Sicam PAS installation
milad2002b
Post by milad2002b » Wed Jan 18, 2017 6:50 am
I am going to set up a small automation lab using Sicam CC v8 and 3 siemens siprotec 4 protection relays with IEC61850.
I only have 1 PC and I want to use it as HMI and server. Is it required for me to get sicam pas and toolbox II as well? During Sicam pas installation I should select "Server" or "DIP"?
thuongvn
Re: Sicam PAS installation
Post by thuongvn » Wed Jan 18, 2017 8:53 am
You can install Server and HMI in one PC.
You must select the "Server" to install SICAM PAS.
Instructions:
http://www.mediafire.com/file/dk11f2r7z ... tion_b.pdf
milad2002b
Post by milad2002b » Wed Jan 18, 2017 11:54 am
Thanks thuongvn.
Is SICAM PAS required for such a small lab? SCC is not enough?
Is any crack available for enabling 61850 feature in feature enabler?
omar zedan
Post by omar zedan » Fri Sep 22, 2017 12:20 pm
Dear Milad2002b
I try to make a small lab like you but what you mean by Sicam CC v8 ?
