[REQUEST} SEE Electrical V7R1
Тools, Elcad, Eplan, ...
green
Re: [REQUEST} SEE Electrical V7R1
Post by green » Thu Jan 17, 2013 9:56 pm
Does this version print "school licence" on paper?
For example. I have oldest version See Electrical V6R1. If I print some electrical diagram on paper, or pdf file, my See Electrical V6R1 includes notice "school licence" to my printing.
Anybody, who know, how can I remove this notice?
forsaken33
Post by forsaken33 » Mon Feb 11, 2013 8:26 am
hello.
please!!
-I need to have full electrical see, can you help me?
on my pc I have no version installed, you could tell me step by step what I need to have this software completely??
please
There are some links that do not work, could resubirlos?
forsaken33
Post by forsaken33 » Thu Mar 07, 2013 6:03 pm
hello
can you help me ??? please
I need see electrical v7 100% ok
but patch v7 build 15 is k.o
please re-up!!
I need symbols-eu
please!!!
patximarin
Post by patximarin » Wed Mar 27, 2013 5:00 pm
Hello my friends. I have the see electrical v7r1 build 14 spanish demo version. I need full version. Anybody have the patch to full?
Thanks.....and sorry, my english is not very good.
Really is a good forum
Carmelinfc
Post by Carmelinfc » Sun Mar 31, 2013 12:09 am
If you look at my post, the links still work if I have not checked, can get all the files to have the full program.
(usearch) (usearch) (usearch)
C.
hgg70
Post by hgg70 » Wed Apr 03, 2013 10:16 am
Patch for build 16 ???
Please
sasko
Post by sasko » Thu Apr 11, 2013 10:42 pm
I already got the V14, worked fine, today I got a message
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: caddy....
R6030
-CRT not initialised
I allready tried to reinstal the C++ versions and system restore but nothing helped me.
Any idea ?
Oll Bell
How can i Clear the Registry from See Electrical?
Post by Oll Bell » Tue Apr 16, 2013 7:41 pm
How can i clear the registry from "See Electrical"?
coffeerain
Post by coffeerain » Mon May 06, 2013 12:42 pm
hi, bsod
please update the patch for build16 when you are free,thanks in advance.
autobotsmala
Post by autobotsmala » Mon May 20, 2013 6:27 pm
Hi Friends,
Can someone upload again the patch for version 14 or 15!
modul
Post by modul » Fri May 31, 2013 7:20 am
The program exists in my native language but in different program version.
There's a demo of SEE Electrical V5 with my language (Greek)
Is there anyway to make the transition in it?
If so which files need editting?
Thank you in advance guys.
Systeme
Post by Systeme » Tue Jun 25, 2013 3:32 pm
I have problem. I just want look if i have Advence or Basic version ...
And i have ..... Why ?
yise111
Post by yise111 » Tue Jul 09, 2013 9:24 am
Please Make Patch for V7R1 build 16 ???thanks~
blank0
Post by blank0 » Wed Aug 07, 2013 7:33 pm
Hi everyone,
I have See electrical 7r1 build20 PL. It have increased protections.
I've found that SYS0001.dll is protected by encrypted HASH stored in SYS0001.enc.
This file contains 32 Bit of encrypted hash stored in plain text not binary. My guess it's RC4 encryption (ARCFOUR), becuse this algorithm is implemented in see electrical to store licenses etc.
Same situation with SEEProtection.dll and SEEProtection.enc.
It will be nice if someone check this by tracking code execution with softice like program;).
Any change of dll's or enc files causes alert message "You're using wrong type of SYS0001.dll".
