It is currently Tue Oct 23, 2018 5:09 pm
Post new topic Reply to topic  [ 81 posts ]  Go to page Previous  1, 2
PostPosted: Sun Dec 14, 2014 8:07 pm
version 7.10 on Aucotec site :
https://www.aucotec.com/modules.php?op= ... ask4mail=0
@bsod, can you do some magic ? ;)
PostPosted: Wed Jan 28, 2015 3:18 pm
Can anybody help me with elcad 7.90 SP2
Thank you very much
PostPosted: Sat Mar 14, 2015 10:16 am
Anybody help me with elcad 7.9.0 sp2 in spanish. I need activation Thank you
PostPosted: Sun Apr 12, 2015 6:57 pm
I installed the Elcad v7.9 sp1 Italian version and use the crack for this version , copy the file alwin.exe and then install the Spanish version sp2 and copy this file and it works.
No if it worked mostly because I have not tested thoroughly but apparently yes. ; )
Download Link
Password : aucotec
https://mega.co.nz/#!H1pSkJSJ!ax7RdLaXm ... 6pyEvWt9aE
PostPosted: Sun Oct 11, 2015 7:42 pm
Hello
I am searching the medicine for Elcad 7.10 with SP3 for German
Thanks for all :haha:
keymak
PostPosted: Sun Jan 03, 2016 2:57 pm
(oo)
PostPosted: Sun Feb 28, 2016 8:00 pm
7.11 ???
PostPosted: Wed Mar 09, 2016 10:03 pm
hi,
v11 can be downloaded from aucotec site ...
https://service.aucotec.com/modules.php ... ask4mail=0
but it needs some magic :)
PostPosted: Thu Mar 31, 2016 7:05 pm
for Aucotec Elcad 7.11.0 - NOT TESTED !!!
http://www.xup.in/dl,14889229/aes7110.rar/
Pass: Aucotec
bsod
PostPosted: Fri Apr 01, 2016 10:17 am
Thanks bosd for the clean crack, l also haven't tested it.
Result of crack check
VirusTotal
SHA256: 4cc72109e5e3f8fac787ddfc2cd3b3da85541454dd5f826ded37b81e12d2c13f
File name: alwin.exe
Detection ratio: 0 / 56
Analysis date: 2016-04-01 07:10:10 UTC ( 1 minute ago )
Regards
PostPosted: Sat Apr 02, 2016 5:21 pm
thanks bsod,
confirm working ..
PostPosted: Wed Apr 27, 2016 6:03 am
Could you re-upload medicine of V7.11?
Tks!
PostPosted: Wed Apr 27, 2016 10:31 pm
do not forget to uncheck the box below
Code:
https://www.datafilehost.com/d/b981d68c
771
PostPosted: Thu Apr 28, 2016 10:20 am
alafandy wrote:
Aucotec Elcad Aucoplan v7.11
Author: AUCOTEC AG
Version: 7.11
file : ISO
Download Direct Link ELCAD 7.11 here :
PostPosted: Thu Apr 28, 2016 10:28 am
crack file for elcad 7.11 please
PostPosted: Thu Apr 28, 2016 11:03 pm
Code:
https://www.datafilehost.com/d/133e698b
711
edit: is down
PostPosted: Mon May 02, 2016 4:40 pm
please 7.11 crack file
PostPosted: Mon May 02, 2016 7:57 pm
selftester
https://www.datafilehost.com/d/bfea6f4f
PostPosted: Mon May 02, 2016 8:45 pm
Thanks you very much, Carlos!
PostPosted: Fri May 13, 2016 12:01 am
Hi all, i'm new!
I need medicine for elcad 7.11 and please tell me how to apply this medicine (wow)
PostPosted: Thu Jun 30, 2016 2:31 am
Hi Everyone, I´m really need this software but i checked already all the links here and I can not find any version of Elcad with the respective crack or medicine, all links are already blocked :´( I just want this software Elcad in any version with the respective crack. If someone can please help me! Pleassseeee. Thnks.
PostPosted: Sun Aug 07, 2016 2:42 am
I just downloaded the iso version 7.11. from: https://goo.gl/qJT64R
Is there any medicine to activate the program?
PostPosted: Thu Aug 18, 2016 2:38 pm
I just downloaded the files to medicate the program. :smile:
I just try and do not work. :( :( :(
Get the following message:
"Program files differ from the original ones.
The program might créate erroneous Project data."
After then close the program.
Know any other solution to disable the "demo" function and to work with all features.
PostPosted: Sun Aug 21, 2016 12:43 pm
try to uninstall, then clear registry (anything involving elcad) and install again
don't start the program before applying patch
PostPosted: Mon Aug 22, 2016 6:58 pm
Thank you very much for your help John_smith. (tyou) (tyou)
I just followed his instructions and now it seems to work. (clap) (clap) (clap)
Then leave the steps taken to get it to work properly for those who may need:
1 Download the program from: https://goo.gl/qJT64R
2nd Download medicine from: 7110.rar - 3.5 MB
3rd Delete the pc making reference to AUCOTEC and Elcad. Both files and registry entries. For this I used the REVOUNISTALLER program.
4th ELCAD program installed version 7.11
5th run the program and leaves a window of selection of type of rules to use. Select appropriate to needs, normally IEC-international.
6th Give OK
7th Copy the file of medicine in the working directory.
and ready. (suc) (suc)
PostPosted: Mon Aug 22, 2016 10:19 pm
6th Give OK
Where is the link for second, 7110.rar?
PostPosted: Mon Aug 22, 2016 11:58 pm
The second link is:
https://userscloud.com/j1mztnn2o091
PostPosted: Tue Apr 11, 2017 3:43 pm
Hello
Is there any medicine to activate the 7.12 version ? (pgood)
keymak
PostPosted: Sat Apr 29, 2017 3:42 pm
Carmelinfc wrote:
The requested file (ID# bfea6f4f) no longer exists on DATAFILEHOST.COM.
Can anybody help
Respect
kashavar
PostPosted: Wed Apr 04, 2018 7:09 pm
is there any help for Elcad v 7.13 / Elcad 2018 ?
PostPosted: Thu Aug 16, 2018 4:39 pm
Please some one to help me wit medicine: 7110.rar - 3.5 MB
