[?]: Testing TIA Portal v11/v12 (We all beta-testers :)
Homeroid_BL
Post by Homeroid_BL » Thu May 19, 2011 4:41 pm
:) We can see no problem except that at this point TIA v11 is useless.
Does not support DP and MPI (only Teleservice and Profinet)
Using applications created in v10.5 is not possible if libraries were included.
TIA v11 can not 'remember' language setting as it was case in v10.5
No support of GSM comm board as written in manual.
You can not migrate (any, I think) Step7 V5.x project into Step/ v11 - it terminates with error.
When you instert a function, all default parameters are set to 0 even if 0 is ilegal value.
And many more... :( (boom) (ev) (h)
kphcm
Re: [Link]: STEP 7 Prof/Basic V11(TIA Portal) [Torrent & Rap
Post by kphcm » Fri May 20, 2011 5:44 am
I Install 1 keys from 14/05/2011 in item "Installed key"(Step 7 Professional combo single Trial 21 days SITTS7PROF1100). It become Step 7 Professional Edition V11 Floating Unlimited SIFLS7PROF1100) - it work good
kphcm
tristande
Re: [Link]: TIA Portal V11: Step7 + Flex + WinCC v11
Post by tristande » Sat May 21, 2011 10:53 am
I just finished installing TIA Portal v11 on a fresh new virtual machine.
After the .net framework updates, it took me 28 minutes to install it, with one reboot at the end.
( Win XP Pro SP3, HP Elitebook, T9600, 1Gb ram in virtual machine )
On Xp Pro you can only install WinCC Basic, as mentioned above. Also, i did not install the guided tour.
Funny thing is that i didnt have to install any keys or use EKB. TIA Portal v11 just starts without any problem.
I've used the rapidshare links in the second post.
Thanks for sharing this!
Great forum & support here :)
EDIT: When i tried to add a new device, i asked for a "Step 7 combo" key. Then i chose to activate the trial.
I could not find the key for this in EKB 2011_05_20 nor in 2011_03_20. Anyone has a solution for this?
Post by CoMod » Sat May 21, 2011 11:20 am
tristande wrote:When i tried to add a new device, i asked for a "Step 7 combo" key. Then i chose to activate the trial.
Try to remove Trial keys http://support.automation.siemens.com/W ... n/24200966
but wait new version 2011_05_21, 22 ...
tristande
Post by tristande » Sat May 21, 2011 12:32 pm
Thanks again for your help CoMod.
I succesfully removed the trial license and installed the combo key from the EKB installer.
Could you tell me why its better to wait for a new release of EKB installer?
Does it include the WinCC Pro keys?
Post by CoMod » Sat May 21, 2011 1:58 pm
tristande wrote:
CoMod wrote:
tristande wrote:Could you tell me why its better to wait for a new release of EKB installer?
1304 ?
1305 ?
Sorry, i dont understand you. What do you mean with 1304 /1305?
N
No torrent link at ruttracker for the WinCC Professional V11?
Today Rapidshare
Tommorow Torrents... (oo) and wait
and install new Windows
for WinCC v11 need cleared system
flopez
Error during migration
Post by flopez » Sat May 21, 2011 8:50 pm
Problem with migrating a project Step7 v5.4 or v5.5.
appears the following errors
Migration wrote:Migration date: 5/21/2011Type Message Time
Migration log 8:39:55 PM
Station: SIMATIC 300 8:39:56 PM
Hardware configuration 8:39:56 PM
Central 8:39:58 PM
Cannot migrate module FM350 COUNTER (6ES7 350-1AH01-0AE0) in rack 0, slot 10. 8:39:58 PM
Cannot migrate module CPU 315-2 DP (6ES7 315-2AF03-0AB0 V1.2) in rack 0, slot 2. 8:39:58 PM
Cannot migrate module DI16xDC24V (6ES7 321-1BH01-0AA0) in rack 2, slot 7. 8:39:58 PM
General 8:39:58 PM
Error during migration. 8:39:58 PM
Any solutions in sight?
flopez
centipede
Re: [?]: Testing TIA Portal v11 (We all beta-testers :)
Post by centipede » Sat May 21, 2011 9:01 pm
Pls check this List:
http://support.automation.siemens.com/W ... n/50029533
https://support.automation.siemens.com/ ... W_List.pdf
for example: Your CPU have the wrong Firmware, you need 6ES7 315-2AH14-0AB0 v2.6 or above.
flopez
Post by flopez » Sat May 21, 2011 11:08 pm
centipede wrote:Pls check this List:
Thanks for the info
Have I checked and I see no solution, because I have about a hundred projects.
