It is currently Mon Jan 22, 2018 3:38 am
Post new topic Reply to topic  [ 43 posts ]
 Post subject: [LINK]: Decoder ProSave
PostPosted: Wed Aug 13, 2008 2:53 pm
in Russian wrote:
Синенс уже перестал выпускать некоторые виды панелей (OP15,OP27 и др) и с ЗИПом уже сейчас напряженка. Это старье можно достать только за цену в 2-3 раза дороже, чем они стоили изначально.
Оказалось, что можно.
v1.08
http://www32.zippyshare.com/v/bDL8ugHI/file.html
reupload 09.04.2017
- Author name
- Date of compilation
- password Supervisor
- configured Panel Adress
- configured speed PLC
- configured PLC Adress
- Slot PLC
- Rack PLC
- tag adress
 Post subject:
PostPosted: Sat Aug 16, 2008 8:36 am
My KIS ( http://www.kaspersky.com/ ) and DrWeb ( http://www.drweb.com inside NAROD hoster) nothing detect.
99% of AVG false detect
 Post subject:
PostPosted: Sat Aug 16, 2008 7:01 pm
hi
My Avast nothing detect.
how said sania:
thanks :wink:
 Post subject:
PostPosted: Sat Aug 23, 2008 10:33 am
My test :
 Post subject: OP27
PostPosted: Mon Sep 15, 2008 4:08 am
Dear all,
Thx & regards,
Saree
 Post subject:
PostPosted: Tue Oct 14, 2008 10:07 am
Hi!
 Post subject:
PostPosted: Tue Oct 14, 2008 10:25 am
Schtiel wrote:
Hi!
 Post subject:
PostPosted: Wed Nov 19, 2008 6:05 pm
 Post subject:
PostPosted: Mon Nov 24, 2008 7:45 am
 Post subject:
PostPosted: Tue Dec 02, 2008 4:10 pm
mirrors:
[dead]
 Post subject:
PostPosted: Tue Dec 02, 2008 4:21 pm
Hello
 Post subject:
PostPosted: Tue Dec 09, 2008 11:24 am
ppp wrote:
I know.
I make.
Как получить такой файл?
Могу только проект дать.
 Post subject:
PostPosted: Thu Jan 08, 2009 2:39 pm
Dear all,
Thx :D
 Post subject:
PostPosted: Wed Jan 21, 2009 8:12 am
Please help....
Regards.
 Post subject:
PostPosted: Wed Jan 21, 2009 4:15 pm
Hello
Prosave-files *.psr
 Post subject:
PostPosted: Fri Apr 17, 2009 7:14 am
 Post subject:
PostPosted: Fri Apr 17, 2009 8:17 am
Привет,
С уважением.
Umencho
PostPosted: Wed Apr 07, 2010 11:49 pm
great job, congratulation
PostPosted: Wed Nov 03, 2010 4:43 pm
PostPosted: Wed Nov 03, 2010 8:44 pm
PostPosted: Sat Jul 07, 2012 7:45 pm
plz help me
PostPosted: Sat Jul 07, 2012 7:48 pm
plz help me
place it to Rapidshare - ppp can view :D
PostPosted: Fri Feb 15, 2013 10:54 pm
PostPosted: Sat Feb 16, 2013 1:02 am
ok, this is the new link
http://www.4shared.com/file/Uyl-tLYI/ST130_14FEB13.html
PostPosted: Wed Mar 27, 2013 12:51 am
PostPosted: Tue May 14, 2013 12:48 pm
thx
PostPosted: Thu Oct 10, 2013 1:37 pm
PostPosted: Thu Dec 12, 2013 3:23 pm
Спасибо большое за работу!
PostPosted: Thu May 08, 2014 9:55 pm
try the next link:
http://www.girlshare.ro/33556006
dekor.
PostPosted: Tue Aug 12, 2014 9:18 am
can not be used. Thank you!
PostPosted: Fri Oct 10, 2014 10:37 pm
Ребята, я потерял програмулину.... перезалейте у кого есть плз!
I lost this usefull software... Please, reload it to same Share... Thanks!
PostPosted: Tue Nov 11, 2014 4:53 am
Dear Sir,
Regards,
Baronat
:D
PostPosted: Tue Nov 18, 2014 3:50 pm
Hi all,
PostPosted: Mon Dec 29, 2014 10:55 pm
========= Admin =============
KIS delete this file :(
пароль был 1
PostPosted: Fri Jul 10, 2015 12:13 pm
PostPosted: Mon Aug 17, 2015 4:12 pm
Добрый день!
PostPosted: Thu May 19, 2016 3:53 pm
Thanks for any kind of help
PostPosted: Thu Sep 15, 2016 2:28 pm
hello
have you an other link to download this soft
thank you
PostPosted: Fri Oct 14, 2016 10:00 am
Доброго всем дня!
Может кто-нибудь помочь с живым линком на эту полезную программу или может поделиться из своих закромов ?
PostPosted: Mon Oct 31, 2016 7:41 pm
Hi my friends, i need prosave decoder, anyone can upload, please!
PostPosted: Wed May 31, 2017 10:42 am
Hello PPP
PostPosted: Fri Jun 09, 2017 4:54 am
Hello Everyone (welc)
I have an OP7 backup file.
Link to the .psr file below
(dlink)
Best regards (tyou)
Mireklab
PostPosted: Thu Nov 30, 2017 12:43 am
Great job !!! Спасибо !!
cron
