[?]: WinCC Advanced/Flexible "MISSING USER RIGHTS..."?
Homeroid_BL
Post by Homeroid_BL » Tue May 28, 2013 11:25 pm
Hi all!
Suddenly, I can not connect any PC HMI application to S7-1200 (6ES7 214-1AG31-0XB0) via Ethernet.
Both HMIs, WinCC Advanced V11 SP2, and WinCC Flexible 2008 SP2
reports an error:
"missing user rights to write into registry"
Flex RunTime Error
WinCC TIA Error
All the time PLC is online, visible, working fine.
TIA Prog OnLine & WinCC TIA Error
Someone knows what is going on?
dls.dls
Re: [?]: WinCC Advanced/Flexible "MISSING USER RIGHTS..."?
Post by dls.dls » Wed May 29, 2013 7:15 pm
With the fault number (1400XX) you will mabe found any détails in the documentation.
Good luke!
Homeroid_BL
Post by Homeroid_BL » Thu May 30, 2013 9:16 am
Nice joke, dls.dls :) Since documentation tells that "my station is not connected", so i should "check cable and wiring" :)
Post by sania » Sat Jun 01, 2013 6:44 pm
set your pg/pc interface as tcp/ip - your net card
Homeroid_BL
Post by Homeroid_BL » Sun Jun 02, 2013 3:29 pm
It was set to TCP/IP, bu access point was MicroWin, not S7ONLINE.
Changing access point to S7ONLINE, problem was solved.
But, it menas that in TIA Portal:
-connection to PLC work regardles of PG/PC interface set (not relevant)
-connection to HMI considers PG/PC interface settings?????
Anywy, error description as "missing user rights" did not help me solving problem, it's just confusing description.
Sania, thanks!
Post by sania » Mon Jun 03, 2013 7:17 am
Homeroid_BL wrote:But, it menas that in TIA Portal:
yes it is