I will not do the updates all CPU's, and other modules.
I am saddened by this new Step7 V11
End my opinion is not compatible with Step7 V5.5
additional testing I've done by changing the cpu, after the migration appears dozens of errors.
Migration
Migration log 11:30:42 PM
Station: SIMATIC 300 11:30:43 PM
Hardware configuration 11:30:43 PM
PLC program 11:30:43 PM
Objects to be migrated 11:30:43 PM
Organization blocks: 3 11:30:44 PM
Function blocks: 6 11:30:44 PM
Data blocks: 55 11:30:44 PM
Functions: 28 11:30:44 PM
Data types: 1 11:30:44 PM
Tags: 1661 11:30:44 PM
FB2: The interface of DB70, DB71, DB72, DB73, DB74, DB75 is out of date. 11:30:43 PM
FC6: The interface of DB10 is out of date. 11:30:43 PM
FC1: The interface of DB10 is out of date. 11:30:43 PM
FC19: The interface of DB70, DB71, DB72, DB73, DB74, DB75 is out of date. 11:30:43 PM
FC23: The interface of DB70, DB71, DB72, DB73, DB74, DB75 is out of date. 11:30:43 PM
FC50: The interface of DB70, DB71, DB72, DB73, DB74, DB75 is out of date. 11:30:43 PM
FC51: The interface of DB70, DB71, DB72, DB73, DB74, DB75 is out of date. 11:30:43 PM
FC52: The interface of DB70, DB71, DB72, DB73, DB74, DB75 is out of date. 11:30:43 PM
FC70: The interface of DB80 is out of date. 11:30:43 PM
FC80: The interface of DB80 is out of date. 11:30:43 PM
OB1: The interface of DB70, DB71, DB72, DB73, DB74, DB75 is out of date. 11:30:43 PM
OB100: The interface of DB10 is out of date. 11:30:43 PM
The classic project is not consistent. "Programma S7" needs to be recompiled. 11:30:43 PM
FC1: The data type DB18, DB20, DB22, DB24, DB26, DB28 is unknown. 11:30:43 PM
CPU 315-2 DP\FB41: The corresponding SCL source is missing. 11:30:45 PM
CPU 315-2 DP\FB101:The label name "'ok'" is not unique. Label renamed to "'okä'". 11:30:45 PM
CPU 315-2 DP\FC101:The label name "'ok'" is not unique. Label renamed to "'okä'". 11:30:50 PM
General 11:30:43 PM
Error during migration. 11:30:50 PM
This only changed the hardware virtually
flopez
Post by CoMod » Tue May 24, 2011 4:28 am
tristande wrote:If i install WinCC Pro v11 and i have already TIA portal v11,
will WinCC be integrated into TIA Portal?
WinCC Pro v11 = WinCC + WinCC Flexible
(Select in Setup)
TIA Portal WinCC Professional v11 setup
I tested Runtime with this keyset
SIFLS7PROF1100.ekb
SIFLWCAURT9999.ekb
SIFLWCCLPR1100.EKB
SIFLWCLORT9999.ekb
SIFLWCRCRT9999.ekb
SIFLWCSRPR9999.EKB
SIFLWCSSRA9999.ekb
* SIFLWCPRC51100.EKB
* SIFLWCPRO41100.EKB
* SIFLWCRP041100.EKB
* SIFLWCRPC41100.EKB
* SIFLWCRT061100.ekb
* SIFCYWCPLG99991.EKB
See LOGs files C:\Program Files\SIEMENS\Automation\SCADA-RT_V11\WinCC\diagnose
License.Log when ALL is Ok
05/23/2011 11:23:53 InitLicense RT | AppName = AppRT:Mcp | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLWCRP041100 | Text of License = WinCC RT Professional (4096) | Relevant Limit = 0000004096 |
05/23/2011 11:23:53 InitLicense RT | AppName = AppRT:TlgASO | CycleCheck = yes | NameForMessageBox = | Name of License = SIFCYWCPLG99991 | Text of License = WinCC Logging RT Professional (1500) | Relevant Limit = 0000002000 |
05/23/2011 11:35:18 ExitLicense RT | AppName = AppRT:Mcp | CycleCheck = yes | Name of License = SIFLWCRP041100 | Text of License = WinCC RT Professional (4096) |
05/23/2011 11:35:18 ExitLicense RT | AppName = AppRT:TlgASO | CycleCheck = yes | Name of License = SIFCYWCPLG99991 | Text of License = WinCC Logging RT Professional (1500) |
* Install only 1 multitag key
TIA Portal WinCC Professional v11 Error message when installed more 1 key SIFCYWCPLG9999* with one serial number
In some case installation is broken - reinstall WinCC with Repair option
Russian wrote:В некоторых случаях установка нарушается - переустановить WinCC с ремонтом вариант Repair
*Не должно быть однотипных ключей - выбирайте только один на достаточное число тэгов.
