[LINK]: Drive Window for ABB
привода и частотники
Prods
Post by Prods » Thu Jul 17, 2008 10:58 am
Hi, I am looking for the program Drive window for parametrization of ABB drives. Any help :) ???
Link
Post by Link » Fri Jul 18, 2008 1:34 pm
DriveWindow v2.2
I never tested this program and I do not know if it is necessary lic
57030 KB
http://rapidshare.com/files/130639872/ABB_DriveWindow_v2.2.rar
Link
Post by Link » Wed Jul 23, 2008 6:58 pm
And what about drive window light 2
maybe this one:
http://rapidshare.com/files/131916688/DriveWindowLight.rar
never used it but the readme shows 2003 as release date...
Please, is there anybody here that knows the pinout for the DB9->RJ45 cable ???
Prods
Thx
Post by Prods » Thu Jul 24, 2008 9:54 am
Thank you rack123.
This is what I need it :)
Link
Post by Link » Sat Sep 20, 2008 9:45 am
I found the cable and draw the pinout:
http://rapidshare.com/files/146811604/abb_rj_2_db9.rar
Tested on ACH550 with drivewindow 2.6, works fine!
Link
Post by Link » Thu Sep 25, 2008 5:26 pm
I don't remeber where saved the original link, so I've compressed the setup folder and reupped here:
DriveWindow 2.6
http://rapishare.com/files/148332125/DWL26.rar
http://www.megaupload.com/?d=YTISOI3D
about 20Mb (85Mb uncompressed).
No password, please remove all the "*" for the correct links ( I don't like the web spiders).
If the setup not works correctly from a hd folder try to burn a cdrom with all the files/folders that are in rar.
pb123
Acs800
Post by pb123 » Fri Dec 05, 2008 6:19 pm
Does any one have a pinout for the ABB ACS800 rj12 to DB9
PLC_ITA
which software far ACS800
Post by PLC_ITA » Fri Jan 09, 2009 3:18 pm
I have tryed DWL 2.6 but a ASC800 is'nt recognized. Max ACS550 is supported.
Anyone can help me ?
Umencho
Post by Umencho » Sat Jan 10, 2009 3:52 am
Did you try with DriveWindow v2.2? From most's link. Works without lic. I use this for ASC600 and ASC800. Connection by PCMCI card (NDPA-02 DDCS/PC card adapter) + NDPC-12 card cable (10Mb optical transmitter/receiver) + FO cable.
reagrds
kevin0175
Re: which software far ACS800
Post by kevin0175 » Thu Feb 05, 2009 3:30 am
PLC_ITA wrote:I have tryed DWL 2.6 but a ASC800 is'nt recognized. Max ACS550 is supported.
DriveWindow Light 2.7
DriveWindow Light is a commissioning and maintaining tool
for ACS140, ACS160, ACS350, ACS400, ACH400, ACS550,
ACH550 DCS400 and DCS800 drives. Also following ASC600 and ACS800
applications are supported: standard, spinning control and
pump control. DriveWindow Light is designed to run under the
Microsoft Windows NT4.0 (SP6), Windows 2000, Windows XP or
Windows Vista operating systems on IBM -compatible PCs.
arfineira
Post by arfineira » Fri Jul 10, 2009 8:01 pm
Does any one have a pinout for the ABB ACS800 rj12 to DB9 ?
Is possible to configure any serial port COM to communicate with ACS800 ?
ntban
Re:
Post by ntban » Tue Nov 10, 2009 4:16 am
the link of DWL26 on Rapidshare is broken !
Please, Re-Upload again ?
stojakovicv
Re: [LINK]: Drive Window for ABB
Post by stojakovicv » Thu Feb 11, 2010 7:35 am
I have ACS-CP-A control panel, but it is not working http://www.abb.com/product/us/9AAC113396.aspx
I have found in user manual that I need some OPCA-02 adapter cable for this drive.
Is this correct cable: http://rapidshare.com/files/146811604/abb_rj_2_db9.rar ?
