 pm
Pucket Putin WinCC Server :)
https://wikileaks.org/ciav7p1/cms/page_ ... 7BSGBSYBSk
Fake news
Post by CoMod » Thu Apr 20, 2017 10:56 am
http://www.dw.com/en/reports-german-gov ... a-38506101
Post by CoMod » Sat May 13, 2017 5:26 am
Global attack (boom)
tem87
Post by tem87 » Thu Dec 14, 2017 6:11 pm
Сайты антивирусов молчат.
Numerous critical vulnerabilities have been found
Post by CoMod » Fri Dec 15, 2017 8:07 am
Info
Post by Info » Thu Jan 11, 2018 5:18 pm
(sfaq) https://support.industry.siemens.com/cs ... d-specter)
(https://support.microsoft.com/en-us/hel ... -kb4056895).
