[Request] Switch to Vijeo Designer "S2VD"
leofarhan
Post by leofarhan » Wed Jun 10, 2009 8:48 pm
If anyone have Switch to Vijeo designer i.e S2VD Please Upload it.
Schtiel
Post by Schtiel » Thu Jun 11, 2009 5:47 am
What is S2VD? Any link to its description?
leofarhan
S2VD is Switch To Vijeo Designer
Post by leofarhan » Thu Jun 11, 2009 2:19 pm
S2VD is Schneider Utility which is used for internal / system integrator application.
This utility / software convert XBTL1000 file (i.e. for XBTF Series) to Vijeo Designer file (i.e. XBTGT Series Application).
The main purpose of this utility is to convert software enviorment. (i.e. XBTL1000 to vijeo Designer)
This utility is free of cost, but not available for downloading. One have to get a training in order to get this utility.
If anyone have utility, please upload it.
Links regarding S2VD are listed below
http://www.schneiderelectric.bg/forum/v ... b592603c51
http://www.schneider-electric.cz/downlo ... _ASRTP.pdf (Page No. 21)[/img]
leofarhan
Re: [Request] Switch to Vijeo Designer "S2VD"
Post by leofarhan » Sat Mar 06, 2010 7:32 pm
Thanks Schtiel & Dustin
cesarmecatronik
Post by cesarmecatronik » Wed May 22, 2013 6:34 pm
hi, you can upload tje aplication again please? the links dont works
vlad2006gr
Post by vlad2006gr » Wed May 22, 2013 9:34 pm
Rapidshare link is work!
carter666
Post by carter666 » Thu May 22, 2014 9:54 am
Can You upload a new link? Because the link does not exist. And I have to convert an application from the XBT-F on XBT-GT. And i need the S2VD.
alimicro
Post by alimicro » Sun Nov 09, 2014 6:03 pm
Can You upload a new link? Because the link does not exist. And I have to convert an application from the XBl-1000 on XBT-GT. And i need the S2VD.
Carlos
Post by Carlos » Sun Nov 09, 2014 8:26 pm
gycu
Post by gycu » Tue Apr 24, 2018 6:59 am
Hey guys,
Thanks for the uploads.
I installed Vijeo Designer 5.0, then SP1 and XBTL-1000 4.51
I downloaded Switch_to_VJD.rar and from here I installed the "Switch from XBTL1000 2 Vijeo.exe" and after some failed attempts to convert a project, I also installed MBX Driver Suite, from the same archive.
With every attempt I make to Import a dop file in Vijeo Designer, I get the same error message "XBTL1000 has stopped before end of information extraction.
Can you help me with this? Thank you in advance!
apilife
Post by apilife » Wed Apr 25, 2018 9:29 am
Hi gycu,
Are you sure the DOP file is done with XBT-L1000 and not Vijeo Designer Lite ?
What model of HMI is it for ? S2VD is made for XBT-F conversion...
Could you send your DOP file ?
This S2VD is quite old and doesn't always work.
(MBX Driver Suite is not needed for conversion.)
gycu
Post by gycu » Thu May 10, 2018 7:43 am
apilife wrote:Hi gycu,
Thanks for your reply and sorry for the late reply, I was out of town for some time.
I'm pretty sure the software is made with XBTL-1000, as it is very old and as I can open it with XBT-L1000.
The HMI is an XBTE016110, are you sure only XBTF's can be converted?
I sent you on pm the .dop
Thank you.
Cheers