В случае проблем смотрите (шлите) отчёты C:\Program Files\SIEMENS\Automation\SCADA-RT_V11\WinCC\diagnose
Always need to install ENGLISH language !
alafandy
Post by alafandy » Tue May 24, 2011 6:17 am
Problem with Install WinCC v11
look this pic
im install SQL server 2005 sp3 in my pc...
and this problem always appear ??!
my OS is windows7 sp1
sanruku
Post by sanruku » Tue May 24, 2011 6:46 am
alafandy wrote: im install SQL server 2005 sp3 in my pc...
Did you read the readme file?
You have to backup your SQL 2008 Databases, uninstall SQL Server 2008, install SQL 2005, reinstall SQL 2008, restore your Databases.
Good luck
alafandy
Post by alafandy » Tue May 24, 2011 11:15 pm
Good luck
thnx sanruku,..
yes, i did it with file (Readme)
and uninstall my SQL Server 2008, the install SQL server 2005 from DVD winCC11,..and get same Problem
then i install SQL server 2005 SP3 in my PC and get same problem too ??!!
maybe WinCC v11.0 not working with Win7 SP1
any idea ?!
sanruku
Post by sanruku » Wed May 25, 2011 7:11 am
alafandy wrote: and uninstall my SQL Server 2008, the install SQL server 2005 from DVD winCC11,..and get same Problem
any idea ?!
Remove all SQL Servers from your system. Then let Portal install the SQL 2005.
What happens then?
Are you running 64bit or 32bit Win7 SP1? Portal is incompatible with 64bit OS.
alafandy
Post by alafandy » Wed May 25, 2011 2:12 pm
What happens then?
my PC with single CPU and running win7 sp1 (32bit)
RAM ( just 1GB) :lol:
and
Now i fix my Porblem with making some ON feautures in windows7
look in this pic
and sloved this porblem with install WinCC v11.0
look my install here:
and now working perfect,..
Thank YOU ,sanruku .
with Greetings
acid12
Post by acid12 » Sat May 28, 2011 6:11 pm
anyone know what about FM 355 in new Step7 v11.
FM355 is a closed loop control module,
in previous versions of step7 one should download additional package from siemens website.
The newest version is 6.11 link.
During instalation in Step7 v11 it displays info that step7 not installed, need step7 v5.3 or newer :)
I suppose I should just wait, but maybe someone has an idea ? :)
Post by CoMod » Sat May 28, 2011 7:24 pm
acid12 wrote:anyone know what about FM 355 in new Step7 v11.
See https://support.automation.siemens.com/ ... W_List.pdf
ivan_euler
Post by ivan_euler » Fri Jun 10, 2011 8:53 am
:?: hello mod
Im installing TIA V11 in windows XP profesional SP3 and i succesfully installed step 7 v 11 but when installing wincc v11 only the basic had been installed...i already checked all the prerequisite...
Im i missing something...??????? i hadthe latest ekb ....
im confused .... (fback)
Post by CoMod » Fri Jun 10, 2011 9:50 am
tak2750 wrote:i want to install pcs7 7 sp2.
can i install step7 v11 and wincc v11 separatly and use pcs7 v7 sp2?
Russian wrote:Я хочу установить pcs7 7 sp2
Могу ли я установить step7 v11 и wincc v11 и использовать pcs7 v7 sp2?
