RSEmulate 5000 wont install.
vatodster
Post by vatodster » Thu Sep 15, 2016 11:41 pm
I have tried installing rsemulate 5000 v20. i have rslogix v11,15,19,2,0,21,23,26,28 installed. Each time I try to install it, I get an error when it goes to install the eds files. After acknowledging the error, the install completes. The program does not run correctly and all the modules do not show up, just the emulator cpu and an i/o module to select from. I am installing this on win 7/32 in vmware. I do a snapshot and install and it doesnt work. i tried another install that installs all versions from 12-21. same thing. Any suggestions or thoughts.
RobRob
Re: RSEmulate 5000 wont install.
Post by RobRob » Fri Sep 16, 2016 3:20 pm
You need to have RSLOGIX 5000 v20 if you will work with RSEMULATE 5000 v20. Try it (pgood)
vatodster
Post by vatodster » Sat Sep 17, 2016 12:31 pm
I have v20 installed. Thank you.
RobRob
Post by RobRob » Mon Sep 19, 2016 2:51 pm
vatodster wrote:I have v20 installed. Thank you.
Try it on Windows Xp SP3 (in VMWARE), probably you don't have Service pack 1 in your Windows 7.
Read the next information about it:
http://www.ab.com/en/epub/catalogs/1276 ... ments.html
vatodster
Post by vatodster » Wed Sep 21, 2016 7:10 pm
SP1 is already installed. Also meets the recommendations. I'm at a loss.
RobRob
Post by RobRob » Wed Sep 21, 2016 7:47 pm
vatodster wrote:SP1 is already installed. Also meets the recommendations. I'm at a loss.
Do you have the same problem yet?
