Info: TIA Portal V13 SP2 Trial is ready for download
Info
Post by Info » Wed Feb 27, 2013 8:29 pm
Only for registered user!
https://support.industry.siemens.com/cs ... ankingDesc
https://support.automation.siemens.com/ ... aller=view
for others
viewtopic.php?f=30&t=19323
(mirr) https://disk.yandex.ru/d/3bvO_CWyzwiN_w
TIA Portal v13 Documentation
http://support.automation.siemens.com/W ... 804/133300
S7-1500 Documentation
http://support.automation.siemens.com/W ... 743/133300
S7-1500 parts are available for delivery from 17.4.2013
1511-1PN list price is 620 €.
1513-1PN list price is 1380 €.
1513-3PN/DP list price is 3400 €.
Juli
Re: Info: TIA V12 Trial is ready for download
Post by Juli » Wed Feb 27, 2013 8:32 pm
:D :D :D :D
Yes ...... I am a registered user (suc) (suc)
Gauss73
Post by Gauss73 » Wed Feb 27, 2013 9:44 pm
Hello!
When can We download the whole application? Not just a trial! Have Anyone some inform? (clap)
centipede
Post by centipede » Wed Feb 27, 2013 9:56 pm
Here the Links for WinCC V12:
http://support.automation.siemens.com/W ... e/67797298
and the Trial is the complete Software, just need a License ;-)
Post by CoMod » Wed Feb 27, 2013 10:11 pm
centipede wrote:Here the Links for WinCC V12:
Install TIA Portal v12 and run EKB :lol: see new keys for testing only
just EXE Image (boom)
and 8 GB
Recommended PC/PG hardware 64-bit operating system
Core i5, 2.4 GHz or comparable
8 GB
1280x1024
Windows 7
centipede
Post by centipede » Wed Feb 27, 2013 10:17 pm
Post by CoMod » Thu Feb 28, 2013 7:31 am
First error - can't create new project / migrate old :D
W7 x64 +Step7 5.5, Flex 2008 SP3 + TIA Portal 11 + TIA Portal 12 + Kaspersky KIS 2013
TIA Portal 11 is Ok
TIA Portal 12 Installed without problem on:
Windows 7 x64 Home Edition (for install need edit SIA2.INI)
Windows XP SP3 x32
Homeroid_BL
Re: Info: TIA Portal V12 Trial is ready for download
Post by Homeroid_BL » Thu Feb 28, 2013 9:30 am
Hehehe Simatic software has bugs? Miracle! :)
CoMod, could you post a link to the EKB_Instal file which contains V12 licences?
I have Simatic_EKB_Install_2012_07_19; Simatic_EKB_Install_2012_09_29; Simatic_EKB_Install_2012_10_12; Simatic_EKB_Install_2013_01_21 - but I can not find any V12 keys in those files.
flashy
Post by flashy » Thu Feb 28, 2013 9:35 am
Once you have installed TIA Portal V12 :!: :!: :!:
Open up EKB installer, and select New Keys = x from the top left hand corner, you will then see V12 licences (but only for W7 - with XP this option not work)
##~FlashY~## 8) :lol:
Homeroid_BL
Post by Homeroid_BL » Thu Feb 28, 2013 9:41 am
"Once you have installed V12" - must satisfy this first :)
Info
Post by Info » Thu Feb 28, 2013 4:35 pm
The ekb_install is not able to create a license for WinCC V12, for Step7 it is OK.
wait 8 march 2013
Gauss73
Post by Gauss73 » Thu Feb 28, 2013 9:25 pm
I don't see any V12 in the EKB (2013/1/21) as flashy. So, I found a V12 area but is emty and don't belong V12 in the New keys menu. It's run because it is a trial version. Maybe I think?!
Any idea? Thanks!
daniel4632
Post by daniel4632 » Fri Mar 01, 2013 8:06 am
Anyone know when Safety Advanced V12 will be available? Tried to install V11 after installing STEP 7 V12 but of cause it wasn't possible. Is there a workaround?
-- D
Homeroid_BL
Post by Homeroid_BL » Fri Mar 01, 2013 12:37 pm
Anyone yet installed succesfully TIAP V12?
On Win7 32-bit?
Is it possible to open new project (CoMod had problems)?
Is it possible to open V11 project?
Does V12 uprade V11, or after instalation there are V11 and V12 both?
I have downloaded all, but I am affraid to instal becouse I know tha V12 is pretty buggy (expecetd SP1 of 3GB cca), and I want to have functional V11.
centipede
Post by centipede » Fri Mar 01, 2013 2:00 pm
You can open V11 projects and its your decision to save as V11 or migrate to V12.
You can install V12 parallel to V11, so you can use bothe TIAs.
daniel4632
Post by daniel4632 » Sat Mar 02, 2013 12:15 am
STEP 7 V12 & V11 will install on the same computer WinCC V12 & V11 will not, just tried.
manuelsaurio
Cannot open TIA V11 file in TIA V12
Post by manuelsaurio » Mon Apr 01, 2013 2:40 am
Dea All,
I'm trying to test TIA V12 and I'm not able to open my V11 projects.
The following error is showed
"Memory area is write protected", error code 0080:000014.
manuelsaurio
Re: Cannot open TIA V11 file in TIA V12
Post by manuelsaurio » Mon Apr 01, 2013 5:30 pm
I've the same error as coMod !!!
