friends..i have wincc with sp2 and i want to upgrade it to sp4.....i installed sql4 but i cannot upgrade wincc...bcs when i put the wincc sp4 cd ,it says u should put ms-tools cd and u should install security patch..and so i put ms-tools cd and i try to install security patch..but it says and error message that ""Setup cannot uptade your Windows XP files because the language installed on your system is different from the uptade language"
what is the problem?where is the false? and what should i do.....and also i checked languages of wincc and ms tools patch language..its same and its english...
![Confused :?](./images/smilies/icon_confused.gif)
