WINCC 7.0 SP2 UNDER WINDOWS 2008 SERVER IN RUSSINA LANGUAGE
PLC_ITA
Post by PLC_ITA » Fri Mar 20, 2015 9:03 am
Hello to all, i need a help about an installation of Wincc
I have a new customer that have already a project. This project is a wincc 7.0 sp2 version and running under Windows 2008 server ( english )
The project have two Language : English and russian ( cirillic character )
In may office now i would like to replicate a same machine but i do not read in russian . a ??????? will be display instead string.
I try to serch in internet a Language pack / MUI or other for Windows but not result.
Anyone can suggest or help me ?
thank you (sos)
Info
Re: WINCC 7.0 SP2 UNDER WINDOWS 2008 SERVER IN RUSSINA LANGU
Post by Info » Fri Mar 20, 2015 1:01 pm
Windows Server 2008 R2 SP1 MUI Russian Language Pack
http://download.microsoft.com/download/ ... -ru-RU.exe
Windows Server 2008 R2 SP1 MUI Language Pack (All Languages)
http://download.microsoft.com/download/ ... P1_DVD.iso
Russian support package for WinCC
http://dfpd.siemens.ru/infocenter/628/1457/
Request is free
http://dfpd.siemens.ru/index.php?id=1453
https://translate.google.ru/translate?h ... Fid%3D1453
PLC_ITA
Post by PLC_ITA » Sun Mar 22, 2015 3:03 pm
thank you for your answer,
I have install russiann Language in my machine and install , but the result is the same. Always ????? instead of string.
A more info
The project languge is'nt RUSSIAN but BELARUS
there are a difference ? seraching into Microsoft site there is'nt a Belarus language
my operating systeme is WINDOWS SERVER 2008 STANDARD in english.
After the Language pack installation i use english Language because if i switch Windows in russian it's impossible for me use Windows or other
anyone have a suggest ?
Usver
Post by Usver » Mon Mar 23, 2015 9:24 am
In registry tool: hklm\SYSTEM\CurrentControlSet\Control\Nls\CodePage 1250 = c_1251.nls, 1251 = c_1251.nls, 1252=c_1251.nls
PLC_ITA
Post by PLC_ITA » Mon Mar 23, 2015 11:28 am
yes !!!!
now work fine
THANK'S A LOT !!!