At present it is not recommended to use this beta version of TIA on production systems.
You can use the TIA is at your own risk, for training purposes.
Russian wrote:В настоящее время не рекомендуется использовать данную бета-версию ТИА на рабочих системах.
Вы можете использовать ТИА только на свой страх и риск в целях обучения.
wait SP1 and SP2
=== Bugs =======
http://support.automation.siemens.com/W ... n/50204569
Russian wrote:Установил wincc v11, но получил только Флекс, почему не установился ВыньКЦ ?
If the installation of TIA V11.0 is defective or damaged by an event, you have the option of repairing the TIA V11 software
Start Install anew and select Repair option
Russian wrote:Если установка закончилась, но на последнем экране выскочило сообщение об ошибке установки, то переустановите Портал в режиме Repair Ремонт
zeytin
Migration is working Correctly?
Post by zeytin » Mon Jun 20, 2011 10:18 am
I am trying migration an empty project that has only cpu315 2eh13 and empty ob1 in step7 prof edition 2010
But TIAportal migration freeze not working no message
I am trying another way
I can copy the C:\Program Files\Siemens\Automation\Portal V11\Mig directory the other notebook that have only step7prof 2010
it is same problem
migration waiting waiting waiting waiting more than 40 minutes
but no message no fault
you can press cancel button process is stop
How can I migrate old project to TIAPortal
I can not migrate empty project (clap)
Umencho
Post by Umencho » Mon Jun 20, 2011 11:27 am
Hope the version of cpu315 2eh13 is 2.6.
Did you try with other hardware http://support.automation.siemens.com/W ... n/50029532 ?
If the behaviour is the same perhaps reinstall of software might helps.
zeytin
Post by zeytin » Tue Jun 21, 2011 8:17 am
I am trying migrate with "excule hardware" tick
but it is not possible same situation
I install the software again complately english version win7 ultimate
I install update1
I can not solve this migration problem
theedoek
Post by theedoek » Fri Jun 24, 2011 8:49 am
Prior to this release of the V11 software Siemens already announced that the software would not be bug-free and that several functions like the project migrator would not be operational at the time of release.
So simply said, stop wasting your time time trying to get the migrator working.
Umencho
Post by Umencho » Mon Jul 11, 2011 9:55 am
Demo projects for HMI Panels at TIA Portal V11/ WinCC 11 (Basic
Panels, Comfort Panels and WinCC Runtime Advanced)
http://support.automation.siemens.com/W ... n/50599077
Info
Post by Info » Tue Jul 19, 2011 11:16 am
TIA Portal & 6ES7 331-7RD00-0AB0
Adress bugs with 4AI
======= Problem with German regional settings =============
I have create new project with TIA v11 UPD 2. Added HMI KTP400 or KTP600.
And when i'm trying to safe it, it crashes..
Problem was solved with regional settings.
I have changed region to English (United States) and after that craches gone.
So if somebody has problem with HMI craches, change your regional to English (United States)
P.S i did not test with German regional.
thevinhtbc
Post by thevinhtbc » Fri Jul 22, 2011 10:45 am
Hi all!
i have a quesion.i installed ok ,i can download program but i can`t upload program.
who can help me?
Umencho
Post by Umencho » Fri Jul 22, 2011 10:51 am
Did you receive any error? How did you realize that is not possible to make upload?
saravanan_tsvk
Post by saravanan_tsvk » Wed Jul 27, 2011 4:59 am
I have not started using the TIA 11.
But when I opened, it was a big surprise that the overall look of the software changed.
I have noted one more thing that the logic blocks such as OB's, FB's and FC's are also changed.
Because of that, we can use the shortcut keys and the introductions also placed in different location not like normal simatic manager.
zer1988
Post by zer1988 » Sat Jul 30, 2011 2:13 am
hi everybody,
How to install more kinds of CPU into tia portal v11. In last version, I often used 'Install GSD file'. However, it seem that do not effect in this version. Please, help me.