Is it a EKB licensing problem or a V12 bug?
tanghm
Post by tanghm » Wed Apr 24, 2013 6:33 pm
I think it is not EKB license problem.
SiemensUser
Post by SiemensUser » Mon May 06, 2013 4:21 pm
Could someone please upload the V12 download files on Rapidshare etc. I cannot download those files directly from Siemens even as a registered user,
Thanks!
boost_up
Post by boost_up » Mon Jun 17, 2013 10:31 pm
Does anyone have the V12+SP1 (that includes the Safety Advanced). I'm getting an error with the safety program of a 317-2PN/DP.
Scarch
Post by Scarch » Sat Jun 22, 2013 1:53 am
Let's wait a couple of years, as usual with the "software" from siemens.
Customers are betatesters (boom)
boost_up
Post by boost_up » Sat Jun 22, 2013 6:42 pm
Yep, as allways the oldest software is the best one to work.
Django_2013
Post by Django_2013 » Thu Jun 27, 2013 3:57 pm
Ok...then.... Does EKB create a valid WinCC V12 Licence or not?
And sth. other.... What is the actually version of EKB?
Is the Version from March still the newest?
Hope smbdy can tell me that.
Thankx a lot!
Post by CoMod » Thu Jun 27, 2013 4:00 pm
Django_2013 wrote: What is the actually version of EKB?
:anon: viewtopic.php?f=30&t=218
Update
Post by Update » Wed Jul 24, 2013 6:28 pm
Servicepack 1 für STEP 7 V12 and PLCSIM 1500 v12
http://support.automation.siemens.com/W ... e/76276623
LINK
http://support.automation.siemens.com/W ... e/75277515
Servicepack 1 für WinCC V12
http://support.automation.siemens.com/W ... e/73956248
STEP_7_Professional_SP1_for_V12
S7_PLCSIM_V12_SP1
WinCC_Professional_SP1_for_V12
WinCC_Comfort_Advanced_SP1_for_V12
WinCC_Basic_SP1_for_V12
WinCC_Runtime_Advanced_SP1_for_V12
StartDrive v12 SP1 http://support.automation.siemens.com/W ... e/77330014
http://support.automation.siemens.com/W ... e/68034568
elchavo2003
Post by elchavo2003 » Tue Jul 30, 2013 2:47 pm
http://support.automation.siemens.com/W ... e/68034568[/quote]
Can someone post StartDrive SP1 alternative link?
Rex2701
Post by Rex2701 » Tue Jul 30, 2013 5:18 pm
elchavo2003 wrote:StartDrive v12 SP1 http://support.automation.siemens.com/W ... e/77330014
viewtopic.php?f=30&t=20059
Re: Info: TIA Portal V12 SP1 Trial is ready for download
Post by CoMod » Tue Jul 30, 2013 5:30 pm
Argentina is not in Black zone - try to register
Rex - You can send your personal link in private message
Вы можете послать свою личную ссылку через Личные сообщения
***s://support.automation.siemens.com/secret/**/**********_68034568_DL/SINAMICS_Startdrive_V12_SP1_Optionspaket.zip
eseq
Post by eseq » Wed Aug 07, 2013 11:23 am
Hi All,
Can somebody share a link for WinCC V12 Runtime advanced please?
yayca
Post by yayca » Thu Mar 13, 2014 10:51 am
Where can I download the installation DVD WinCC Runtime Professional 12?
Info
Info: TIA Portal V13 SP1 Trial is ready for download
Post by Info » Sat Jan 10, 2015 9:06 am
Full installer
SIMATIC STEP 7 (TIA Portal) V13 SP1 TRIAL Download
http://support.automation.siemens.com/W ... /106448872
SIMATIC WinCC V13 SP1 TRIAL available for Download
http://support.automation.siemens.com/W ... /106567563
Service Pack package
SIMATIC_STEP_7_Professional_SP1 http://support.automation.siemens.com/W ... /105825934
WinCC V13 Service Pack 1 http://support.automation.siemens.com/W ... /106567433
Startdrive V13 Service Pack 1 http://support.automation.siemens.com/W ... n/68034568
Safety V13 Service Pack 1 http://support.automation.siemens.com/W ... /108442820
StartDrive V13 SP1 https://mega.co.nz/#!B5Z2HL5T!jf7g8-HGX ... tbmkv2WyIk
Roozen
Re: Info: TIA Portal V13 SP1 Trial is ready for download
Post by Roozen » Fri Jan 29, 2016 5:49 pm
Hello
Is wincc professional v13 software pack contains wincc runtime?
I have installed wincc pro v13 but there is no runtime installed on my pc.
Regards
Sie-auto
Post by Sie-auto » Mon Feb 15, 2016 4:20 pm
You can use google translate at this site http://vocsyit.com/threads/229 at point 13. Or that this thread http://goo.gl/KXAb1B
Sie-auto
engma
Post by engma » Tue Mar 29, 2016 10:48 am
I installed Tia portal v13 and the ekb and it worked fine but after a month from installation an error message appeared sometimes while working. and it requires to close the portal and open it again. Is there any solution for this problem?
mariobo11
Post by mariobo11 » Wed Jun 22, 2016 1:57 pm
Is there anywhere only PLCSIM v13 for download and will it work along with TIA Portal v12 for simulation of CPU1200?
Thanks!
