Fatek Protected File
Re: [?]: How crack or unlock FATEK PLC password
hello to all
Any one has a program to read the password of LS PLC (GLOFA SERIES )??. If someone has this, I would greatly appreciate if I could get a copy!
BEST REGARDS
ZAFARI.CTRL@GMAIL.COM
BEST REGARDS
https://www.dropbox.com/s/4dysbh62inwzf ... d.rar?dl=0Raptor wrote:Dear ziconltai: Please share Fatek Unlock software for we..
Hi all,
I'm newbie, could u help to crack password of sub program fatek Fbs PLC, the file attached here : https://www.dropbox.com/s/bgo2o6jo0sm6c ... 1.pdw?dl=0
Thanks in advance,
Thanks in advance,
littlekhum wrote:
Good luck!
password: A85323Hi all,
Good luck!
Password- TURKMEN
Good luck!
Good luck!
hi vlad2006gr
help please to crack password of sub program fatek Fbs PLC
https://yadi.sk/d/HKfYhY3Uj8GgT
Password- A85323
Good luck!
Good luck!
help please to crack password of plc fatek FBE-20MA
https://www.4shared.com/file/N_FcF07Wba/3as.html
Password- 762805
ID- 762805
Good luck!
ID- 762805
Good luck!
Password ID : GORBUSHA
Hello dears
I can't download this file: WPlad300-12308-ENU_CR.rar
can you help me please
thanks a lot
Best regards
thanks a lot
Best regards
HI, thanks for your answers and getting rid of the password. Here I have another programm with a password. Could you take it off as well? Link to the program:
https://www.sendspace.com/file/2nwmo1
thanks in advance.
thanks in advance.
Password- 111
Good luck!
Good luck!
thank you very much for help, best regards!!
Password ID 22775440
Good luck!
Good luck!
Hello to all. Can anyone help me also. I need the password for the program running on Fatek FBs PLC.
The file is attached here: https://www.dropbox.com/s/21og6up5mv4lx ... k.zip?dl=0
Thank you in advance
Main: 1145570
pleeeeeeeeeeeeeeeeeeeeeese help me again.
I really need your help
this is a fatek protected file and i can not access source code please help me.
What is the password??
i cannot find password
https://drive.google.com/file/d/0B6tRgl ... sp=sharing
Re: Fatek Protected File
I have a plc FBS - 32MAR2 -AC which has password , may remove ?.to make changes to PLC?.
I do not have the file!!!!
Use search on this forum topic.- viewtopic.php?f=3&t=5035&start=50#p74140h_vakilian wrote:pleeeeeeeeeeeeeeeeeeeeeese help me again.
ID-BITA9980
Hi all my friends.
i have a plc Fatek FBs-40MA(v4.62) that have password.
I monitored communication between plc and winProLadder but i cannot find password.
how can i find password???
Is any software to do that??
pleeeeeeeeeeeeeeese help me
this is communication Log when password form appear:
[04/03/2016 11:34:08] - Open COM7 port (C:\Program Files\Fatek\WinProladder\WProlad.exe)
[04/03/2016 11:34:08] - Written data
02 30 31 30 32 43 35 03 .0102C5.
[04/03/2016 11:34:08] - Read data
02 30 31 30 32 30 32 31 30 30 30 34 30 30 37 43 .01020210004007C
03 .
02 30 31 32 41 44 36 03 .012AD6.
02 30 31 32 41 30 30 34 36 41 30 03 .012A0046A0.
02 30 31 30 30 43 33 03 .0100C3.
02 30 31 30 30 30 30 30 32 31 30 30 30 34 30 30 .010000021000400
30 30 35 30 30 30 30 30 30 30 34 36 32 30 31 31 0050000000462011
30 33 30 30 30 30 34 33 31 34 32 34 46 30 30 30 030000431424F000
38 39 30 34 36 36 46 30 30 30 31 36 46 37 45 35 890466F00016F7E5
38 03 8.
And this is communication Log when I Entered password "00000000" and winproladder answer illegal password:
[04/03/2016 11:40:09] - Written data
[04/03/2016 11:40:09] - Read data
38 39 30 34 36 36 46 30 30 30 31 46 30 46 35 35 890466F0001F0F55
31 03 1.
02 30 31 32 35 30 46 30 41 3a 30 30 30 30 30 30 .01250F0A:000000
30 30 36 42 03 006B.
02 30 31 32 35 36 30 33 30 03 .01256030.
[04/03/2016 11:40:11] - Written data
[04/03/2016 11:40:11] - Read data
31 03 1.
03 .
38 03 8.
31 03 1.
31 03 1.
ID= 1510s_hussain2k wrote:Kindly tell the password for the file
Good luck!
Look at here pls.h_vakilian wrote:Hi all my friends.
03 .
38 03 8.
31 03 1.
31 03 1.
https://www.youtube.com/watch?v=L11i6D4WUhI
https://drive.google.com/open?id=0B-WrZ ... 2R5dUU4YVE
you can find software at http://tuanlongtai.blogspot.com/
Please help me find the password !!!!
https://drive.google.com/folderview?id= ... sp=sharing
Password FANDTJNipahan wrote:Please help me find the password !!!!
ID FAN
Good luck!
This tool can find passwordsNipahan wrote:Please help me find the password !!!!
https://drive.google.com/file/d/0B-WrZV ... sp=sharing
Can you help me unlock this file?
https://www.dropbox.com/s/880b13xldcozq ... S.pdw?dl=0
Thanks in advance!
Thanks in advance!
Thank you. I really really appreciate your help.vlad2006gr wrote:https://www.sendspace.com/file/10yxvnarshad88 wrote:Can you help me unlock this file?
Good luck!
One small problem. The writing in the file has messed up when I open it. I can't understand the text.
I have re-uploaded the original locked file again. Is it possible you can remove password from this file again?
https://www.dropbox.com/s/cvxru7uxehytr ... 2.pdw?dl=0
Thanks in advance!
Ok. Password- 19713620arshad88 wrote:One small problem. The writing in the file has messed up when I open it. I can't understand the text.
Thank you, thank you my good sir. I am very much obliged.vlad2006gr wrote:Ok. Password- 19713620arshad88 wrote:One small problem. The writing in the file has messed up when I open it. I can't understand the text.
This is Block of OMRON Plc;
Password simoneteh_vakilian wrote:Please help me find the password !!!!
Good luck!
ID=91319158icegirl013172 wrote:Can you help me unlock this file?
Good luck!
Can you please send me the programm for unlocking?
Thanks in advance.
Thanks in advance.
Hi Vlad2006gr
https://drive.google.com/file/d/0B3xYIn ... sp=sharing
Password 3233708marea wrote:Can you help me unlock this file?
Good luck!
thank you so much Vlad2006gr
great job
great job
Hi Vlad,
Could You please take a look at this file:
https://ufile.io/d4cca
I'd be very pleased if You could help.
It's a matter of life and death...
Link is not work..szafa wrote:Could You please take a look at this file:
Here's a link from google drive.vlad2006gr wrote:Link is not work..szafa wrote:Could You please take a look at this file:
Just click the button in the middle of the screen.
I appreciate Your help.
https://drive.google.com/file/d/0BxeGfM ... JJYWs/view
Password- 5352szafa wrote:Here's a link from google drive.
Good luck!
Password: 5253szafa wrote:Here's a link from google drive.vlad2006gr wrote:Link is not work..szafa wrote:Could You please take a look at this file:
https://www.youtube.com/watch?v=2TJEQ5JliDw
