It is currently Wed Nov 21, 2018 7:08 am
Post new topic Reply to topic  [ 13 posts ]
PostPosted: Sun Nov 14, 2010 9:18 pm
Hi Friends
Can somebody share LogixPro Simulator? (sos)
I have searched in the forums but link does not work. (no)
Thanks in advance (tyou)
PostPosted: Mon Nov 15, 2010 4:50 am
What version are you looking for?
RSLogix Emulate 500
RSLogix Emulate 5
RSlogix Emulate 5000 Ver 15, 16 etc
PostPosted: Mon Nov 15, 2010 11:06 am
Hi neuhauser
That is what you need this the LogixPro Simulaor
(dlink) http://www.mediafire.com/?x153cfp6kbpbcdv
good luck (suc) (suc) (suc) (suc) (suc) (suc)
PostPosted: Mon Nov 15, 2010 7:36 pm
The version that I need is LogixPro Simulator from the LearningPit, that one that cuongvcs has uploaded, but... (dlink)
I have installed and run the keygen, but when I tried to enter the key pushing the button unlock, a popup appear "You User Name and/or User Code could not be verified"
And I have to exit and the software remains in trial mode 15 days. (wow)
Somebody has another working version?
Or do you know to fix that?
The latest version is 1.86 but any working version is good for me.
Thanks in advance. (tyou)
PostPosted: Mon Nov 15, 2010 8:00 pm
Hi asteroidehk.
Ok I'll help you fix problems keygen.
the fist .you opend notepad and write "logixpro rigister" then save it in C:\Program Files\TheLearningPit\LogixPro and rename this file register.bat
the second > to Start/run type cmd type in C:\Program Files\TheLearningPit\LogixPro ,then type "logixpro register" it will show up on the enter key and you see befor "END"is 8 characters ,and copy it
open keygen and pass 8 characters in to HWID .
the name is SISTEMA ,click generate get the key.
Get keys that put LogixPro with name SISTEMA.
Good Luck (suc) (suc) (suc) (suc) (suc) (suc)
PostPosted: Tue Nov 16, 2010 9:50 am
Hi cuongvcs
I have done exactly what you said, but it does not work, the same pop-up apeears.
(no)
Another idea?
(h)
Thanks again
PostPosted: Tue Nov 16, 2010 11:19 am
Sorry asteroidehk
you can try again .
with "cd C:\Program Files\TheLearningPit\LogixPro"
I have setup and tried again and it worked.
the remaining step do same.
good luck (sorry) (sorry) (sorry)
PostPosted: Tue Nov 16, 2010 12:46 pm
May be problem in this? :wink:
In may cause the keygen got me a valid key with SYSTEM name.
PostPosted: Fri Nov 19, 2010 7:24 am
Hi friends
After several tries, I have achieved to register.
Thanks a lot. (suc)
PostPosted: Mon Dec 29, 2014 8:36 am
hello
the link seems to be closed, could you posted again?
PostPosted: Fri Oct 27, 2017 10:14 am
morens wrote:
hello
If you are still in need of the above software, Please contact me.
You can directly reach me here -- http://wonderwareintouchusers.com/contact/
PostPosted: Fri Nov 03, 2017 11:27 pm
Hello
I've logixpro V1.61
https://drive.google.com/open?id=0B60BJ6cxLY6SS29QRm56UHp1Z0U with activate :wink:
Best regards.
PostPosted: Tue Dec 19, 2017 12:47 pm
yuki_lolita wrote:
Hello
I've logixpro V1.61
Best regards.
GDrive tells me "Sorry, this file is infected with a virus, Only the owner is allowed to download infected files"
Any suggestion?
