[LINK]: EPLAN ELECTRIC P8, Fluid, Pro Panel, PPE, EEC v2.6
Тools, Elcad, Eplan, ...
sadefa
Post by sadefa » Sat Aug 27, 2016 6:24 am
Hello 2 all
today I have the new EPLAN v2.6 to share
Enjoy ;)
EPLAN ELECTRIC P8 2.6
DESCRIPTION
links turbobit
EPLAN P8 FLUID 2.6
DESCRIPTION
turbobit
EPLAN P8 PRO PANEL 2.6
DESCRIPTION
Complete consistency
Manifold possibilities
Added value at a glance
Product videos
System requirements
links turbobit
EPLAN P8 PPE 2.6
DESCRIPTION
links turbobit
links wayupload
EPLAN P8 EEC One 2.6
DESCRIPTION
The use of EPLAN Engineering Configuration One (EEC One) is the first step on the road towards automation. In electrical and fluid engineering pre-defined standards such as circuit board elements or value sets are automatically collated into a wiring diagram based on Excel, thus simplifying machine design. In control cabinet and switchgear engineering, in EEC One combined with EPLAN Pro Panel, predefined 3D assembly layouts and more flexible control systems have reduced the time needed for the virtual configuration and assembly of mounting levels in control cabinets. Customers striving to standardise processes and data in engineering will benefit from this automation over the long term.
links turbobit
mazytus
Re: [LINK]: EPLAN ELECTRIC P8, Fluid, Pro Panel & PPE v2.6
Post by mazytus » Sat Aug 27, 2016 1:27 pm
Please upload to torrent
sadefa
Post by sadefa » Sat Aug 27, 2016 2:12 pm
yes ... I am here to serve you!
Just think how impudence your post is.
Use google to find one. I only have the links.
Perez1985
Post by Perez1985 » Sun Aug 28, 2016 7:02 pm
Is here any crack or eplan files only?
mazytus
Post by mazytus » Mon Aug 29, 2016 2:30 am
No crack, only Eplan
P.S. All downloaded now have to wait for crack. New License System :(
PDLFFALF
Post by PDLFFALF » Mon Aug 29, 2016 10:04 am
thanh3386
Post by thanh3386 » Tue Aug 30, 2016 8:14 am
(sos) (sos) (sos) please post md5 sum . i download and install fail
krepac
Post by krepac » Tue Aug 30, 2016 6:37 pm
Can anybody translate crack notes and manual in English, please?
Many thanks
thanh3386
Post by thanh3386 » Fri Sep 02, 2016 1:20 am
1. install EPLAN P8
2. Run Crack
3. copy "version.dll" to C:\Program Files\EPLAN\Platform\2.5.4(or 2.6.3 or etc)\Bin
4. run EPLAN
5. enjoy
krepac
Post by krepac » Fri Sep 02, 2016 1:32 am
Thanks!
Does crack works with EPLAN 2.6?
thanh3386
Post by thanh3386 » Fri Sep 02, 2016 2:23 am
Does crack works with EPLAN 2.6?[/quote]
yes. "1.8 to 2.6"
gregar
Post by gregar » Fri Sep 02, 2016 10:34 am
Translation is not precise. The original description file has 6 steps, but the translation only has 5 steps. I have a problem with the launch of Eplan with Win 10 Pro 64 Bits - no licenses available for the launch with crack "2016-08-31 EPLAN 1.8-2.6 X64 crack". Has anyone had success?
Schtiel
Post by Schtiel » Fri Sep 02, 2016 8:37 pm
2: Turn off the antivirus software, turn off the UAC system.
4: Run as administrator EPLAN全系列 2. 1 2.3 2.4 2.5 2.6 X64 crack.exe.
5: Copy version.dll to: C:\Program Files\EPLAN\Platform\2.6.3\Bin. Solve the problem of stuck.
6: Reboot.
ericpan
Post by ericpan » Sat Sep 03, 2016 3:57 am
Hello! Where can I dowload the EPlan 2.6 software now? The links above is not available.
duckman
Post by duckman » Sat Sep 03, 2016 9:44 pm
Hi all, for those interested in the crack.
Have tested with Virus Total and result was 6/56. (i.e 6 of the best anti virus software found a cause for concern.
This was after l removed the word crack from any titles).
gregar
Re:
Post by gregar » Tue Sep 06, 2016 7:36 am
Thanks, but this sequence does not work for me. When Eplan started, in the license selection window NO licenses available in the list of license and also stated: "There are no adequate dongle for validation.". As a result, Eplan not start.
It seems that there should be something else.
It is necessary to install MultyKey driver?
It is necessary to Run the Test mode in Windows 10?
Is there anyone who has had success with this?
Please can somebody who has had success with this, write one complete and correct instructions?
shestipal
Post by shestipal » Wed Sep 07, 2016 8:16 am
good day, colleagues! Could you please share new link on crack?