And additionally Keyac5.dll have some nice code in it :
?FREE_LICENSES@@YGHXZ
?FREE_MODULE_LICENSES@@YGHH@Z
?GET_WRITE_DATA_TO_REGISTER@@YGHXZ
?INIT_KEY_TYPE@@YGHHHHPAD@Z
?KEY_BITGET@@YGFGFF@Z
?KEY_BITSET@@YGXPAXFFF@Z
?KEY_CHECK_DATAMOD@@YGHHHHPADHPAH@Z
?KEY_CLEAR_REGISTERS@@YGHXZ
?KEY_DEFINE_FORMAT@@YGXH@Z
?KEY_DEFINE_GAMA@@YGXH@Z
?KEY_GET_DATAMOD@@YGHHPAH0PAD00000PAI2@Z
?KEY_GET_MODE@@YGHH@Z
?KEY_GET_NET_HASP_LOG_PARAM@@YGXPAH0PAD0@Z
?KEY_GET_PRODINFO@@YGHPAH0000PAD0@Z
?KEY_GET_PRODINFO2@@YGHPAHPADPAI00010@Z
?KEY_GET_SEE_TYPE@@YGHXZ
?KEY_GET_SERIAL@@YGHPADH@Z
?KEY_GET_TYPE@@YGHXZ
?KEY_GET_TYPE_REMOTE@@YGHPAD@Z
?KEY_HAVE_SIGNATURE@@YGHPAH@Z
?KEY_IS_STANDARD_REGISTRY@@YG?AW4EMod@@H@Z
?KEY_IS_USING_DATAMOD@@YGHH@Z
?KEY_NETHASP_CLOSE@@YGHXZ
?KEY_NETHASP_LAST_ERROR@@YGHXZ
?KEY_NETHASP_READ_MODULE@@YGHHPAH0@Z
?KEY_NETHASP_READ_MODULEX@@YGHHPAH0@Z
?KEY_NETHASP_SET_DATA_NBMOD@@YGXHPAD@Z
?KEY_NETHASP_SET_NBMOD@@YGXH@Z
?KEY_NETHASP_SET_PARAM@@YGXHH@Z
?KEY_NETHASP_SET_PARAM_FROM_PROG@@YGXHH@Z
?KEY_NETHASP_SET_PROG_NUM@@YGXH@Z
?KEY_NETHASP_SET_SRV_NAME_FROM_PROG@@YGXPADH@Z
?KEY_NETHASP_WRITE_MAXMODULE_SEE@@YGHHH@Z
?KEY_NETHASP_WRITE_MAXMODULE_XELEC@@YGHHH@Z
?KEY_NETHASP_WRITE_MODULE@@YGHHHH@Z
?KEY_NETHASP_WRITE_MODULEX@@YGHHHH@Z
?KEY_READ_REGISTER@@YGHHPAH@Z
?KEY_SET_SEE_TYPE@@YGXH@Z
?KEY_SPECIFIC@@YGHHH@Z
?KEY_WRITE_BINARY@@YGHHHHPADHHHHHH@Z
?KEY_WRITE_DATAMOD@@YGHHHHPADHHHHH@Z
?KEY_WRITE_PRODINFO@@YGHHHHHHHH@Z
?KEY_WRITE_REGISTER@@YGHHH@Z
?KEY_WRITE_SIGNATURE@@YGHH@Z
?ONLY_FOR_CODE_CALCUL_DO_NOT_WRITE@@YGXH@Z
?PROG_KEY_WITHCODE@@YGHPBDHP6GXHH@Z_N@Z
?RETURN_CODE@@YGPBDHPBD@Z
?SEEK_FOR_NET_HASP_ONLY@@YGX_N@Z
Cheers blank0
wangrenzhi
Post by wangrenzhi » Fri Aug 09, 2013 5:06 am
How to add code to Keyac5.dll?
blank0
Post by blank0 » Sun Aug 11, 2013 6:36 pm
This dll is a part of HASP HL dongle programmer, simply we can write dongle with license file received from IGE-XAO.
License file contains data like this:
[INFO]
Version=4.00
CLIENT=
CONTACT=
ADRESSE=
CODE_SOCIETE=
CODE_POSTAL=
VILLE=
NOM_PAYS=
Prod=S2000_SeeElect
Vers=7.1
Dest=CLIENT
Tcli=INDUSTRIE
Pays=
Utemps=DATE
[KEY]
N=XXXXXXX
P=0
C=XXXXXXXXXXXXXXXXXXXXXX
V=0
[MOD]
1=DIAGRAM,,1 Advanced,,,,,
2=INSTALL,,1 Advanced,,,,,
Mod section seems to be only informative, all options are hidden in N=XXX.. and C=XXX...
bsod
Re: [REQUEST} SEE Electrical V7R1 Build21
Post by bsod » Wed Oct 30, 2013 10:31 pm
for V7R1 Build 21
http://www.upnito.sk/subor/3e6cce30ff9c ... 31be5.html
PW: IGE-XAO
bsod
trufellli
Post by trufellli » Thu Oct 31, 2013 7:13 pm
Hi Bsod
Any medicine for build 16 italian version?
thanks in advance.
