Roboguide V8.1056 Rev.C
Hello all,
I've downloaded Roboguide V8.1056 Rev.C from the Fanuc FTP server.
The 30 day trial is over and I need to reactivate the software again before I go to their system training.
I've found a solution in another post and tried it but it didn't work.
The post I'm referring to : viewtopic.php?f=3&t=5518&p=42667&hilit=roboguide#p42667
Can anybody help me solve this problem ?
Beside that, if anybody is interested in the software, let me know.
Kind regards,
Erik
Kind regards,
Erik
Re: Roboguide V8.1056 Rev.C
Доброе утро!
Хотелось бы опробовать эту программу перед покупкой.
Пожалуйста, пришли ссылку для скачивания или сам файл.
С уважением из России.
P.S.: Если есть учебное пособие, то это будет просто прекрасно.
Сейчас покупаем робота Fanuc, но без программы roboguide.Eert_NL wrote:Hello all,
Erik
Hello Shuravin,
I´ve send you a PM with a link in it.
Hope this helps.
Erik
Hope this helps.
Erik
It's possible to reactivate Roboguide to new 30 days.
Use the software TRIAL RESET.
Hello sdf37,
Can you explain more ?
Maybe a link to that software ?
Have you tried it yourself ?
Did it work then ?
Kind regards
Did it work then ?
Kind regards
I have used this solution for Roboguid V7 but i have just intalled the V8, so i have not tested trial reset again.
Visit this site: http://fr.scribd.com/doc/16840394/Robog ... -Day-Trial
and download Trial reset at this address:
http://www.filecrop.com/81194268/index.html
Hello all,
After a long search for better options I finally found a way to fix my problem.
It's not the best solution but it works.
Install the software as usual.
Run it for like 30 day’s
If the software reaches it’s time then uninstall the software
1. Use the program “Trial-Reset”. I’ve tested version 4.0 Final.
2. Go to the menu called protection plus
3. Select “Scan generic” from the pull down menu.
4. From the same pull down menu select “Clear”
5. Reboot the computer
6. Reinstall RoboGuide
7. Reboot the computer
Done !
Hope this helps others as well.
If it does, please drop me a pb.
Regards, Erik
Done !
Regards, Erik
Re: Roboguide V8 Ref. E
Hello all,
I just got the latest version from Fanuc.
It has support for several new robots and its called RoboGuide V8 Ref. E
It also has new controller software v8.13 - R-30iB
P.m. me for more information.
Regards Erik
Regards Erik
Would anyone have a download link to the trial version 8.10?
Does it work also for V8?Eert_NL wrote:If the software reaches it’s time then uninstall the software
Regards, Erik
I paste another option pretty similar:
extracted from v6.40 / not checked
This will reset your 30 day trial, after it ends:
Uninstall handlingpro/simpro/related components,
Delete these registry keys:
HKEY_CLASSES_ROOT\CLSID\{10459-d3d485b5-84d3-4f7b-acec-468ca308fdf0}
HKEY_CLASSES_ROOT\CLSID\{14742-df3ae7e1-0132-4a0b-a142-91977fc93e22}
HKEY_CLASSES_ROOT\CLSID\{801c08d1-cd91-486f-a44d-308cf5a69e3b}
HKEY_CLASSES_ROOT\CLSID\{8a05a2f8-6397-4b9a-8498-0d044d7655da}
Delete these files:
C:\WINDOWS\system32\ES2TPCPS.ocx
C:\WINDOWS\system32\INVDPB8V.ocx
Reinstall handlingpro/simpro, it should be good for another 30 days.
The solution as I wrote works with V8 Rev E as well.
I'm not sure about your solution, but off course you can try that too.
It still would be better if anyone could find a real solution for the trial key.
Regards
Regards
Does anyone have the latest of the Roboguide software ?
esta solución funciona. solo hay que aclarar bien los pasos.
1.- ejecutar el trial reset 4 (como administrador)
2.- buscar la opción PROTECTION PLUS
3.- ejecutar SCAN GENERIC
4.- ejecutar CLEAR
5.- desinstalar roboguide
6.- reiniciar pc
7.- instalar roboguide
8.- reiniciar pc
9.- funcionando 30 días mas
saludos
4.- ejecutar CLEAR
6.- reiniciar pc
8.- reiniciar pc
saludos
Eeeeh,
Why this (Spanish?) translation of my post?
Hi guys,
Bellow a medicine for Roboguide revE 8.1079.00.34.
Can be run under virtual machines too.
http://www.filedropper.com/patchroboguidereve810790034
Hi,Eert_NL wrote:Hello all,
Done !
Regards, Erik
thankx a lot. It works!
But the Trial-reset.exe is detected as a virus from my system. I've run it, and then deleted (keeping just the .zip archive for future necessity...)
Is it normal? Have I download an infected version?
Thanks in advance!
Bye
Hi, morecore
can you please upload again the patch.
Hi, can you please reupload the file.morecore wrote:Hi guys,
Did anybody find "patch" for this? Please upload again
Hi guys,
Sorry i've been very busy.
Install Roboguide then replace the original file with this one.
Link http://www.filedropper.com/rgcore
Give credits to the cracker not to me.
A sidenote:
The right version wicth work with the patch posted by morecore on previous post can be downloaded here
http://fabryka-robotow.pl/2014/04/fanuc ... 079-rev-e/
Enjoy!
Enjoy!
By the way, any patch to RoboGuide v8 RevK?
RoboGuide v8 RevE has a known bug regarding ProfiBus configuration.
Anyone that have later version? M? And if any patch works for that version?
Should this post be on request?
Please, could someone upload the patch again? Thanks in advance!!
HI!
Does anyone has the crack for version Roboguide V8.1056 Rev.C ???? I just need it for learning how the software works. I do not need new versions just this one. Thanx
