[LINK]: Softlogix v20
dimodimo
Post by dimodimo » Sun Aug 05, 2012 12:31 pm
Hello everyone,
Can anybody upload Softlogix v20?
Thank you very much for your attention.
guolibin
Re: [Request]: Softlogix v20
Post by guolibin » Sat Oct 13, 2012 1:55 pm
hussein kamal
Re: [LINK]: Softlogix v20
Post by hussein kamal » Sun Oct 14, 2012 9:49 am
hi (fback) (fback) (fback)
i want to ask how i activate Softlogix v20 can you help me in that
thanks to you
dimodimo
Post by dimodimo » Wed Oct 17, 2012 12:33 pm
Dear guolibin,
Thank you very much for share! (tyou)
hussein kamal look here:
viewtopic.php?f=41&t=15633&start=50#p54538
hussein kamal
Post by hussein kamal » Wed Oct 17, 2012 7:46 pm
Dear dimodimo
thank you for helping me but i try to activated using that's way but not working because that's first time to make that if you have description how make it i will be grateful
(tyou) (tyou)
grayfox
Post by grayfox » Thu Dec 20, 2012 7:34 pm
Here it goes
Tested and working
1-On the folder "C:\Program Files\Rockwell Automation\SoftLogix5800"
Look for the fallowing DLL RSSL5K32.dll
Hex edit:
Change 34 02 to 30 90
2-On the folder "C:\Documents and Settings\All Users\Documents\Rockwell Automation\Activations"
Add on the "ftasystem.lic" file the fallowing entry:
HOSTID=ANY vendor_info="PRODUCT_NAME:oftLogix5860" SN=0000000001 \
FFFF FFFF FFFF FFFF"
Good luck (pgood)
Helder
Post by Helder » Fri Dec 21, 2012 2:28 am
hi grayfox,
I can find 34 02!!!!! :o :o :o :o :o
what can i do??? :? :? :? :?
(sos) (sos)
Helder
Post by Helder » Sun Jan 06, 2013 2:58 pm
It's working now.... :D :D
Thank you... (tyou) (tyou)
Tanke85
Post by Tanke85 » Fri Jan 18, 2013 6:56 pm
Could you explain with more details? Because I already look for "34 02" with HexEdit Pro, but I got a lot of results, wich one should I change to "30 90"? If I change only the first one SoftLogix doesn't execute, if I change every one i get "Activation Error". (no)
Thanks in advance!
caccioz
Post by caccioz » Mon Jan 28, 2013 3:40 pm
HI ALL
Sorry all ,but Why not working with me this activation Softlogix V20?
Hex edit:
Change 34 02 to 30 90 FC339
MY RESULTS :
In Factory Talk manager / TAB Manage Activations I see properly license SoftLogix 5860 but NOT WORKING !!
When I run SoftLogix Chassis Monitor a window appears that says : Failed to activate SoftLogix 5800
Why ? Please Help me !!! Thanks
mdim
Post by mdim » Tue Jan 29, 2013 6:05 pm
Try to disable rs master license if you have it.
just comment the rows with rsmaster and check
On my PC it worked.
caccioz
Post by caccioz » Wed Jan 30, 2013 4:49 pm
(oo) (clap) (gpost)
Great !! Thanks mdim Now work !!
(tyou)
zjjunior
Post by zjjunior » Fri Feb 15, 2013 9:09 pm
mdim wrote:Try to disable rs master license if you have it.
On my PC it worked.
(gpost)
Amazing, it works like magic!!
Thanks!!
calabazo13
Post by calabazo13 » Fri Apr 05, 2013 7:12 pm
On my PC it worked.
Incredible it works perfectly thanks mdim
neto136
Post by neto136 » Mon Apr 08, 2013 5:35 pm
On my PC it worked.
(oo)
PERFET, MAN!!!!
All working now!
Thanks a lot!!!
(gpost)
Rawle30
Post by Rawle30 » Fri Apr 26, 2013 2:54 pm
I need some assistance, I'm getting the following .....
I do not have any master license to disable....here is what I have.....
SERVER this_host ANY
USE_SERVER
VENDOR flexsvr
INCREMENT fta.system flexsvr 1.00 permanent 1 VENDOR_STRING=1 \
vendor_info="PRODUCT_NAME:FTA System Placeholder" SN=1 \
SIGN="00FB D8C8 C8F8 49F2 480A E303 5567 E100 A110 03FF 3224 \
F038 B859 C955 5900"
FEATURE RS5K_700.exe flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RS5K_700.exe" SN=8283999999 \
SIGN="0088 4C88 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RSLINX.EXE flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSLINX.EXE" SN=8283999999 \
SIGN="00BF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RSLINX.GW flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSLINX.EXE Gateway" SN=8283999999 \
SIGN="00CF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RSLINX.SN flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSLINX.EXE SN" SN=8283999999 \
SIGN="00DF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RS5K_GLX.exe flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RS5K_GLX.exe" SN=8283999999 \
SIGN="00EF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RS5K_MLP.exe flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RS5K_MLP.exe" SN=8283999999 \
SIGN="00FF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RS5K_000.exe flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
SIGN="009F 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