I use the build 14 mixed italian - english, not the best way for work (not_allow).
please......I..need.
nice job for the rest.... (ev)
lvs445
Post by lvs445 » Fri Nov 01, 2013 8:07 am
Dear Bsod what you think about SEE v7r2 ? (dlink)
http://www.tucows.com/download.html?sof ... 593869&t=2
bsod
Post by bsod » Fri Nov 01, 2013 7:00 pm
for V7R1 Build 16 - not tested !!!
http://www.upnito.sk/subor/f5597cf1cc62 ... 29f5a.html
PW: IGE-XAO
bsod
djto
Post by djto » Fri Nov 01, 2013 11:24 pm
Hello
I have copied the last files of bsod in main directory Italian version
What is the procedure to activate See Electrical V7R1?
As I understand that it is activated?
many thanks
trufellli
Post by trufellli » Mon Nov 04, 2013 12:34 pm
many thanks bsod....u are the best.
I'll show you the full license activated.
http://www.hostingpics.net/viewer.php?i ... censed.jpg
trufellli
Post by trufellli » Mon Nov 04, 2013 12:55 pm
for djto.
I followed these steps:
- Install See Electrical v7R1 build 16 italian.
- Copy bsod file in main directory and overwrite them.
- Start See Electrical, click on information icon (i) on the right corner up.
- click on "registra il software"
- then "registra il software ora"
- fill all the fields that are showing and go to next tab
- Choose the radio button "il software è protetto tramite chiave hardware"
- fine
- go to file---imposta sistema--- tab licenza and view all the modules in advance level activated
- Enjoy.... (suc)
djto
Post by djto » Mon Nov 04, 2013 1:45 pm
Many Thanks
the software running
makakeo
Post by makakeo » Sat Nov 23, 2013 11:19 am
SEE Electrical ftp download:
Spoiler
vitjooks
Post by vitjooks » Wed Nov 27, 2013 6:30 pm
Hello
Who have Patch for SEE Electrical V7R2 ?
pblulu
Post by pblulu » Sat Nov 30, 2013 11:25 am
vitjooks wrote:Hello
I am looking for the same
jheekers
Post by jheekers » Mon Dec 09, 2013 7:58 pm
Hello everybody.
I have installed and cracked the DK version of V7R1 with the crack from BSOD.
But thats not my language. Is it possible to use it with an English or Dutch version?
And can sombody tell me were i can find it to download?
Many thanks
Arabilis
Post by Arabilis » Sun Jan 12, 2014 12:42 pm
Hello, could somebody upload the file again for See Electrical V7R1 build 21?
bsod
Post by bsod » Mon Jan 13, 2014 5:14 pm
@Arabilis
the patch for See Electrical V7R1 build 21 is still online
@jheekers
- download the V7R1 build14 in this post viewtopic.php?f=7&t=18647#p57134
- download the update files for build 21 ftp://ftp.caddy.dk/SEE%20Electrical/Opd ... uild%2021/
- download the patch for build 21 in this post viewtopic.php?f=7&t=18647&start=50#p63112
bsod
vitjooks
Post by vitjooks » Mon Jan 13, 2014 7:18 pm
Hello bsod
Maybe you have patch for V7R2?
bsod
Post by bsod » Mon Jan 13, 2014 7:44 pm
Hello vitjooks,
No, Do you have the setup file for V7R2 (english or german)?
bsod
lvs445
Post by lvs445 » Mon Jan 13, 2014 8:20 pm
[quote="bsod"]Hello bsod (pgood)
HI sir bsod where and how to send a files?
