[LINK]: EPLAN Electric P8 v2.1.4 Build 5325 (x86/x64)
Re: [LINK]: EPLAN Electric P8 v2.1.4 Build 5325 (x86/x64)
I am also trying to get ver. 2.1.6 working on windows 7 with no luck
Please help
Please help
Hi.
please, can i have question?
On which version you used this patch?
I have only EPLAN Electric P8 2.0 SP1 build 4831 and EPLAN Electric P8 2.1 SP1 build 5473.
I tried diferent patches on diferent version but i can't find the right combination
Washa
Washa
manepipoca wrote:Hi!
With x32 and WinXP this works fine:
Best Regards!
I have few cracks. Sometimes works one, sometimes works another.
I am using ePLAN P8 2.1 SP1 (= 2.1.6) build 5473 at two computers.
On my notebook with Windows 7 x86 works crack with SN-U1006.EFG and this procedure:
On my second computer (desktop) there are Windows 7 x64 and previous crack does not works propertly.
The differences which I have to do are:
Interesting is that at my previous Win7 x64 (cracked) installation (E5200 / 4 GB) was ePLAN working even the test mode was disabled.
At my actual Win7 x64 (legal) installation (i7-3770 / 16 GB) is working only when the Windows are in the test mode.
Hope that helpes ...
My question:
It is possible to use Data Portal when I am using cracked version of ePLAN? How?
manepipoca wrote: -Disable UAC;
-Install Eplan P8 2.1;
-Go to control panel. There you will find licence client. Right click and click change. There you can disable the HL drivers.
-Copy the file "SN-U1006.EFG" into "C:\Documents and Settings\All Users\Application Data\EPLAN\Common" (Depends OS);
-Registry the file "SN-U1006.EFG" simply click on it;
-Run "install.cmd", are in the folder x32 or x64 of the downloaded file;
-Run "dseo13b.exe", click on next, and check the option "Enable Test Mode", click on next. Choose "Exit" and click on Next;
-Restart your computer;
-Run "dseo13b.exe", click on next, and check the option "Sign a System File" click on next, put this path: "C:\Windows\System32\Drivers\multikey.sys" and confirm. Choose "Exit" and click on Next;
-Run "dseo13b.exe", click on next, and check the option "Disable Test Mode", click on next. Choose "Exit" and click on Next;
-Run Eplan 2.1
The difference at x64 is that I have to stay in TEST mode. Otherwise the hardlock driver is not loaded.grmm wrote:Instructions:
-Add the data to the registry by running 5189.reg from the archive
-Install the new drivers (HASPUserSetup.exe)
-NEW HARD...UPDATING.....
-EPLAN 2.1.6 is running in TEST mode!
My question:
Hello Everybody
I installed P8 2.1, but i was using 1.9.11. I was making backup with Project--->Back up---> Project function. But now. I tried to Restore them, there is no project seen at the Restore table...
Then I copied the my old project folder to the new one. I opened the project but its just readable, i couldn't edit it. What should i do?
You can see the message at the pic.
None of the cracks work properly on ePlan v2.1. License "38269" is some sort of demo license which allows only 10 pages, that's why you get read-only project. Other licenses like "10066" don't work on v2.1. Last properly cracked ePlan version is v2.0 SP1, no limitations on that version. Unfortunatelly it doesn't work together with ProPanel and SchematicGenerator which are version 2.1.
SN-U1006.EFG works on 2.1 SP1 propertly without any limitations.
See my previous post.
Eplan Electric P8 v2.1.4 Sp1 (link: http://www.plcforum.uz.ua/viewtopic.php?f=7&t=17643 ) works on my PC with Windows 7x64 Enterprise Sp1(build 7601) and Test Mode only!
Where can I download this "SN-U1006.EFG" to test it? If you mean "SN-U10066.EFG" that one doesn't work with version 2.1.SN-U1006.EFG works on 2.1 SP1 propertly without any limitations.
