[?]: Promis.e v8i for microstation
HI
I found some ftp link with all installation files of Promis.e v8i
but without crack for license
ftp://ftp.archwayftp.com/promise
please ,can some one here fix ore create a crack for the program ?
thx
thx
Re: [?]: Promis.e v8i (for microstation) link.CRACK NEEDED
I can. http://depositfiles.com/files/exslsi774djcatalyst wrote:can some one here fix ore create a crack for the program ?
thanx a lot for crack Linkinx64
i have only to short questions .
1. how i active it or where i should to put these .dll files ?
2. are these files working with AUTOCAD version of promis.e ? ( if not i will looking for promis.e for autocad and i will upload it for your expert look).
thanx anyway you r the genious.
Copy Bentley folder from archive over existing folder (default: C:\Program Files\Bentley in 32-bit Windows version, C:\Program Files (x86)\Bentley in 64-bit Windows version). Overwrite files on prompt.djcatalyst wrote:1. how i active it or where i should to put these .dll files ?
I don't know what is the "AUTOCAD version of Promis.e". These files are intended for the products I donwloaded by the link you provide at 22 of April (Promis.e and PowerDraft).djcatalyst wrote:2. are these files working with AUTOCAD version of promis.e ?
hello
Linkinx64
as i promissed , i found link with PROMIS.E for Aoutocad :
http://www.ndocs.ru/Compuware/Bntl/Bent ... utoCAD.zip
i think the link is a litle bit low it disconnected couple of times , but maybe you could downlod the pro.
and it wroten that is russian version , but i think it can be the multilanguage.
if you succeed to download it , please try to create some crack for it.
thnx a lot .
Linkinx64
thnx a lot .
The service pack 2 located by the link is not intended for Promis.e v08.11.07.146 (for AutoCAD):
More troubles happened after install. Autocad is crashing after I try to launch Promis.e v8i for AutoCAD:
Maybe it because I've cancelled the Promise's SQL instance for SQL Server...
I'm only able to make a "blind" crack now: by comparison of original and cracked versions of Bentley.liclib.dll for the PowerDraft (see linkz in post above).
3 very similar parrterns found and edited but operability of the software can't be checked. I can't install MS SQL because I have working SQL instance that is used for my work.
So, the operability test is up to you: http://depositfiles.com/files/lr3xukna7
P.S> Crack for Promis.e v8i Microstation should also work with Promis.e for Acad. Because Bentley.liclib is copying to the same folder during install...
oh,
thanx alot for your huge work Linkinx64
i will try totest it .
thanx again for everything
I have test software with license but after start software (promis-e for autocad) , it display some error like this:
"Command: (command "LoadEctEcad")
LoadEctEcad ; error: Exception occurred: 0xC0000005 (Access Violation)
Enter BACKSPACE to interrupt script.
nil
Command: (if (= InitOK "no") (command "ECAD_EXEC_SETUP"))
and I checked in the license management tool, it display :
Microstation Power Draft : Trial expires in 26 days
1777 : Trial expires in 26 days.
Could you see it or may be I did something wrong to apply license.
Thanks and regards.
nil
Thanks and regards.
I know it. But after 26 days nothing will happens.mytom123 wrote:and I checked in the license management tool, it display :
Check it: set windows date 1 month forward and try to launch PowerDraft. License manager will show "expired" but PowerDraft continue work.
Does it happened after you applied the "license"?mytom123 wrote:I have test software with license but after start software (promis-e for autocad) , it display some error like this:
nil
I will check for this issue if so. Which AutoCAD version you use?
It was happened after I start program, and already add license.
My Cad software is autocad 2007.
Brgds.
Brgds.
please guys help
ive tried to download autocad version from link what i found :
( http://www.ndocs.ru/Compuware/Bntl/Bent ... utoCAD.zip )
but it all the time disconnected
if some one of you succeed to comple the download please upload it to another link so i will download it completley
thx alot
thx alot
ohhh
thanks alot BROTHERS.
you saved my ass//
you saved my ass//
This is an internal Promis.e or AutoCAD 2007 error, have nothing to do with my crack.