bsod
Post by bsod » Tue Jan 14, 2014 3:44 pm
SEE Electrical V7R2 Build 11
http://www.upnito.sk/subor/3b27ab04cda6 ... 99a76.html
PW: IGE-XAO
thanks @lvs445 for setup file !!!
bsod
remik
Post by remik » Wed Jan 15, 2014 1:24 pm
Thank You bsod (clap)
lvs445
Post by lvs445 » Wed Jan 15, 2014 3:49 pm
bsod ! You are a great master of of the years (clap)
pblulu
Post by pblulu » Sun Jan 19, 2014 2:24 pm
bsod
You are simply the best (clap)
hm205
Post by hm205 » Thu Jan 23, 2014 5:17 pm
Merci Bsod :D
babol9
Post by babol9 » Thu Jan 30, 2014 11:29 pm
thank you (pgood) (pgood) V7R2 builds down 11 Spanish demo and following instructions works but it seems to be no demo and installation not complete
I have to do something else?
thanks again
copain
Post by copain » Wed Feb 05, 2014 7:59 am
THX Bsod,
FR : hm205 ,Je cherche aussi la possibilité de pouvoir mettre à jour la base de donnée fabricant (références et symboles). As tu trouvé qqchose ? Il y a très peu de forum parlant de ce soft hélas.
Merci
EN: hm205, I'm trying to find too how to update the manufacturer's database (product number and symbols).. Did you find something ? This soft seems to be underrated from web .
vitjooks
Post by vitjooks » Tue Feb 11, 2014 9:29 am
Hello bsod
Maybe you have patch for V7R2 build 12?
ftp://ftp.caddy.dk/SEE%20Electrical/Opd ... uild%2012/
Sarrax
Post by Sarrax » Fri Feb 21, 2014 6:51 am
Hello everybody,
I have a problem with V7R2b11:
- I have downloaded and intalled See Electrical (setup-see-electrical-v7r2-b11-fr.exe).
- I have downloaded the patch (see_electrical_v7r2b11.exe) and executed it in See Electrical installation folder. The patch was OK.
When I run See Electrical, I am offered option "Register your licence now " or "Register later". I never have the option "My software is protected with hardware key".
If I select "Register later" and go in System parameters/Licence, I only have option "Find licence on Internet", no option "My software is protected with hardware key".
I have also tried to run Progdis5.exe but it returned errors
Can you help me?
Patrick90
Post by Patrick90 » Sat Feb 22, 2014 8:46 pm
I need a German cracked version os see electical. Here are so many links. What is the right one?
Mgros
Post by Mgros » Sun Feb 23, 2014 5:11 pm
See this post ...
viewtopic.php?f=7&t=20920
Patrick90
Post by Patrick90 » Fri Feb 28, 2014 9:32 pm
Mgros wrote:Hi,
See this post ...
its fr and not german?!
Patrick90
Post by Patrick90 » Sun Mar 09, 2014 6:57 pm
Patrick90 wrote:
Mgros wrote:Hi,
See this post ...
where can I download it?? I cant find it
Carlos
Post by Carlos » Mon Mar 10, 2014 6:40 pm
Patrick90 wrote: where can I download it?? I cant find it
http://www.ige-xao.com/
-> germany
-> downloads
-> software
-> see electrical test verson
-> some number and letters
et voilá, SeeElectrical_V7R2_DE_Build11.msi
(i not test with p..ch)
miradep
Post by miradep » Fri Mar 28, 2014 1:06 pm
First of all, thanks for the information i have learn here...
I need some help because i can´t put to work this portuguese version... If someone can help It will be very appreciated.
The version is this:
http://www.sa.online.pt/downloads/downl ... =6&idp=712
Thanks in advance and sorry about my english...
Carlos
Post by Carlos » Sat Mar 29, 2014 11:37 am
miradep wrote:Hi,
does not exist for build 12 :(
portuguese:
por agora só existe patch para a buld 11
xáu
miradep
Post by miradep » Sun Mar 30, 2014 1:00 pm
Thanks Carlos.
Do you know were i can get the b11? and the solution?
