It is currently Fri Jan 18, 2019 5:29 pm
Post new topic Reply to topic  [ 25 posts ]
 Post subject: [LINK]: Softlogix v20
PostPosted: Sun Aug 05, 2012 3:31 pm
Hello everyone,
Can anybody upload Softlogix v20?
Thank you very much for your attention.
PostPosted: Sat Oct 13, 2012 4:55 pm
http://www.4shared.com/rar/4RuBk8MF/SoftLogix5800_2000.html
PostPosted: Sun Oct 14, 2012 12:49 pm
hi (fback) (fback) (fback)
i want to ask how i activate Softlogix v20 can you help me in that
thanks to you
PostPosted: Wed Oct 17, 2012 3:33 pm
Dear guolibin,
Thank you very much for share! (tyou)
hussein kamal look here:
http://plcforum.uz.ua/viewtopic.php?f=41&t=15633&start=50#p54538
PostPosted: Wed Oct 17, 2012 10:46 pm
Dear dimodimo
thank you for helping me but i try to activated using that's way but not working because that's first time to make that if you have description how make it i will be grateful
(tyou) (tyou)
PostPosted: Thu Dec 20, 2012 10:34 pm
Here it goes
Tested and working
1-On the folder "C:\Program Files\Rockwell Automation\SoftLogix5800"
Look for the fallowing DLL RSSL5K32.dll
Hex edit:
Change 34 02 to 30 90
2-On the folder "C:\Documents and Settings\All Users\Documents\Rockwell Automation\Activations"
Add on the "ftasystem.lic" file the fallowing entry:
HOSTID=ANY vendor_info="PRODUCT_NAME:oftLogix5860" SN=0000000001 \
FFFF FFFF FFFF FFFF"
Good luck (pgood)
PostPosted: Fri Dec 21, 2012 5:28 am
hi grayfox,
I can find 34 02!!!!! :o :o :o :o :o
what can i do??? :? :? :? :?
(sos) (sos)
PostPosted: Sun Jan 06, 2013 5:58 pm
It's working now.... :D :D
Thank you... (tyou) (tyou)
PostPosted: Fri Jan 18, 2013 9:56 pm
Could you explain with more details? Because I already look for "34 02" with HexEdit Pro, but I got a lot of results, wich one should I change to "30 90"? If I change only the first one SoftLogix doesn't execute, if I change every one i get "Activation Error". (no)
Thanks in advance!
PostPosted: Mon Jan 28, 2013 6:40 pm
HI ALL
Sorry all ,but Why not working with me this activation Softlogix V20?
Hex edit:
Change 34 02 to 30 90 FC339
MY RESULTS :
In Factory Talk manager / TAB Manage Activations I see properly license SoftLogix 5860 but NOT WORKING !!
When I run SoftLogix Chassis Monitor a window appears that says : Failed to activate SoftLogix 5800
Why ? Please Help me !!! Thanks
PostPosted: Tue Jan 29, 2013 9:05 pm
Try to disable rs master license if you have it.
just comment the rows with rsmaster and check
On my PC it worked.
PostPosted: Wed Jan 30, 2013 7:49 pm
(oo) (clap) (gpost)
Great !! Thanks mdim Now work !!
(tyou)
PostPosted: Sat Feb 16, 2013 12:09 am
On my PC it worked.
(gpost)
Amazing, it works like magic!!
Thanks!!
PostPosted: Fri Apr 05, 2013 10:12 pm
On my PC it worked.
Incredible it works perfectly thanks mdim
PostPosted: Mon Apr 08, 2013 8:35 pm
On my PC it worked.
(oo)
PERFET, MAN!!!!
All working now!
Thanks a lot!!!
(gpost)
PostPosted: Fri Apr 26, 2013 5:54 pm
I need some assistance, I'm getting the following .....
I do not have any master license to disable....here is what I have.....
SERVER this_host ANY
USE_SERVER
VENDOR flexsvr
INCREMENT fta.system flexsvr 1.00 permanent 1 VENDOR_STRING=1 \
vendor_info="PRODUCT_NAME:FTA System Placeholder" SN=1 \
SIGN="00FB D8C8 C8F8 49F2 480A E303 5567 E100 A110 03FF 3224 \
F038 B859 C955 5900"
FEATURE RS5K_700.exe flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RS5K_700.exe" SN=8283999999 \
SIGN="0088 4C88 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RSLINX.EXE flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSLINX.EXE" SN=8283999999 \
SIGN="00BF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RSLINX.GW flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSLINX.EXE Gateway" SN=8283999999 \
SIGN="00CF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RSLINX.SN flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSLINX.EXE SN" SN=8283999999 \
SIGN="00DF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RS5K_GLX.exe flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RS5K_GLX.exe" SN=8283999999 \
SIGN="00EF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RS5K_MLP.exe flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RS5K_MLP.exe" SN=8283999999 \
SIGN="00FF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RS5K_000.exe flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
SIGN="009F 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
PostPosted: Wed Jun 05, 2013 6:09 am
" Failed to activate SoftLogix5800: No activations available "
Why and How ?
PostPosted: Wed Jun 05, 2013 6:18 pm
Why = You forgot or haven't done some patching required.
How = You need to patch and install the correct license.
PostPosted: Thu Jun 06, 2013 7:37 pm
Dear All Expert Member,
Is it possible install Softlogix and RSLogix Emulate at the same time ?
Because I had try to install Softlogix V20 and RSLogix Emulate V20.01 not succes. (wow) (no)
"The windows message pop up show is incompatible "
PostPosted: Sun Jan 19, 2014 4:48 pm
Working fine! Thanks!
PostPosted: Tue Nov 25, 2014 7:58 pm
Hello I tried the same method as well but I am also getting a message that says can't be actived and I do not see a master license in my activations?
Could someone please enlighten me as to where did you find yours?
Thank You!
PostPosted: Mon Sep 14, 2015 4:35 pm
Hello All,
I need to use softlogix 5800 v20, I have installed but stuck at activation.
I have tried a lot of times with Hex editing RSSL5K32.dll but still unable to get softlogix activated.
It would be a great help for me if anyone can upload patched RSSL5K32.dll file and ftasystem.lic.
PostPosted: Wed Oct 18, 2017 8:38 pm
On my PC it worked.
sorry, but how to disable rs master license?
PostPosted: Sun Dec 17, 2017 3:14 am
There is nothing there. It shows "invalid link"
guolibin wrote:
Is there another link where I can download softlogix v20?
PostPosted: Fri Jun 01, 2018 1:30 pm
https://dfiles.eu/files/8lu4e6n6b
Users browsing this forum: Google [Bot] and 2 guests