IVVA
Post by IVVA » Thu Sep 08, 2016 8:43 am
Here multikey signed for windows 10 64bit:
Spoiler
gregar
Post by gregar » Fri Sep 09, 2016 8:29 am
Thanks!
It works fine!
Thanks!
zesava
Post by zesava » Mon Sep 12, 2016 7:04 am
Hi folks.
I'm not sure is it the correct topic for this question but anyway :)
Can someone explain me difference between EPLAN ELECTRIC with Pro Panel AddOn and EPLAN Pro Panel with ELECTRIC AddOn.
PS. If someone has torrent link for EPLAN ELECTRIC P8 2.6 pls share.
singleperson
Post by singleperson » Mon Sep 12, 2016 7:21 am
Dear all,
Does anyone active Eplan harness 2.5 successfully?
I try to use the crack as instruction but the language is not licensed.
Please help me.
GenderGeek
Post by GenderGeek » Tue Sep 13, 2016 6:32 pm
Should work, I have no problem with the patch. Harness is listed.
mehmetf
Post by mehmetf » Thu Sep 15, 2016 12:20 pm
PDLFFALF wrote:crack:
http://eplan-eb2.ys168.com/
Hi, i dont use this page, please can you help me, how can i use?
Update
Post by Update » Thu Sep 15, 2016 3:45 pm
BIGBUSTERG
Post by BIGBUSTERG » Thu Sep 15, 2016 3:48 pm
zesava wrote:Hi folks.
Usually the price, but I guess that doesn't matter here.
Electric P8 can have several different version of panel and vice versa.
Only when you consider the options of the different modules available to add to each license it makes sense.
Or you can buy it!!!!!!!!!!!!!11
jbv_eng
Post by jbv_eng » Mon Sep 19, 2016 5:34 pm
Hello friends, I have Eplan Electric P8 2.4 and I try to install it on Win 7 32bit using these steps:
6: Reboot.
I have done all those steps, and after I rebooted my PC, and tried to run the EPLAN it failed and showed this error:
EPLAN\Platform\2.4.4\Bin\W3Sharedu.dll or one of its dependedcies are not found or could not be loaded!
What seems to be the problem?
Can you help me with this?
I haven't installed MultyKey driver yet. Is that the problem?
If so can you explain to me the steps to install the MultyKey driver?
Thanks in advance. Would really apreciate any help.
Cheers
kh100hcha
Post by kh100hcha » Wed Sep 28, 2016 12:56 am
Hi gregar,
Please, could you give the steps to work?
It worked with Windows 10 64bits?
Thank
eskalen46
Post by eskalen46 » Thu Sep 29, 2016 11:37 am
HELLO FRIENDS
IS THERE TORRENT LINK FOR EPLAN P8 2.6?
THANKS.
dzks13
Post by dzks13 » Thu Sep 29, 2016 2:48 pm
hello ,
Can anybody explain the prοcedure of the eplan installation step by step?
kh100hcha
Post by kh100hcha » Fri Sep 30, 2016 2:53 am
Install in Windows 10 64bits
First of all, my Windows 10 is in portuguese. So I will try to translate the menu itens...
Download the files (a) and (b):
(a) 2016-08-31 EPLAN 1.8-2.6 X64 eplan-eb2.ys168.com_crack.rar
https://mega.nz/#F!0NADHRCR!lLQRL5MmP2UUEOUtwsatdA
(b) Virtual USB Multikey Dongle 64bit driver - Signed by Leshcatlabs.rar
https://mega.nz/#!BZ1V1TAK!Un9OitK-tT4_ ... KTX3Hutypg
1: Extract the files above (a) and (b) in any where.
2: Install the software EPLAN Electric P8 2.6.
3: Turn off the UAC system.
- Write in Search button "UAC". Click on Change User account control settings. Down the level to "Never notify".
- Control panel > User account > User account > Change User account control settings > Down the level to "Never notify".
4: Run as administrator HASPUserSetup.exe.
5: Run as administrator EPLAN全系列 2. 1 2.3 2.4 2.5 2.6 X64 crack.exe. (I had to run 2 times, because 1st time I saw a message like "...was not possible to copy SN10066.exe and SN-10066.EGF..."). After run, just see if there are 2 files in C:\Users\Public\EPLAN\Common
6: Copy version.dll to: C:\Program Files\EPLAN\Platform\2.6.3\Bin
7: Restar windows.
8: Copy the files: multikey.cat , multikey.inf , MultiKey.sys ... from the folder extracted from Virtual USB Multikey Dongle 64bit driver - Signed by Leshcatlabs.rar to C:\Windows\System32.
9: Right-click in Start menu > Device Manager.
10: You will see one device with exclamation mark (!). Right-click > Update Driver. Select the seccond option "Search software driver in computer". Search in C:\Windows\System32. Click Next.
11: It will find a driver signed by "Leshcatlabs". Click in OK.
12: After the conclusion of update driver, you will see a message like "installing or updating" like some new device was inserted in computer.
