Try to use the following...
Note*) The new Studio 5000 V21.0.0.0 from now on uses digital signatures to protect the files.
This method will work for now on.
Patch to allow licenses:
Hexedit flexsvr.exe at address E4D0
Replace 55 8B EC 83 E4 F8 81 EC with 33 C0 40 89 45 FC 48 C3
Patch to accept licenses:
Hexedit C:\Program Files\Common Files\Rockwell\FTACommon.dll at address 40FB9
Replace 34 02 with 30 90
Patch to bypass digital signature check:
Hexedit C:\Program Files\Rockwell Software\Studio 5000\Launcher\ActivationInterop.dll at address 5C86
Hexedit C:\Program Files\Rockwell Software\Studio 5000\Logix Designer\ENU\v21\Bin\LogixDesigner.exe at address 1DFAF6 (V21.0.0)
Hexedit C:\Program Files\Rockwell Software\RSLinx\RSLINX.EXE at address D9092 (V3.51.10.00)
Replace 0F 85 46 03 00 00 with E9 2C 00 00 00 90
It now shows a message stating that files have been altered.
The following will remove these messages:
Patch to bypass digital signature warning message
Hexedit C:\Program Files\Rockwell Software\Studio 5000\Launcher\ftastub.dll at address FCD
Hexedit C:\Program Files\Rockwell Software\Studio 5000\Logix Designer\ENU\v21\Bin\ftastub.dll at address FCD
Hexedit C:\Program Files\Rockwell Software\RSLinx\FTAStub.dll at address FCD
Replace 40 03 with 09 00
FEATURE RS5K_700.exe flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RS5K_700.exe" SN=8283999999 \
SIGN="0088 4C88 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FFFF FFFF FFFF FFFF"
FEATURE RSLINX.EXE flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSLINX.EXE" SN=8283999999 \
SIGN="00BF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RSLINX.GW flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSLINX.EXE Gateway" SN=8283999999 \
SIGN="00CF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RSLINX.SN flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSLINX.EXE SN" SN=8283999999 \
SIGN="00DF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RS5K_GLX.exe flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RS5K_GLX.exe" SN=8283999999 \
SIGN="00EF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RS5K_MLP.exe flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RS5K_MLP.exe" SN=8283999999 \
SIGN="00FF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RS5K_000.exe flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
SIGN="009F 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
I tested and the software run very well.
I put archive in 4shared, you'll need put the archive in folder and update license.
for ex:
there is a archive in folder with "LogixDesigner.exe" name. Is olny put in folder:
And replace old archive.
