ABB 5.0 Licence Issue - LinkinX64 Help?
другие контроллеры
winnipeg_1
Post by winnipeg_1 » Tue May 20, 2014 9:41 pm
LinkinX64,
I installed 5.0 and went to install the licence and couple items pop up
1) Unable to Load File: Failed CIV check
2) And: The ABB License Client Provider Service has not been setup to run under a vaild account. Please refer to the installation manual that came with your product for proper license account setup information.
winnipeg_1
Re: ABB 5.0 Licence Issue - LinkinX64 Help?
Post by winnipeg_1 » Wed May 21, 2014 12:49 am
Got somewhat moving on this - but it comes up with this error in the "License Status Viewer"
0X4AB09 -> Invalid License Granted Feature Found, But wrong Machine ID
THanks for any insight
Linkinx64
Post by Linkinx64 » Sun May 25, 2014 12:26 pm
winnipeg_1 wrote:0X4AB09 -> Invalid License Granted Feature Found, But wrong Machine ID
Open .sla and replace all MAC IDs with your Ethernet card MAC address (or you can place DEMO instead).
winnipeg_1
Post by winnipeg_1 » Mon May 26, 2014 2:48 pm
Yes I did that. The License Entry is 5.0.2.45. I installed 5.0.2/2. In the Machine ID I see two -> DEMO, and 0050563DF792 which is the MAC of the network card.
The error I get in the License Status Viewer is: Error Code 0x4AB09 ->Invaild License Granted:Feature found, but wrong Machine ID.
This is the software package versions installed.
[Installed ABB Software Packages]
Package Description Version
800xA Base 5.0.0 5.0.2484.8625
800xA Base 5.0.0 SP2 5.2.3152.14888
800xA Base 5.0.0 SP2 Graphics Extension 5.0.2/0 5.2.3269.29788
800xA Base 5.0.0 SP2 RU3h 5.2.3551.26693
ABB 800xA Instructions 5.0.3121.26822
ABB 800xA Instructions for Process Graphics 5.0.3261.29320
ABB AC 800M Connect 5.0.2/0 5.0.2004.52
ABB AC 800M Connect Graphics Extension 5.0.2/1 5.0.2008.11
ABB Base Software for SoftControl 5.0.2/0 5.0.2004.52
ABB Central Licensing System 5.0.2/2 5.0.2.45
ABB Central Licensing System Extension 5.0.2/2 5.0.3476.21300
ABB Control Builder M Professional 5.0.2/0 5.0.2004.52
ABB Diagnostic Collection Tool 5.1.1/0 5.1.1.8
ABB Diagnostics Collection Tool Plugins 5.1.1/0 5.1.1.8
ABB OPC Server for AC 800M 5.0.2/0 5.0.2004.52
ABB PC, Network and Software Monitoring 5.0.2/0 Rollup3 5.0.3489.19186
ABB SFC Viewer 5.0.0 SP2 5.0.3091.9714
ABB SFCViewer 5.0.0/0 5.0.2454.24217
AC800M Connect 5.0.2004.52
AC800M Connect Graphics 5.0.2008.11
Control Builder M 5.0.2004.52
OPC Server for AC 800M 5.0.2004.52
SoftController 5.0.2004.52
ABB 800xA System Checker Tool 5.0.0/2 5.0.3049.12534
ABB 800xA System Installer 5.0.2/0 5.0.3134.27548
ABB SoftPoint Server 5.0.2/0 5.0.2000.27
ABB Engineering Studio 5.0.0/0 SP2 5.0.3121.28708
ABB Engineering Studio 5.0.0/0 5.0.2468.14412
ABB Inform IT - Application Scheduler 5.0.5108.0730
ABB Inform IT - DataDirect 5.0.5108.0724
ABB PC, Network and Software Monitoring 5.0.2/0 5.0.3120.16880
ABB PC, Network and Software Monitoring Graphics Extension 5.0.2/0 5.0.3218.15056
winnipeg_1
Post by winnipeg_1 » Mon May 26, 2014 5:54 pm
I now have a second error -> No Active SFA -> Error Code 0x8004AB8B; The system is running without an active SFA.
Linkinx64
Post by Linkinx64 » Thu May 29, 2014 6:52 pm
Try to reinstall ABB Client License Service.
winnipeg_1
Post by winnipeg_1 » Thu May 29, 2014 9:53 pm
I uninstalled the CLS and went to reinstall it. It askes what type I want?
Client or Server or Standalone.
What do I choose for this.
Linkinx64
Post by Linkinx64 » Fri May 30, 2014 5:10 am
winnipeg_1 wrote:I uninstalled the CLS and went to reinstall it. It askes what type I want?
If your system contains 2 or more nodes (computers): Server - install on Aspect Server node or Domain (if you have a domain); Client - install on all other node types.
Else select Standalone installation type.
winnipeg_1
Post by winnipeg_1 » Fri May 30, 2014 12:17 pm
This is just a standalone PC. The license is now taking but I have other issues;
- When I create a new project in CB, it says I don't have any librarys installed and quites?
- For the OPC, when I go to enter my PC IP, it doesn't provide me with the IP address from the list.
Thanks for any insight on this.