So I downloaded Drivewindow Light. Is it possible to connect to drive over 8-pin RJ45 connector.
Does anyone have cable pinout for ACS350 drive?
brave_eagle
Post by brave_eagle » Thu Feb 11, 2010 7:39 am
The DWL 2.92 had already released
pconline
Post by pconline » Sun Feb 21, 2010 7:34 pm
Can someone uplad 2.7?
Because 2.92 is upgrade for Drivewindow light 2.7
pconline
Post by pconline » Mon Mar 08, 2010 10:33 am
I found DWL 2.8 You can download it from http://rapidshare.com/files/360563073/dwl_2.8.rar
You can use service pack to upgrade to 2.93. It's downloadable from ABB
Regards.
azamo12
Post by azamo12 » Sun Sep 12, 2010 10:01 pm
hi any one can upload DriveWindow 2.30
Artem
Post by Artem » Wed Oct 05, 2011 7:13 pm
I have DWL 2.92. Can I communication with ACS-800 this program. I have DB9->RJ45 cable ABB?
Linkinx64
Post by Linkinx64 » Thu Oct 06, 2011 6:35 am
Artem wrote:I have DWL 2.92. Can I communication with ACS-800 this program. I have DB9->RJ45 cable ABB?
You need NPCU-1 adapter and cable for RS485. Then you can. But only for reading/writing parameters of standard software and basic control (start/stop/fwd/rev), due to link speed via RS232 is too slow.
Can anyone upload DriveWindow 2.3 here?
Sleepwalker
Post by Sleepwalker » Tue Dec 27, 2011 2:03 pm
Hello all
How to activate "Loading packages" in DriveWindow?
I have checked in help file info is that "special license..." need "...to be entered into DriveWindow".
Where can I find this license and how to enter it?
rosco87
Post by rosco87 » Mon Jan 07, 2013 11:14 pm
illarra
Post by illarra » Wed Jan 16, 2013 8:36 pm
I found how to make the RJ45 to DB9 cable. Is the comunication faster using this cable than using the RS232?
Linkinx64
Post by Linkinx64 » Thu Jan 17, 2013 9:25 am
1. http://www.4shared.com/rar/CpRDWGM7/dri ... t_293.html
2. The same. The difference is only in connector type.
illarra
Post by illarra » Thu Jan 17, 2013 4:10 pm
esantoshex
Post by esantoshex » Wed Mar 06, 2013 7:08 pm
Linkinx64,
Please... Can you upload again the DriveWindow 2.2 or 2.3 on another server? Rapidshare is broken (exceed daily limit)....
Thanks a lot!
Best regards,
Edsan
Linkinx64
Post by Linkinx64 » Sun Mar 10, 2013 5:01 pm
http://www.filefactory.com/file/ooit37b ... _v2.30.zip
Inform when you're done with the download - I will delete it.
Rkha Skha
Post by Rkha Skha » Mon Jul 01, 2013 6:49 pm
rosco87 wrote:DriveWindow light
2.7 here :
http://rapidshare.com/files/2000229200/DWL2.7.RAR
Thanks for this buddy :-)
Just looking for this link...
PaulMall
Post by PaulMall » Thu Aug 29, 2013 8:28 am
Linkinx64 wrote:http://www.filefactory.com/file/ooit37b ... _v2.30.zip
Mr. Linkinx64,
Could you please repost?
Paul Mall
MaxS
Post by MaxS » Tue Sep 23, 2014 8:52 am
Someone has DriveWindow Light v2.94?
I have DWL v2.93 and such problem:
Error Message
Error occurred while uploading parameters. Check the connection and try again.
Cause
The connected drive’s application software is not supported by DWL.
Frequency converter ACS550 firmware (parameter 3301) = 313dh
Test Date (parameter 3303) = 11.27
DWL v2.93 release date 2010
On the ABB site not files for upgrade. If I right understand software for all FC released after 2010 can buy only. :(
MaxS
Post by MaxS » Fri Nov 07, 2014 3:05 am
I alread have a fault like this before...
