[LINK]: Case FBD from Sauter
Hi everybody
Does anyone have Case FBD from Sauter? or/and any soft from this link
http://www.sauter-controls.com/sauter/e ... _eng_.html
Thanks for any hint.
Cheers
Jamrobe
Cheers
Jamrobe
Thousands thanks artbistr
However, I have encountered a minor problem
Your files contains a upgrade licence for the software.
As I do not have a original licence, normally, I am informed that "Licence not found" when I try to upgrade.
Any solution as how to get around this problem?
Regards
Jamrobe
Regards
Jamrobe
It is an image of a diskette with the licence.
sauter.img
Link_is_Dead :(/sauter.img
http://files.mail.ru/QV5049
http://www.winimage.com/ for write image to floppy
Good luck!
sauter.img
Good luck!
Dear bugorka
Thank you very much , but i have used winimage from winimage.com
and tryed to move the license but it is giving me failure of moving the token.
any how i have installed the software, but when i run novapro32 it is asking me for the place of the project to open , how can i create a new project?
an image of license-disket:
Link_is_Dead :(/case.imz
http://www.rapidshare.ru/1016982
-------- for write with ------------------
Re: [LINK]: Case FBD from Sauter
Please i need this program too
If you have case fbd please send it to me i will send u crack licjsmith wrote:Please i need this program too
Thamx
Does any one have this diskette? My HDD in control PC is damaged and I can not access "Case FBD" nor "NovaPro32". I have some license files but I do not have license installer. If I try to install software it show me info that I have to install license first.
Hi.
I searching for diskette license for Case FBD. Can anybody share it?
Thanks so much.
Thanks so much.
