wincc advanced and wincc proffesional on tha same project
Hello everyone!
I want to set 2 station PC ,one with wincc advanced and another with wincc proffesional in the same project.
I need to migrate from wincc advanced to wincc proffesional an work in the same project...can i do that?
Thank you!!!
Thank you!!!
Re: wincc advanced and wincc proffesional on tha same projec
I forget to mentioned that i have installed both softwares to PC,but in project three "Harware catalog" i see only RT Advenced,how can i import proffesional?
I have wincc proffesional in "Installed softwares"...!!!
if i uninstall and after that install,will work?
I say that i cant find in TIA,like in your picture,it's only wincc RT Advanced...
just in a minute,i wait for reinstall:)
thank you...
thank you...
thank you...but i can not downloa .exe file,do you know another sourse?
EKB install dont work with wincc rt proff...can you help me please
http://5cm.ru/view/i7/EUPl.png
thank you,i solved the proble,thank you anyway...
me again
First i migrate from advanced to professional,but stil have a problem ,when i start rt simulation with project,a message apear ocured starting rt prof,says that i don't have a license and will start in a demo version,but i instal a flot license with EKB 2048 tags,i can understand why he put 128tags license?!!!
http://imgur.com/a/tmehY
Another probelem the RT button in RT Prof is not enable....
Pleas help me!!!
Thank you!!!
Pleas help me!!!
Thank you!!!
Ok,thank you...but how can i ununstall unecesary license with EKB,HELP buton do not work...?
- Faq & Info
i try this methods ,both didn't work i can find AX NF ZZ file...
http://s020.radikal.ru/i711/1505/0d/273f988e4437.jpg
it not works...plese give me another way....thank you
reRead https://support.industry.siemens.com/cs ... t/24200966sergiu_md85 wrote:i try this methods ,both didn't work i can find AX NF ZZ file...
ok,i solved the problem,but... is always a problem...when rt open ,shows only one screen,without all pages...i have 22 pages...is somwere something to configure?
The button RT is not enebled,may this is a problem?
Thank you a lot!!
Thank you a lot!!
try Demo project for WinCC Runtime Professional V13 SP1
https://support.industry.siemens.com/cs ... al-v13-sp1