I'm solved after update the parameters file of the ACS350/550.
Download link:
http://library.abb.com/global/scot/scot ... 0c003a0305
(thnx)
This update for DWL 2.63 (2007-07-02). I have DWL 2.93 and my files of parameters is newer (2009-2010).
Ramomkosta
Post by Ramomkosta » Fri Jan 09, 2015 12:42 pm
This update for DWL 2.63 (2007-07-02). I have DWL 2.93 and my files of parameters is newer (2009-2010).[/quote]
Yes its true,but someday this fault occur to me,and my DWL is 2.93 to...
But I try to change this library in that link,and after that its works...
"In electronics is proven that there is not an exact science.
If we do not try we will never know if it works."
Ramomkosta
jovancha
Post by jovancha » Sat Feb 21, 2015 6:29 pm
Hi, can someone upload ABB drivewindow? Links here are dead.
Thank you.
Petrozawodsk
Post by Petrozawodsk » Thu Feb 26, 2015 10:52 am
MaxS
Post by MaxS » Thu Nov 05, 2015 6:41 am
DriveWindow Light 2.93:
http://my-files.ru/opx7zh.DriveWindow%2 ... 202.93.rar
Cable pinout:
http://my-files.ru/1vy4ce.OPCA-02.rar
Anybody have DWL 2.94?
On the ABB site available update from DWL 2.94 to 2.95:
http://search-ext.abb.com/library/Downl ... ion=Launch
MaxS
Post by MaxS » Fri Nov 06, 2015 6:46 am
Old links (in before message) is not good.
Cable pinout:
MaxS
Post by MaxS » Fri Nov 06, 2015 6:52 am
If somebody have DWL 2.94, give link please. (sos)
ufuk82
Post by ufuk82 » Thu May 19, 2016 5:59 pm
eggman14
Post by eggman14 » Fri Nov 04, 2016 8:05 am
Hi all,
i have drive windows light 2.3 and also 2.93.
Can anyone upload links to all the versions again in between
ie 2.4 2.5 2.6 2.7 2.8
and the cable pinout as all the rapidshare links etc are broken.
Lemajd
Post by Lemajd » Sun Nov 20, 2016 9:56 am
Hi All,
Any update or good link to be shared about ACS drivers software?
Regards
eggman14
Post by eggman14 » Fri Jun 01, 2018 7:52 pm
Lemajd wrote:Hi All,
Regards
I have them working up to 2.93. I have the 2.94 to 2.95 updater but not the version 2.94
I haven't shared for a while but can provide dropbox. let me know if required
jbomson
Post by jbomson » Wed Dec 05, 2018 3:06 pm
need dwl 2.94 pl.help
vlad2006gr
Post by vlad2006gr » Sat Dec 08, 2018 8:22 pm
eggman14 wrote:I have them working up to 2.93. I have the 2.94 to 2.95 updater but not the version 2.94
Create a reg file with such content and run it.
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\DWL2.exe]
@="C:\\Program Files (x86)\\ABB\\DriveWindow Light\\DWL2.exe"
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\DriveWindow Light]
"DisplayVersion"="2.94"
Download and install update from DWL 2.94 to 2.95
Reg file for Windows 7. For Win XP, you need to edit a little. I think you figure it out.
jbomson
Post by jbomson » Sat Dec 15, 2018 4:34 pm
After adding registry (windows 10), i am able to install dwl 2.95 through file upgrade 2.94 to 2.95.
https://search-ext.abb.com/library/Down ... ion=Launch
boont
Post by boont » Wed Jan 30, 2019 8:56 am
Please post a link to download DriveWindow 2.4 or 2.3! Really needed. I can not find anywhere.
vlad2006gr
Post by vlad2006gr » Tue Feb 12, 2019 7:58 am
boont wrote:Please post a link to download DriveWindow 2.4 or 2.3! Really needed. I can not find anywhere.
Good luck!