13: Done. Open EPLAN.
dzks13
Post by dzks13 » Fri Sep 30, 2016 6:09 am
I made it! :D :D :D :D
Thanks a lot kh100hcha!!
kh100hcha
Post by kh100hcha » Fri Sep 30, 2016 10:32 pm
Every time when open EPLAN, it shows a chinese message and open the chinese site.
So I tryied delete the file version.dll from C:\Program Files\EPLAN\Platform\2.6.3\Bin and continious working, but with lags
I think, the main points are:
- UAC > Never notify
- SN-10066.EGF in C:\Users\Public\EPLAN\Common
- multikey.cat , multikey.inf , MultiKey.sys ... in C:\Windows\System32
- update the Driver in Device Manager.
kh100hcha
Post by kh100hcha » Fri Sep 30, 2016 10:58 pm
Someone have the installation of EEC One 2.6?
pedjaiv
Post by pedjaiv » Mon Oct 03, 2016 12:17 pm
Hi, I am using eplan pro panel v2.4 and i can´t find copper modul. Is this modul already in pro panel or I have to download it?
Please help :-)
Hypnos82
Post by Hypnos82 » Tue Oct 04, 2016 1:45 pm
Is there a 32bit solution for Eplan 2.6?
mazytus
Post by mazytus » Tue Oct 04, 2016 4:37 pm
Eplan only 64bit
luismello
Post by luismello » Sat Oct 22, 2016 10:51 pm
I have same problem, how to remove this msg?
cybernight
Post by cybernight » Tue Oct 25, 2016 2:12 pm
In the patch site : http://eplan-eb2.ys168.com/ you can fond now a tool to make the patch
I have made a new version.dll without the message and opening the website, its working on Windows 7 x64
you can download it in: https://mega.nz/#!8clznLZa!i-906IBNIsFR ... a2mar8q-qI
iyalav
Post by iyalav » Thu Oct 27, 2016 12:12 pm
I can not download just Eplan P8 part13. (this link: http://adf.ly/1dlXo5) Could you please reupload it?
czagawara
Post by czagawara » Thu Oct 27, 2016 7:26 pm
Hi I have the same problem.I would appreciate if someone can help with this.
This is the firs link for download ,like iyalav wrote is part 13
cybernight
Post by cybernight » Thu Oct 27, 2016 9:24 pm
I can help with Eplan Electric P8 2.6
Here you have a link to download the complete Eplan Electric P8 2.6 in only one file:
https://mega.nz/#!NMMRhYJR!UC76kBH-rVTS ... zfpuqMi0tg
czagawara
Post by czagawara » Thu Oct 27, 2016 9:56 pm
Thanks a lot cybernight !!!! Appreciate
djto
Post by djto » Sun Oct 30, 2016 7:15 am
cybernight wrote:In the patch site : http://eplan-eb2.ys168.com/ you can fond now a tool to make the patch
I replaced the dll with your but eplan does not open, because.
cybernight
Post by cybernight » Mon Oct 31, 2016 11:10 pm
This is a compilation of the eplan files:
Eplan Electric 2.6 : https://mega.nz/#!NMMRhYJR!UC76kBH-rVTS ... zfpuqMi0tg
Eplan Patch : https://mega.nz/#!pI0XxDwS!vZVkKfGritsn ... 4jTkHTXZSo
Inside the patch you have all the necessary files to create the virtual dongle and to create the version.dll
Follow the "Patch Instructions.txt" and the "Version.dll Creator Steps.docx"
I just compiled the files and rewrite the instructions the credit for the patch it's:
P.Y.G Decryption team works
WwW.CHiNaPYG.CoM
For research purposes only, do not infringing!
djto
Post by djto » Tue Nov 01, 2016 11:51 am
Thanks run in ok
sangalaviral
Post by sangalaviral » Wed Nov 02, 2016 3:38 pm
After Installing HASP, I do not find any virtual USB in device manager. Using Windows 10 x64
pconline
Re: [LINK]: EPLAN ELECTRIC P8, Fluid, Pro Panel, PPE, EEC v2
Post by pconline » Sun Nov 06, 2016 8:49 am
I installed as decribed by cybernight.
It is working but sometimes freezing.
Then I used the version.dll creator, i tried program and i see that it is not freezing(lag) now.
Thanks to cybernight.
softsmoke
Post by softsmoke » Sun Nov 06, 2016 10:34 am
Hey, Can somebody tell if the crack works for EEC?
huzuri
Post by huzuri » Mon Nov 07, 2016 8:42 am
i install an crack working good but when i try to open eplan it see message and opening the website
what can i do. pls help
dinuro
Re:
Post by dinuro » Tue Dec 06, 2016 11:15 pm
Schtiel wrote:1: Install the software EPLAN series.
6: Reboot.
i can't install (3: Run as administrator HASPUserSetup.exe.) from this file because the comment have a new version.
how to install this? my OS with win 7 x64