Test configuration: OS Windows XP Pro SP3 + AutoCAD 2007 + Promis.e v8i for AutoCAD v08.11.07.146 + crack http://depositfiles.com/files/lr3xukna7 - all works.
This error message appears disregarding to the crack. Means, without crack it appears too.mytom123 wrote:I have test software with license but after start software (promis-e for autocad) , it display some error like this:
nil
hey guys
how i schould open these files : Bentley_Promise_v8i_for_AutoCAD.crc , and the others
please help
.crc file ?
how i extract it?
thx
please help
.crc file ?
how i extract it?
thx
You can use some software to combine files, like total commander or others.
After that you can install this package.
Brgds.
Brgds.
ohh
im totaly confused , ine tried to do something with total comander but with no results.
please can you explain me how can i extract all these filese to one folder with the program?
sorrry
thx
sorrry
thx
All files in one folder, choose 1 file .Ex: The left window display source files, the right window display the destination after merge.
Merge with total commander menu File > Combine
After combine 001+002+...+... to one archive file you can unpack it.
Brdgs
Brdgs
thx
i did it as you explained , it works
[LINK]: promis.e v8i for AutoCAD x64/x86 [08.11.08.22]
64-bit edition of promis.e v8i for AutoCAD now available:
http://www.filefactory.com/file/ce8309d ... 22_x64.rar
308Mb
This version require 64-bit edition of AutoCAD (2007 through 2010).
32-bit edition:
http://www.filefactory.com/file/ce831d2 ... 22_x86.rar
312Mb
308Mb
32-bit edition:
312Mb
This is some link for promis e select series 5, but I don't have crack.
Any have it? And how to install.
ftp://64.90.235.41/pub/knowledgebase/at ... .10.63.zip
ftp://64.90.235.41/pub/knowledgebase/at ... .10.65.zip
ftp://64.90.235.41/pub/knowledgebase/at ... .10.64.zip
I have more recent versions of promis.e for AutoCAD than your:
promis.e for AutoCAD v08.11.10.66 [x64]:
http://www.filefactory.com/file/2cvlaeh ... 66_x64.rar
promis.e for AutoCAD v08.11.10.66 [x86]:
http://www.filefactory.com/file/2gnc4ez ... 66_x86.rar
promis.e for AutoCAD v08.11.11.18 [x64] (w/o prerequisites):
http://www.filefactory.com/file/45xt1u5 ... .part1.rar
http://www.filefactory.com/file/21srsg7 ... .part2.rar
http://www.filefactory.com/file/1b6j48w ... .part3.rar
promis.e for AutoCAD v08.11.11.18 [x86] (w/o prerequisites):
http://www.filefactory.com/file/6kqawwj ... .part1.rar
http://www.filefactory.com/file/2i3girc ... .part2.rar
http://www.filefactory.com/file/1oqy3ci ... .part3.rar
Installation order:
1. Install AutoCAD (supported versions: 2007 - 2011, not included).
2. Download a proper version of promis.e for AutoCAD.
3. Install Prerequisites (see prerequisites folder).
4. Install Promis.e (setup folder): x86 for 32-bit version of AutoCAD, x64 for 64-bit version of AutoCAD.
5. Copy file from crack folder to the proper place.
Installation order:
Linkinx64, thanks!
I just install 32 bit version.
hello,Linkinx64,
the links does not workig....
Anybody can provide a link of Promis.e of first post ( compatible with medicine and NOT autocad version)?
Re: [?]: Promis.e v8i for microstation
i try it, but its give me message to inseret other file location....
any one can help, by providing the set-up program for promis-e (SELECT Series 7) with crack? for 64 bit.
Hello Linkinx64,
Can you check the link of Promise series 5?
Thank you so much!
Thank you so much!
Checked. Re-uploaded.
Hello Linkinx64,
Thank you very much!
hi all,
I have a promis-e v8i (select serial 7), but without crack.
Please can some on fix it.
Thanks!
Thanks!
