executer
Post
by executer » Sat Feb 23, 2013 3:28 pm
I would like to use indirect addressing of SCL block input interface. Inputs are UDT data structures (string and few reals inside).
So, my question is it possible at all?
Another way is to re-declare inputs as TEMP array and copy all of them one-by-one on block start, but it is extra work for PLC.
VAR_INPUT
REACTOR_01 : UDT_STRUCTURE_REACTOR;
REACTOR_02 : UDT_STRUCTURE_REACTOR;
REACTOR_03 : UDT_STRUCTURE_REACTOR;
REACTOR_04 : UDT_STRUCTURE_REACTOR;
END_VAR
VAR_TEMP
REACTOR: ARRAY [1..4] OF UDT_STRUCTURE_REACTOR;
END_VAR
REACTOR[1] := REACTOR_01;
REACTOR[4] := REACTOR_04;
I know how to do it on STL, but here i need to proceed string data, so want to use SCL, witch I less familiar with (
executer
Post
by executer » Sat Feb 23, 2013 3:41 pm
I find out a thread on
https://www.automation.siemens.com/WW/f ... anguage=en and check SCL_WriteAll source from Late member. Am I right that clear solution for me will be following:
VAR_TEMP
REACTOR AT REACTOR_01: ARRAY [1..4] OF UDT_STRUCTURE_REACTOR;
END_VAR
Then I will be able to point input data by using REACTOR array?
---- UPD
No, It is not possible to deaclare temp variable AT input variable
pmmdavid
Post
by pmmdavid » Mon Feb 25, 2013 4:40 am
Here's is my 2 cents if i understand your question...
VAR_INPUT
Reactor : Array [0..31] of STRUCT
a : int ;
b : bool ;
c : word ;
END_STRUCT;
END_VAR
executer
Post
by executer » Tue Feb 26, 2013 5:55 am
Yep, it will works for STEP7, but I using PCS7 САС - so no arrays aloud on block interface (
I try to use AT instruction to represent several STRUCT Inputs as ARRAY, but compiler gave an error, probably because of size of repsesentator is greater than AT variable ((( It could not see that I have a lot of them.
indian
Post
by indian » Thu Mar 14, 2013 8:59 pm
FUNCTION FC99 : VOID // BLK_WR
VAR_TEMP
DATE_TIME : DT ; // date&time of event
E_DATE : DATE ; // date of event
E_TIME : TIME_OF_DAY ; // time of event
SFC_ERROR : INT ; // Current return value
END_VAR
VAR_IN_OUT
S_COUNT : INT ; // pointer (previous entry)
END_VAR
BEGIN
IF S_COUNT > 29 OR S_COUNT < 1 THEN // max count of entry 30
S_COUNT := 1;
END_IF;
// write date&time
SFC_ERROR := READ_CLK(CDT := DATE_TIME);
E_DATE := DT_DATE(DATE_TIME);
E_TIME := DT_TOD(DATE_TIME);
DB4.Status[S_COUNT].EVENT_D := E_DATE;
DB4.Status[S_COUNT].EVENT_T := E_TIME;
// alarm's data
DB4.Status[S_COUNT].E70_B := DB50.DBB70 ; //
..........yours data here........ reading or writing it doesn't matter.....
// inc of pointer
S_COUNT := S_COUNT + 1 ;
END_FUNCTION
my DB4 is area which consist 30 UDT, each UDT comprises all information alarm's stop related. I guess yours goals are similar.
