How can i convert a project from version 7.x in version 6.5 if i don't use special (new or different) functions available only in version 7.x ?
There is a method to open this project from version 7.x in version 6.5 ?
If you have a project made in version 6.5 and you open in version 7.x, Zenon IDE see the difference and make an conversion (UP conversion), have someone solution to make an DOWN conversion from v7.x to v6.5 if the project don't include special function acceptable only for v7.x ???
Thank you!
[HOW TO...] Convert project v 7.x in v 6.5 in Zenon
Re: [HOW TO...] Convert project v 7.x in v 6.5 in Zenon
As far as i know it is not possible to downgrade the project versions.
It has something to do with the SQL databases. In 7.0 or 7.10 it is a SQL2012 and in the older SQL2008.
Unless i'm mistaking ofcourse.
Goodluck.
Goodluck.
Hello ,
You don't have need to downgrade the version , you can compile file runtime with 7.0 version for 6.50 as you need.
Regards.
Regards.
Hi Shkodran
Could clear some informations for me?
"You don't have need to downgrade the version , you can compile file runtime with 7.0 version for 6.50 as you need".
That we can compile the runtime files for version 6.5 by 7.0 but in editor of 7.0 has some configuration different than 6.5 like " configuration for 61850 driver some config of trigger option " so the runtime 6.5 will work with which configuration.
Brgds
Mytom123
Brgds
Mytom123
Hi ,mytom123 wrote:Hi Shkodran
Brgds
Mytom123
Can you post your editor project here ? I'll take a look...
In Editor 7.x is different than Editor 6.50 for setting Trigger Options individually as picture. So the runtime 6.50 will work with Trigger Options individually or will work as the setting "use preconfigured TrgOps".
Sorry I do not have devices for testing so I do not know which will work.
http://www.mediafire.com/view/6mh4cdc9n ... option.jpg#
Brgds
Mytom123
Brgds
Mytom123