Link
Post by Link » Mon Aug 01, 2011 2:40 pm
Panels, Comfort Panels and WinCC Runtime Advanced) (2011-07-25)
=> http://support.automation.siemens.com/W ... n/50599077
Homeroid_BL
Post by Homeroid_BL » Mon Aug 01, 2011 9:26 pm
Anyone noticed that blocks with know-how protection ARE PRINTED REGULARY? :D :D :D
van8x10
Re: [?]: Testing TIA Portal v11 SP1 (We all beta-testers :)
Post by van8x10 » Fri Aug 12, 2011 5:11 pm
I have a STL section as below (is OK in Step 7 V5.5):
below
      L     #TEMP9
      L     1
      >I
      JCN   M003
      L     9
      T     #TEMP8
      T     #TEMP12
M003: NOP   0
      L     #TEMP8
      T     #TEMP13  // Data Type: Byte; Offset 16.0
      A     L     16.0   //Bit 0 of #TEMP13
      =     Q [AR1,P#0.0]
      A     L     16.1   //Bit 1 of #TEMP13
      =     Q [AR1,P#0.1]
      A     L     16.2   //Bit 3 of #TEMP13
      =     Q [AR1,P#0.2]
      A     L     16.3
      =     Q [AR1,P#0.3]
After Migrating:
After Migrating
    L     #TEMP9
      L     1
      >I
      JCN   M003
      L     9
      T     #TEMP8
      T     #TEMP12
M003: NOP 0
      L     #TEMP8
      A     %L16.0               //Bit 0 of #TEMP13
      = Q [ AR1 , P#0.0 ]
      A     %L16.1               //Bit 1 of #TEMP13
      = Q [ AR1 , P#0.1 ]
      A     %L16.2               //Bit 2 of #TEMP13
      = Q [ AR1 , P#0.2 ]
      A     %L16.3               //Bit 3 of #TEMP13
      = Q [ AR1 , P#0.3 ]
Compile warning:
Access to %L16.0 with ambiguos address
Access to %L16.1 with ambiguos address
Access to %L16. with ambiguos address
Please help to resolve the trouble above!
SHKODRAN
Post by SHKODRAN » Sun Aug 21, 2011 4:48 pm
I don't have TIA installed, but I suggest you try something like:
      L     #TEMP9
      L     1
      >I
      JCN   M003
      L     9
      T     #TEMP8
      T     #TEMP12
M003: NOP 0
      L     #TEMP8
      LAR1
      A     [AR1,p#16.0]              //Bit 0 of #TEMP13
      = Q  [ AR1 , P#0.0 ]
      A     [AR1,p#16.1]             //Bit 1 of #TEMP13
      = Q  [ AR1 , P#0.1 ]
      A     [AR1,p#16.2]             //Bit 2 of #TEMP13
      = Q  [ AR1 , P#0.2 ]
      A     [AR1,p#16.4]               //Bit 3 of #TEMP13
      = Q  [ AR1 , P#0.3 ]
I repeat, do not know yet the structure of the TIA.
van8x10
Post by van8x10 » Tue Aug 23, 2011 7:10 am
Thank SHKODRAN for your suggestion. I think this is one of bugs of TIA V11. It doesn't recognize local variable in the function!
Here is my way to fix the problem: (although uncomfortable)
      L     #TEMP9
      L     1
      >I
      JCN   M003
      L     9
      T     #TEMP8
      T     #TEMP12
M003: NOP 0
      L     #TEMP8
      T MB200;       Not use     #TEMP13
      A    M200.0
      = Q  [ AR1 , P#0.0 ]
      A    M200.1
      = Q  [ AR1 , P#0.1 ]
      A    M200.2
      = Q  [ AR1 , P#0.2 ]
      A     M200.3
      = Q  [ AR1 , P#0.3 ]
van8x10
Post by van8x10 » Tue Aug 23, 2011 3:54 pm
Someone pls could help post my problem on Siemens Automation Forum ( https://www.automation.siemens.com/WW/f ... anguage=en). I forgot and could not give back my password for the forum!
Post by sania » Tue Aug 23, 2011 4:33 pm
in properties of your FC you need change "symbolic access only" to "absolute & symbolic access"
van8x10
Post by van8x10 » Wed Aug 24, 2011 3:48 pm
sania wrote:in properties of your FC you need change "symbolic access only" to "absolute & symbolic access"
Thank Sania, but your advice is of no effect.
BTW, one more bug after migrating a S7-300 project is that you must change addresses for analog modules. For example, PQW272 --> QW272
van8x10
Post by van8x10 » Wed Aug 24, 2011 5:08 pm
Ok, continue to be a reluctant beta-tester for TIA Portal V11.