I've tested (on clean W7 machine) ePlan's v2.0, v2.0 SP1, v2.1, v2.1 SP1. v2.0 SP1 is the last version that works properly with cracks posted here. Maybe you can post here crack that you use, so I can test it, and confirm that it works?Eplan Electric P8 v2.1.4 Sp1 (link: http://www.plcforum.uz.ua/viewtopic.php?f=7&t=17643 ) works on my PC with Windows 7x64 Enterprise Sp1(build 7601) and Test Mode only!
lets wait sadefa's uploading the newest version 2.2.5 build 6338 both p8 and pro panel for testing
Eplan P8 v2.1 SP1 and ProPanel V2.1 SP1 work properly together on my Laptop with Win7x64 Enterprise build 7601 (only in Test Mode).Risky73 wrote:None of the cracks work properly on ePlan v2.1. License "38269" is some sort of demo license which allows only 10 pages, that's why you get read-only project. Other licenses like "10066" don't work on v2.1. Last properly cracked ePlan version is v2.0 SP1, no limitations on that version. Unfortunatelly it doesn't work together with ProPanel and SchematicGenerator which are version 2.1.
Cracked as Bonavox's post!
Thank you for this Information.I made the same experience.Risky73 wrote:None of the cracks work properly on ePlan v2.1. License "38269" is some sort of demo license which allows only 10 pages, that's why you get read-only project. Other licenses like "10066" don't work on v2.1. Last properly cracked ePlan version is v2.0 SP1, no limitations on that version. Unfortunatelly it doesn't work together with ProPanel and SchematicGenerator which are version 2.1.
The thread creator should also include this into the 1st post here.
No need to to reinvent the wheel again and again.
It makes no sense, that everybody has to suffer this experience, waste hours for trying.
Then please be so kind and share this working combo with us. I am not the only one, who is tired of trying a bunch of non-working cracks.van8x10 wrote:Eplan P8 v2.1 SP1 and ProPanel V2.1 SP1 work properly together on my Laptop with Win7x64 Enterprise build 7601 (only in Test Mode).
e.g.
Eplan v2.1x build xxx (pereferably with links)
+link for working and tested crack (mention if tested with x86, x64, but preferably both)
To All gays about installing dongle.
Sometimes it is help to reinstall License Client.
Please help, if somebody knows to help me in my problem.
By my stupid inspiration I made some changes in Rights of Eplan Master settings .Now the program ask for me to login .I live a default place without entering in password field anything (as I did during a changes), but it says wrong password .How I can solve that problem .
Reinstallation not help.
added
OK!
It was easy.
Login as ADMINISTRATOR,and all right.
added
OK!
It was easy.
guys... i've got windows x64 ultimate and cannot turn on TEST MODE !!!!
any clues ?
this deser13 sth doesn't work... also openin cmd and typing there either....
when I restart system no sign is in four corners
any clues ?
Yes, and some more: Don't run crack files or Dongle Emulator in folders with long and Russian name!zart wrote:OK!
It was easy.
Re: EPLAN Electric P8 v2.1.4 EMULATOR
sadefa wrote:For version 2.1 follow the following steps:
6. Install the new drivers (provided into the rar - HASPUserSetup.exe
Regards
Where can I get the HASPUserSetup.exe file. I couldn't find it in any of the downloads.
someone has V2.2.5 with crack?
It seems that ePlan v2.1 SP1 works with crack for v2.0. Procedure is:Risky73 wrote:None of the cracks work properly on ePlan v2.1. License "38269" is some sort of demo license which allows only 10 pages, that's why you get read-only project. Other licenses like "10066" don't work on v2.1. Last properly cracked ePlan version is v2.0 SP1, no limitations on that version. Unfortunatelly it doesn't work together with ProPanel and SchematicGenerator which are version 2.1.
- install ePlan v2.0 (SP1)
- crack it with crack for v2.1 SP1, but instead of SN-U38269.EGF/SN-U38269.reg use SN-U10066.EGF (size=978)/5189.reg (size=827)
- check that everything works properly (no limitations on page numbers or similar) in v2.0
- install ePlan v2.1 SP1 WITHOUT!!! Licence Client - everything should work (no limitations...) - it is possible that it works as Basic (not Professional) version
- install ProPanel v2.1 SP1 and similar ALSO WITHOUT License Client
My procedure for crack is:
- Copy SN-U10066.EGF to (WINXP) C:\Documents and Settings\All Users\Application Data\EPLAN\Common or (WIN7) C:\User\Public\Eplan\Common\(X64)
- Run 5189.reg.
- Run\ X32 \ install.cmd or \X64\install.cmd.
- Run dseo13b.exe, choose next and select "Enable Test Mode", next. Choose "Sign a System File", next and write "C:\Windows\System32\Drivers\multikey.sys". Chose "exit", next.
- On Win32 test mode can be deactivated after cracking, run dseo13b.exe and "Disable Test Mode". Win64 needs test mode to stay active.
