It is currently Mon Jan 21, 2019 7:29 pm
Post new topic Reply to topic  [ 19 posts ]
PostPosted: Sat Jun 23, 2007 10:05 am
Before I have Xtal software to unprotect PLC omron but my PC broken and I lost this software,
Who have this soft can post for me? thank you very much!
 Post subject:
PostPosted: Sun Jun 24, 2007 5:46 pm
et voila
http://rapidshare.com/files/39079741/Au ... locker.rar
most
 Post subject:
PostPosted: Thu Nov 15, 2007 8:12 pm
in Russian forum wrote:
Можно без проблем снять пароль в контроллерах CS1, CJ1 до версии 2.0 в вериях от 2.0 и выше, как повезёт, зависит от того, с какими опциями установили пароль на программу. описание на http://cpu13.ru/forum/viewtopic.php?t=4
you can view passwords in "*.OBJ"
 Post subject: Find OBJ file
PostPosted: Mon Jun 30, 2008 5:40 am
chongky wrote:
what is *.obj file ?
where does it located ?
You can find the *.OBJ file in CF card after u back up PLC program. So, You must back up the PLC program first using CF card and you will find the obj file in there and you open it using Ultraedit or Winhex.
 Post subject: PLC write protected
PostPosted: Tue Jul 08, 2008 12:18 pm
I have a CJ1 cpu that is protected. It is Overwrite protected, and It is prohibited from saving into a memory card.
1- How can I unlock it?
or at least how can clean it over write protection? so it be programmable again?
 Post subject:
PostPosted: Tue Jul 08, 2008 4:03 pm
Create the program without the Password
To keep on a memory card of as a file AUTOEXEC.OBJ and AUTOEXEC.STD
Push ON and to load the controller from a memory card
The old program will be erased
in Russian wrote:
элементарно, сделать программу без пароля,
сохранить на карту как AUTOEXEC.OBJ и файл настроек AUTOEXEC.STD
и загрузить контроллер с карты при включении питания.
Старая программа в контроллере будет потеряна.
 Post subject: Unlock Protected CJ1
PostPosted: Sat Jul 12, 2008 5:24 pm
If i have one CPU CJ1M with password protected and protected copy to memory card.
Is possible to upload program from that PLC??
OR any idea to unlock the password protected??
 Post subject: Unlock password
PostPosted: Wed Jul 23, 2008 4:32 pm
The software can unlock password CJ series??
 Post subject:
PostPosted: Sun Aug 03, 2008 6:29 pm
huyviet,
I download the file already, but there is no .exe file, so how to use it ?
 Post subject:
PostPosted: Mon Aug 04, 2008 2:32 pm
This is source code spain version. I have compiled and have translated on English, but did not check.
http://rapidshare.com/files/134743934/Password_eng.exe
Write about results.
Good luck!
 Post subject:
PostPosted: Tue Aug 05, 2008 7:21 am
I tested .
C200H , CPM1 , CPM1A , CPM2 , CPM2A , CQM1 : OK
CQM1H-CPU21(51-61) : Not found
 Post subject: CQM1-H
PostPosted: Tue Aug 05, 2008 8:39 am
CQM1-H blocks search of a code. To open the password it is impossible.
 Post subject: Omron CJ1
PostPosted: Tue Nov 25, 2008 5:59 pm
Hi to all...
I try the program XTAL (version 1.00.0005) for my PLC Omron CJ1 but the program don't work (finish the scan to FFFF and write KEY NOT FOUND...). :(
Some know why? Or other program that work with this PLC???
Please, please, please... help me... :cry:
Very thanks...
:P
PostPosted: Fri Jan 18, 2013 6:13 pm
try Password (eng) - для CQM1 URL: http://z-forever.com/w/doku.php/soft:omron:password_unlock:list
PostPosted: Wed Apr 10, 2013 6:09 pm
hi zender
the link you send is not working please upload again (wow)
 Post subject: Re:
PostPosted: Mon Jul 21, 2014 2:32 pm
please hepl me upload plc omron CPM1A
I have a question for everyone
i hepl everyone help me
i have a types plc omron CPM1A and CPM2A, i when upload programs data all in plc but me upload being error
i have a question for your help, i have found errors when i upload plc omron CPM1A and CPM2A but programs plc being unlock password . those errors are shown that i send attach image.
could you help
please. for me a software to fix opening password plc omron.
what is software opening password plc omron CPM1a and CPM2A?
please. can you give me a link ? I to fix open password plc omron
thank you so much for your time and consideration.
https://goo.gl/MymW6Q
 Post subject: Re: Re:
PostPosted: Tue Jul 22, 2014 11:36 am
could you help
Go to this site and you will find what you need
http://www.plcjiemi.com/
PostPosted: Tue Jul 22, 2014 11:38 am
could you help
http://www.plcjiemi.com/ or http://www.ymmfa.com/thread-gkfid-37.html
Good Luck
PostPosted: Sat Aug 02, 2014 7:32 pm
could you help
Good Luck
thank you very much
dear everybody
please you help me
I when unlock pass plc onrom CPM1A by software XTAL
but I unlock password plc omron CPM1A being errors, i have sent image attach.
there are some steps that , I have made/ done below;
the first time I connect cable RS232 go to PC with plc, after I opening software CX one 9.0
I'm online with plc but plc, has lock password so I can't upload
after I opening software unlock password plc onrom CPM1A by software Xtal but I when unlock password this time software Xtal being errors
i don't know, what is this errors ?
how can I modify error '8005' ?
what is this error run-time error '8005': ?
https://www.youtube.com/watch?v=v4J4SAZGMNA