In a function (FC, FB), declaration "Output" of actual parameter does not match the declaration "Input" of formal parameter. For example, there is a warning if you write:
L #OUT5
to be continued...
Rex2701
Post by Rex2701 » Tue Sep 06, 2011 8:18 am
Got the same problem as described above.
Moreover, I can't delete any row in customly defined PLC Data Types (former UDT) and any misplaced object in WinCC screen.
It looks like a "Del" button or menu item didn't works at all!
Installed s/w: TIA Portal v11 +SP1 +Upd1
Update
Post by Update » Wed Sep 14, 2011 2:26 pm
Update 2 for TIA Portal 11 SP1
http://support.automation.siemens.com/W ... n/52258326
Update 2:
STEP 7: Usage of tags (DTL) with HMI
STEP 7: Detail-comparison of blocks
WinCC: Time-synchronization of Basic panels with S7-1200 Controller
Update 1:
STEP 7 Professional: The STEP 7 Professional 2006 and 2010 projects can now be migrated
STEP 7 Professional: System Diagnostic Blocks are now always generated if system diagnostic is active
Homeroid_BL
Post by Homeroid_BL » Sun Sep 25, 2011 12:36 pm
Big bug after installing UPD2 for V11 SP1!
TIA DO NOT SHOW ANY PROFIBUS NODE OR DEVICE!
Terrible!
http://www.flickr.com/photos/67897722@N07/6181038236/
Homeroid_BL
Post by Homeroid_BL » Sun Jan 22, 2012 6:40 pm
Why TIA V10.5 and V11 are not compatibile (among all the rest):
Look this:
At TIA V11, REAL, UDINT, STRING and other complex variables can start ONLY AT ODD byte in Datablock.
In TIA V10.5, they can start at EVEN byte too.
SHKODRAN
Post by SHKODRAN » Mon Feb 20, 2012 8:27 pm
Hello everyone,
when I try to open a HMI project created with TIA, always get this message:
Error wrote:The application has encountered a problem and needs to close.
Would you like to restart the application?
Does anyone know how to fix being done?
Homeroid_BL
Post by Homeroid_BL » Wed Feb 22, 2012 2:44 pm
Seems to me you will never open a project. Project was written in V10.5, so find a project, print it, and write a new one in V11 recpetcing HW/SW differences in those versions.
There is one despert attempt: TIA V11 usually crashes if opens V10.5 with Wachtable created. Open project in V10.5, delete Wachtables, and try to open in V11.
adaptine
Post by adaptine » Wed Feb 29, 2012 11:51 pm
Anyone got their hands on the 64bit trial version they might want to share?
etien666
Post by etien666 » Sun Nov 11, 2012 10:10 am
Hello all,
I had installed TIA V11 and everything works fine.
After installing UPD5 and options motioncontrol and safety I can't open any existing project, and I can't create a new project too.
Do You have any idea how to resolve this problem?
I tried uninstal TIA and instal again. It didn't help.
Or how to uninstal update?
Or how to uninstal option package?
eregibispo
Post by eregibispo » Fri Nov 16, 2012 11:04 am
Subtitle: Unable to download project with Seven x64
Hello.
I have a big problem on my Windows 7 x64 laptop with TIA Portal v11 SP2 Update5.
Trying to connect via ethernet to a 1200 CPU (1214C DCDCDC fw 3.0) occours this:
1.Selecting the Accessible Devices commmand and scanning the net, the system finds the CPU and allow me to flash the leds: so this mean that the system find and log the CPU.
2.If I want to confirm the connection (pushing the Show button) the system freeze for many seconds and, after that, close the connection window without other visible actions.
3.Other thing if I wanna download the project (clicking the Download to Device button) or if I try to go online (clicking the Online button): the system opens the connection window, allow me to find and select the CPU and, when I try to download or go online, it freezes for many seconds and after that shows me one of the two messages as figured in the attached image.
So, I cannot download and online manage the project.
Note that the problem is referred to the OS, because trying the same procedure with the same project on my Windows XP 32 desktop PC, the problem does not occur: the system logs normally and I can download and online manage the project.
Now I really don't know how to do to solve this problem (sos)
Can you help me?
Thanks and goodbye.
ScreenShots