This is for those people for which crack for ePlan v2.1 doesn't work (like me). For the rest which didn't have this problem, this message is not interesting
I cannot run HASPUserSetup.exe in on of steps because of info
"Corrupt installation...plesae reainstall....etc.."
something is wrong with this hasp sentinel
even when I tray to disable License client or hardware key this error pops up
sb help
sb help
Hello I Successfully installed v2.0 SP1
But I have the following problem
I can not import database in menu utilitis>Parts
I do not have Parts managment in menu
I cant run mx Eplan Build 5325 under my OS Windows 7 x64. I tried serveral things you discribed here but nothing works for me. At all Files I Downloaded there isnt the HASPUserSetup.exe inside but i Download a Version from their Page. Many speak about the SN-U10066.egf and the 5198.reg or SN-U10066.reg but i cant found. I only had the SN-U38269.egf and their .reg file.
I hope anyone of you can help me.
THX
Chris
THX
Chris
SN-U10066.egf and the 5198.reg are cracks for ePlan 2.0 so you can probably find them there.Chris_MC wrote:Many speak about the SN-U10066.egf and the 5198.reg or SN-U10066.reg but i cant found. I only had the SN-U38269.egf and their .reg file
Try with this (my compilation with english instructions) and according to my installation instructions few messages ago:
http://www.filedropper.com/epe21
I don't know if it will work on x64, it works on Win7 x32.
Thanks for the Download. I think it works a little bit more. At the moment i have the Problem hat Eplan says that their is not the right Dongle. So I think that is anything wrong with the Driver or the Version of the Sentinel Driver. Whats the right Name of the Driver and their Version?
Thanks a lot!!!
Thanks a lot!!!
SN-U10066.egf and the 5198.reg don't work with License Manager / Driver from version 2.1, that's why I wrote not to install those but use License Manager from version 2.0. I think that the message you wrote confirms it.
To test this try SN-U38269.EGF/SN-U38269.reg, ePlan should open (demo mode for 10 pages). If it does than you know that you most probably need older License Manager.
I check all you write to me but in no case i can start eplan. At last I've installed Licence Client form Version 2.0 without SP but nothing happens. Anytime the same problem that the Manager say that isn't the right Dongle inside.
your link (video) dont work please reuploand itsadefa wrote:Hi,
here is a link for the video. Sorry for the poor quality of the speech, but the mic I used was quite old.
Download link for video:
http://www.filesonic.com/file/2310960711
best regards
I spent many hours trying to install eplan 2.1 on win 7 x64 and nothing, grmm post help its working 100% on my win 7 x64 sp1.
You just have to follow the instructions step by step with no errors.
Many thanks
Many thanks
Just open Eplan in the Expert mode instead of beginer mode. This will fix the problem.I have a problem when i choose new project Eplan give message to me that "The function 'Restore project' cannot be performed because of the settings defined in the rights management module".
I need instructions step-by-step to crack Eplan 2.2 on my Win7 x64. Many thnks
Hi all!
When i try to run EPLAN i keep getting popup with this message :
"The current Windows user name does not exist in the rights management function. A Windows user must log on who is also entered in the rights management as a user. The program will now terminate". I think i messed something in the EPLAN before, and now i return to EPLAN v2.1 and this keeps showing.
Please help.
Please help.
Hi all.
I have this problem with Eplan P8 2.5 x64
" no matching symbol was found in the project"
when i try to insert black box, or connection symbol, or plc input symbol...
Try cofaso 7.0 electrical cad from cofaso.com
They can import Eplan P8 macros, import / export Eplan 5 projects as well!
https://www.youtube.com/watch?v=ZU7zCpTcPDI
Regards,
Ronnie
Regards,
Ronnie
I have been trying to solve this problem for 2 days.Bonavox wrote: ↑Thu Jul 26, 2012 1:29 pmI have few cracks. Sometimes works one, sometimes works another.
On my notebook with Windows 7 x86 works crack with SN-U1006.EFG and this procedure:manepipoca wrote: -Disable UAC;
-Run Eplan 2.1
The differences which I have to do are:The difference at x64 is that I have to stay in TEST mode. Otherwise the hardlock driver is not loaded.grmm wrote:Instructions:
My question:
In my both notebook and PC the windows 7 x64 is used as operating system and I can only work Eplan P8 2.6 in test mode.
I think in win 8 and win 10 there is no mode like test mode.
