[LINK]: WinBass II (Baumüller)
Прочие PLC и HMI на русском
Grey
Post by Grey » Wed Feb 10, 2010 12:02 pm
Други, срочно нужна прога WinBass II для конфигурирования драйверов Baumüller.
Поставщик прислал по гарантии уже 3-й драйвер BM3xxx с неверной прошивкой, а оборудование стоит.
http://www.baumueller.de/e_servo_contro ... nbass2.htm
aborigen
Re: Request: WinBass II (Baumüller)
Post by aborigen » Wed Feb 17, 2010 6:20 pm
almanzo
Re: [LINK]: WinBass II (Baumüller)
Post by almanzo » Sun May 22, 2011 2:15 pm
I can not download this web we need RS Thanks
jkovacs
Post by jkovacs » Fri Oct 18, 2013 11:33 pm
Hello guys
The file Baumuller.001 is corrupt. Could it reload the good version someone, please?
Thanks and best regards
jkovacs
Post by jkovacs » Sat Oct 19, 2013 12:17 pm
Thanks for your prompt reply.
The packed files are available, but some of them damaged on the server.
The packed files are downloadable - but unfortunately, some files are damaged. Just check separately the "Setup.W31" file on server. It is doesn't downloadable.
This file is surely missing from downloaded archive "Baumuller.001" and the unpack process gives fault message --> CRC Error in Setup.W31.
Also the other file "Setup_Update_V1_109bd44.zip" is damaged. Error message during unpacking --> Error: End-of-central-directory signature not found.
Can you check your ones, those are unpackable as well, please? Maybe it needs simply an upload again onto the server?
Many thanks and best regards
jkovacs
Post by jkovacs » Mon Oct 21, 2013 4:24 pm
Many thanks, it works as well. :-)
Best regards
hmohamed
Post by hmohamed » Tue Oct 28, 2014 7:55 am
Links are Dead can you reupload
vlad2006gr
Post by vlad2006gr » Fri Dec 11, 2015 3:46 pm
craul3
Post by craul3 » Fri Apr 22, 2016 7:40 am
Hello
Can you , please reupload WInbass 2? Thank you
craul3
Post by craul3 » Fri Apr 29, 2016 7:57 am
Hello
can you reLink Winbass2 , please ?
Best regards
vlad2006gr
Post by vlad2006gr » Fri Apr 29, 2016 11:42 am
after 11 May will try to help. whilst on holiday.
craul3
Post by craul3 » Sat Apr 30, 2016 6:31 am
OK Thank you .
craul3
Post by craul3 » Wed May 11, 2016 9:59 am
Thank you very much .
Best regards from me to you .
Thank you again .
elhazard
Post by elhazard » Tue Jan 17, 2017 5:34 pm
anyone can share a working link to w1nbass 1
ppp
Post by ppp » Wed Jan 18, 2017 9:10 am
elhazard
Post by elhazard » Wed Jan 18, 2017 9:18 am
thx!
jimmy146
Post by jimmy146 » Wed Aug 01, 2018 7:52 am
Hi, can anybody reupload WINBASS II ?
Updates are avalible from baumuller site without problems, but first install is hard to find - all links are dead now.
Thanky you!
(fback)
alexpin
Post by alexpin » Fri Dec 21, 2018 9:06 am
Срочно понадобилась WinBass II могли бы Вы обновить ссылки
pbfilho
Post by pbfilho » Thu Jun 13, 2019 2:17 pm
Hi, i`ll appreciate very much if somebody can upload fresh links for WINBASS II.
I have a urgent demmand with parametrization of a BUS621 drive.
Thank you in advance.
